I try to boot linux using nfs. I can successfully configure the ip of the board.
The last three lines of the messages are as follows: VFS:Mounted root (nfs filesystem) freeing unused kernel memory..... kernel panic: no init found. Try passing init=option to kernel I manually change the files in /dev by using the similar command: mknod ptyp0 b 0 8 I change some files but not all. Is it problematic? Thanks!Link Copied
cloud,
I use the Omni-nfs server v4.2 as the nfs server in windows2000.So I boot the system as nfs is successful.Are you correct the kernel config as Microtronix documents? Tony,Zhu- Mark as New
--- Quote Start --- originally posted by zrycq@Oct 31 2004, 08:20 PM cloud,
i use the omni-nfs server v4.2 as the nfs server in windows2000.so i boot the system as nfs is successful.are you correct the kernel config as microtronix documents?
tony,zhu --- Quote End --- Thanks, I followed the instructions according to the document. It seems that the nfs has been succesfully mounted. And the system did try to get started from nfs system. I did not change all the files in the /dev directory. does that matter?
cloud,
I create the filesystem in CF card,you may try.And I use the Aletra'stratix 1s10 board.I can startup,can write,can read,but there is one problem that once execute *.exe file ,the uclinux is restarted.The manner that rely on ramdisk,I don't try. Tony,Zhu
