12612 Discussions
what is the problem boot using nfs?
I try to boot linux using nfs. I can successfully configure the ip of the board.
The last three lines of the messages are as follows:
VFS:Mounted root (nfs filesystem)
freeing unused kernel memory.....
kernel panic: no init found. Try passing init=option to kernel
I manually change the files in /dev by using the similar command:
mknod ptyp0 b 0 8
I change some files but not all. Is it problematic?
Thanks!
cloud,
I use the Omni-nfs server v4.2 as the nfs server in windows2000.So I boot the system as nfs is successful.Are you correct the kernel config as Microtronix documents?
Tony,Zhu
--- Quote Start ---
originally posted by zrycq@Oct 31 2004, 08:20 PM
cloud,
        i use the omni-nfs server v4.2 as the nfs server in windows2000.so i boot the system as nfs is successful.are you correct the kernel config as microtronix documents?
        tony,zhu
--- Quote End ---
Thanks, I followed the instructions according to the document. It seems that the nfs has been succesfully mounted. And the system did try to get started from nfs system.
I did not change all the files in the /dev directory. does that matter?
cloud,
I create the filesystem in CF card,you may try.And I use the Aletra'stratix 1s10 board.I can startup,can write,can read,but there is one problem that once execute *.exe file ,the uclinux is restarted.The manner that rely on ramdisk,I don't try.
Tony,Zhu
