nios vga controller
I am doing a project using TRDA-D5M to input image to DE2. The package of TRDB-D5M comes with the coding for storing the data into SDRAM and output to vga. I need to process the image captured by the camera which stored in SDRAM. Hence, I had built a module so called CMOS controller to interface the SDRAM with the NIOS. Now, I want to build a VGA controller using SOPC builder in order to capture the data from the cpu or CMOS controller for display. I used the VGA controller provided in DE2 disk under component section to build a new component in SOPC builder. However, I get this errors---->
Error: set ALTERA_HW_TCL_KEEP_TEMP_FILES=1 to retain temp files
Error: Command: c:/altera/10.0/quartus//bin/quartus_map.exe not_a_project --generate_hdl_interface=C:/altera/10.0/cam/hdl/VGA_NIOS_CTRL.v --source=C:/altera/10.0/cam/hdl/VGA_Controller.v --source=C:/altera/10.0/cam/hdl/Img_RAM.v --source=C:/altera/10.0/cam/hdl/VGA_OSD_RAM.v --source=C:/altera/10.0/cam/hdl/VGA_NIOS_CTRL.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/RICKYY~1/AppData/Local/Temp/alt4925_3538248411242696065.dir/0005_sopcqmap/
Error: VGA_Controller_0: Info: *******************************************************************
Error: VGA_Controller_0: Info: Running Quartus II Generate HDL Interface
Error: VGA_Controller_0: Info: Version 10.0 Build 218 06/27/2010 SJ Web Edition
Error: VGA_Controller_0: Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved.
Error: VGA_Controller_0: Info: Your use of Altera Corporation's design tools, logic functions
Error: VGA_Controller_0: Info: and other software and tools, and its AMPP partner logic
Error: VGA_Controller_0: Info: functions, and any output files from any of the foregoing
Error: VGA_Controller_0: Info: (including device programming or simulation files), and any
Error: VGA_Controller_0: Info: associated documentation or information are expressly subject
Error: VGA_Controller_0: Info: to the terms and conditions of the Altera Program License
Error: VGA_Controller_0: Info: Subscription Agreement, Altera MegaCore Function License
Error: VGA_Controller_0: Info: Agreement, or other applicable license agreement, including,
Error: VGA_Controller_0: Info: without limitation, that your use is for the sole purpose of
Error: VGA_Controller_0: Info: programming logic devices manufactured by Altera and sold by
Error: VGA_Controller_0: Info: Altera or its authorized distributors. Please refer to the
Error: VGA_Controller_0: Info: applicable agreement for further details.
Error: VGA_Controller_0: Info: Processing started: Fri Nov 12 08:48:55 2010
Error: VGA_Controller_0: Info: Command: quartus_map not_a_project --generate_hdl_interface=C:/altera/10.0/cam/hdl/VGA_NIOS_CTRL.v --source=C:/altera/10.0/cam/hdl/VGA_Controller.v --source=C:/altera/10.0/cam/hdl/Img_RAM.v --source=C:/altera/10.0/cam/hdl/VGA_OSD_RAM.v --source=C:/altera/10.0/cam/hdl/VGA_NIOS_CTRL.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/RICKYY~1/AppData/Local/Temp/alt4925_3538248411242696065.dir/0005_sopcqmap/
Error: VGA_Controller_0: Info: Quartus II Generate HDL Interface was successful. 0 errors, 0 warnings
Error: VGA_Controller_0: Info: Peak virtual memory: 265 megabytes
Error: VGA_Controller_0: Info: Processing ended: Fri Nov 12 08:48:57 2010
Error: VGA_Controller_0: Info: Elapsed time: 00:00:02
Error: VGA_Controller_0: Info: Total CPU time (on all processors): 00:00:01
Error: VGA_Controller_0: Command took 1.872s
Error: VGA_Controller_0: No definition of VGA_Controller in C:/altera/10.0/cam/hdl/VGA_NIOS_CTRL.v
Error: VGA_Controller_0.avalon_slave_0: Has readdatavalid but no read signal
Error: VGA_Controller_0.avalon_slave_0: Slave with readdatavalid signal must support at least 1 pending read
What does these means?..
How can i fix the problem?..i hope can get some advices from experts. Thanks.
may i know how to create the cmos controller? can guide me? thanks..
btw, regarding your problem.. new vga ip for sopc is available for download now..
working with 9.1 10.0sp1 and 10.1sp1..
I just 'fixed' this problem by shutting down SOPC builder then quartus. Then restarting both applications and generating my sopc. It worked.
Software quality for you right there......
SOPC Builder is a legacy tool....
It may be. However I have had problems with Qsys so I revert to SOPC. Even in its shortcomings it appears more reliable than Qsys.
