My NIOS-II IDE hangs on startup most of the time I try to run it.
I'm using the Sun Java 2 Platform v1.5.0_04.b05. As soon as I try to select a menu option, it says "Not Responding". Sometimes a reboot helps, otherwise I just keep trying 'til it works. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif Anyone else out there had this problem? Regards, MarkLink Copied
