Hey guys,
I've posted this around on a few forums and not got any luck so I'm hoping the Intel community can come through with the goods. I've got a brand new system and all of a sudden it's become highly unstable (and therefore unusable) due to being stuck in a BSOD loop rotating between several different errors. Whilst testing components we noted that crashes were also caused when inserting a USB wifi dongle and/or flash drive.
I've tested other components pretty heavily (and separately) but the CPU is a little trickier for me to isolate. We've checked for physical damage (bent pins and the like) and haven't seen anything. I also did a stress test before it got unusable and there were no errors or high temps there.
Any help would be greatly appreciated, I'm at my wit's end.
Computer Specs- Windows 10 Pro 64-bit
- Intel Core i7 @ 4.20GHz Kaby Lake 14nm Technology
- RAM 16.0GB
- MSI Z270 GAMING PRO CARBON (MS-7A63) (U3E1)
- ASUS MG279Q (2560x1440@64Hz)
- ATI Radeon RX 580 Series (MSI)
- 465GB Samsung SSD 840 EVO 500GB (SSD)32 °C
- Realtek High Definition Audio
- Silverstone Strider Gold S Series 80 Gold 850W PSU
http://speccy.piriform.com/results/hoGRDXBkFHvy1CFiUJ18 http://speccy.piriform.com/results/hoGRDXBkFHvy1CFiUJ18...
http://speccy.piriform.com/results/U2tl25T2LXfHXvxFMhRZ http://speccy.piriform.com/results/U2tl25T2LXfHXvxFMhRZ... (From Safe Mode, in case it's helpful)
BSOD errors noted- Driver overran stack buffer
- Kmode exception not handled
- Recource not owned
- Kernal security check failure
- Reference by pointer
- FLTMGR.sys
- Quota underflow
- CRITICAL_PROCESS_DIED
- Bad pool caller
- NTFS.sys
- Page fault in nonpaged area
- DPC watchdog violation
- System thread exception not handled
- ++ a few which I've missed
Safe mode is the only way to be able to use my system for longer than a few seconds. The PC can't even remain stable for long enough to reinstall windows! Hardware-wise nothing has been tweaked beyond how it came in the box. Here are my specs, in case it helps.
Here is my report from System Information: https://www.dropbox.com/s/t7cn0y8ls5r6rsr/System%20Information.txt?dl=0 https://www.dropbox.com/s/t7cn0y8ls5r6rsr/System%20Information.txt?dl=0
And here are my mini dumps: https://www.dropbox.com/s/7flgrclmgayzdbb/Minidump.zip?dl=0 https://www.dropbox.com/s/7flgrclmgayzdbb/Minidump.zip?dl=0
When this issue beganThis may or may not be related, but when playing PlayerUnknown's Battlegrounds (PUBG) I got a system lock up accompanied by a plain screen of flat colour (which may actually be close to my theme's colour: dark red and an audio stutter/buzz). Hard power-down is required. As my best guess, this was the when the BSODs started.
Recurring issueYes. If I can get to Safe Mode is it fine though. I can't recall a BSOD in Safe Mode. EDIT: It does crash in Safe Mode with USB insertion/removal.
Date of purchase1 month ago, still under Warranty
Cause/Steps to recreate the issue
Turn on PC and it'll happen almost instantly. Some BSODs happen before you even get into Windows. Crashes even happen during Windows install process. The only way to reinstall was to take the SSD out and install Windows using another PC before putting the SSD back into my box.
Plugging something into USB will almost certainly BSOD it too.
What I've tried so far to resolve the issue- Win10's inbuilt memory test
- MemTest86 (8 passes)
- Tested RAM sticks individually
- chkdsk + scandisk
- Rebuild MBR
- System Restore (BSOD during)
- System Reset (can't do it sometimes, other times it BSODs)
- Startup Repair (BSOD during)
- Removed GPU, ran DDU and tried onboard GFX
- Removed all other components and tested successfully separately
- Updating all motherboard drivers and flashing BIOS
- Unplugging front USB from motherboard
- Updating SSD firmware
- Tested another RAM stick from motherboard's compatibility list and still got BSODs
- Win8 wouldn't complete an install either. BSODd during install (as does Win10)
- Installed Win10 on same SSD in another PC and it went fine (ie the SSD is fine)
- Ubuntu seemed to run fine off USB3
- There may be more, sorry I've tried so much I've probably forgotten some of the things.
