Processors
16002 Discussions
Can anyone verify if my P-core 3 is defected? - i9 -14900K
Khoa
This is a 2024 freshly bought i9-14900K - bought it in June
I just got the PC back from the retailer to re-paste the CPU and clean the dust
Lately I got crashed while playing warthunder with 3-4 chrome tabs opening
Things got more often when I see throttling 'YES' at P-core 3 right after the crashes. Simultaneously, my chrome tabs also got crashed.
Here is the attached photo in Hwinfo under light load after the cleanup and paste-reapplied.
Thank you for your assistance.
Khoa
This is sometime later ... P-core 3 at 70C
CoolBook
Hi @Khoa
It looks odd, but theoretically you could get a single core boost affecting only one or two proffered cores.
I see that you have very high voltages as well. Having that behavior would definitely cause instability and risk of degrading.
Could you limit the max frequency in BIOS as an experiment?
Khoa
can you tell how? bios setting varies accros brands
I'm using
PRO Z790-S WIFI
CoolBook
aCNuser
use Prime95 small ffts test
and see which core fails, then manually down the core ratio for that core
RippedBy14900KS
Yes if it does not meet advertised standards , it is 100% defective.
RMA it. And in august again as they claim from then on there will be a fix.
