I'm a newbie to uclinux
trying to connect to a custom board I get the following errors when using the tse (experimental) in uclinux am I missing any driver or are there any changes that i've to do in any files ************************************************ In file included from /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1084: /home/dpatloll/nios2-linux/linux-2.6/include/../drivers/net/atse.h:30:2:# error "**** This build has not been configured with Alteras example design of TSE-SGDMA." /home/dpatloll/nios2-linux/linux-2.6/include/../drivers/net/atse.h:31:2:# error "**** You need to do: make vendor_hwselect SYSPTF=<your_path>/NiosII_stratixII_2s60_RoHS_TSE_SGDMA_sopc.ptf" /home/dpatloll/nios2-linux/linux-2.6/include/../drivers/net/atse.h:32:2:# error "**** Or, You need to unselect ATSE ethernet driver with make menuconfig" /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c: In function `atse_device_init': /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1153: error: `na_tse_mac_control_port' undeclared (first use in this function) /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1153: error: (Each undeclared identifier is reported only once /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1153: error: for each function it appears in.) make[3]: *** [arch/nios2/kernel/config.o] Error 1 make[2]: *** [arch/nios2/kernel] Error 2 make[2]: *** Waiting for unfinished jobs.... **************************************** the following errors are in uclinux when i'm using the tse mac (SLS) *************************************************** /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1169: error: `na_tse_mac_control_port' undeclared here (not in a function) /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1169: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1169: error: (near initialization for `alt_tse_resource[0].start') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1170: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1170: error: (near initialization for `alt_tse_resource[0].end') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1173: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1173: error: (near initialization for `alt_tse_resource[0]') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1179: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1179: error: (near initialization for `alt_tse_resource[1]') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1185: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1185: error: (near initialization for `alt_tse_resource[2]') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1191: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1191: error: (near initialization for `alt_tse_resource[3]') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1197: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1197: error: (near initialization for `alt_tse_resource[4]') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1203: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1203: error: (near initialization for `alt_tse_resource[5]') /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1211: error: initializer element is not constant /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1211: error: (near initialization for `alt_tse_resource[6]') make[3]: *** [arch/nios2/kernel/config.o] Error 1 make[2]: *** [arch/nios2/kernel] Error 2 make[2]: *** Waiting for unfinished jobs.... *************************************************** someone please let me know ..what might be the problem again I'm a newbie to this whole nios and uclinux thing thank youLink Copied
what is the name of your tse mac in sopc builder? did you change the platform driver setup in config.c to match that name?
--dalon- Mark as New
--- Quote Start --- what is the name of your tse mac in sopc builder? did you change the platform driver setup in config.c to match that name? --dalon --- Quote End --- Thank you for the response my tse mac is named ethernet do i have to change it (to something like tse_mac) what changes do i have to make in the config.c please let me know
if you look at the config.c file, all the (or most of) the peripherals are defined using the swinfo2header command generated .h file# defines from an example design. that means that you either need to modify your sopc system to match the names of the example design's components, or modify the confic.c platform driver instances to reference the correct# defines for your system.
Thank you
will try and see if it works :)