Everything seems to point to the motherboard being faulty but I've just got this gut feeling that because it doesn't BSOD (as far as I remember) safe mode it's not faulty. Before I send it off for RMA and potentially incur a cost for them not finding it faulty I thought I'd try one last time to find an expert who might be able to shine some light on this for me.
Thank you in advance for any help you can give me, I am so desperate to get this sorted out.
- Tags:
- HP Desktops
Update: I ran sfc/scannow again and I got a few errors once it'd finished.
Screenshot of https://www.dropbox.com/s/kyzh80o02fubpia/SFCScannow.PNG?dl=0 Command Prompt and https://www.dropbox.com/s/aki2qwb0vc137jv/CBS.log?dl=0 CBS.log.
Could this just be a failing SSD after all? Are there any other checks you can do to stress an SSD or check it more thoroughly?
Hi BattleCat: Thank you very much for joining the Intel® Processors communities and for providing that information. We are sorry to hear the PC is not working properly.
At this point basically you tried all the troubleshoot steps that we recommend in order to try to fix this problem. As you mentioned, normally this kind of issue is related to the board but the only way to confirm that will be by swapping parts.
Do you have the option to test your processor on a different board or test your board with a different processor?
Could you please test the PC without the video card? This is just to rule out a possible problem with it.
On the link below you will be able to see that the memory RAM that is fully compatible with the processor is: DDR4-2133/2400, DDR3L-1333/1600 @ 1.35V, please make sure that RAM is running under that configuration:
http://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz http://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz
In regard to your inquiry, yes, the problem could be also related to the SSD. I looked for tools to do a health test on it and I found a link that provides some 3rd party applications to do that, hopefully you will be to use them. Other than that to test the PC with a different SSD/hard drive will be the next thing to do to confirm if that is the case:
http://mashtips.com/ssd-health-test-and-performance-monitor-tools/ http://mashtips.com/ssd-health-test-and-performance-monitor-tools/
Additionally, we can run a tool to test the processor, it will do an overall test on it including a temperature test so we can rule out a possible problem in that regard:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Any further questions, please let me know.
Alberto R
Thanks very much for the reply, Alberto.
The RAM is 1333Mhz, so there shouldn't be any issue there, I've also been in contact with MSI and they said there shouldn't be any issues with the RAM I have. I've also tested the system without a GPU and it still displayed the same symptoms through onboard GFX.
I have already run Samsung Magician on the SSD and that didn't return any errors. I grabbed Crystal Disk Mark and the Intel tool but between keeping the system stable long enough to run them and compatibility with the Intel tool it might be a while! That said, it just completed Crystal Mark and below is a screenshot of the results (do they tell any story to you?). Interestingly, the PC crashed within seconds of the test finishing. I'm not sure if that was a coincidence or not.
I'll post an update if I can get the Intel tool to work. Thanks again for your suggestions.
BattleCat: You are welcome. Thank you very much for letting us know those results and for the picture. Hopefully you will be able to run the Intel tool to confirm if the processor is working fine. Since the option to swap parts is not available, a replacement of the processor might be needed. In case you are interested in that option, you can always verify with the place of purchase if they have the chance to do that for you, or you can get in contact directly with Intel so they can further assist you with the process:
Chat support:
http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat,
For phone support, depending on your location, you will see the contact information on the links below:
EMEA contact information: http://intel.ly/28QeAF3 http://intel.ly/28QeAF3
APAC contact information: http://intel.ly/1ITfjUF http://intel.ly/1ITfjUF
LAR contact information: http://intel.ly/29c0rW4 http://intel.ly/29c0rW4
North America: Phone Number 1-916-377-7000, Monday - Friday 7:00 AM to 5:00 PM (Pacific Time).
Alberto R
Thanks, Alberto.
I ended up taking it into a repair shop and they performed a few tests and discovered that the CPU was faulty. They put it on another board and it crashed that too, and tried a different CPU on my board and it booted fine. They got an advanced RA, tested the replacement CPU and it was fine. I'm set to pick up my PC tomorrow, I'm so glad this ordeal is behind me now (it's just unfortunate I had to pay to have a service team to troubleshoot it)!
BattleCat: You are very welcome. Perfect, thank you very much for letting us know those results. We are glad to hear that you found the source of the problem in order to fix it. We apologize for any inconvenience.
Any other inquiry, do not hesitate in contact us again.
Alberto R
![](/skins/images/FCBE28625AAD2D8AF3EB3F393BF39703/responsive_peak/images/icon_anonymous_message.png)
