1. I click DOWNLOAD NOW button:
2. and then I get this:
First, message is misleading and should be more user friendly with better explanation. What can I do with this information? No advice, no tip what this "support ID" means, no url link to proper sources.
I could download this without problems on first fresh start of Windows after install, now it stopped working. Maybe because some updates came or sth. System is new and clean as it can be, only browsers installed and drivers updated by windows update.
Tried cleaning cookies, using many browsers, result is the same.
Now I don't know if this is a server side problem or my configuration problem and should I look deeper or sth.
Forgive me if this is wrong board selected to post. Didn't found obvious one like "Support software problems"
@LeonWaksman @pzagawa @PatrickPlante @KrzyKyle @MO9 Thanks for your patience. Our team was able to reproduce the issue and implement the appropriate fix. Please clear your browser cache and retry downloading IDSA now.
Thank you for bring this issue to our attention.
Monique with Intel Corporation
You are not wrong. The download link is not working. Wait for answer from Intel expert ( @Monique_Intel )
Leon
Any news on this? I just did a fresh install of my windows and want to update my drivers. But I too am getting this error when I try to download Intel Driver & Support Assistant.
Hi @KrzyKyle
While you are waiting for IDSA, do not forget that the first driver to be installed is the Intel Chipset Software Driver for your computer. This driver should be downloaded and installed manually only, before using IDSA for downloading the other drivers.
Leon
This is happening at least since August 5th and on many locations. I tried it on various ISP in my region and also with VPN activated for 3-4 countries.
The error message let us think the issue is on our side, but it's not. It's clearly on Intel side.
I configured about 5 new computers since this issue started and never been able to download it with any new computer.
I am the Project Manager for IDSA. I've escalated this reported error to our internal IT contacts for review; our IDSA team haven't experienced this issue and haven't been able to reproduce the error.
Thank you for your patience and in the meantime, you can always manually download Intel drivers at Download Center.
Hi Monique,
Attached pls find a video clip taken from my computer, showing the problem.
Leon
@LeonWaksman @pzagawa @PatrickPlante @KrzyKyle @MO9 Our internal team has cleared the cache for that URL...can you try again and see if it allows you to download IDSA now?
Hi Monique,
Same result as before (i.e. not working, broken link). Cleared browser cache. Checked in Chrome and Edge.
Leon
Looks like we have bigger architecture problem here which can't be resolved by standard "maintenance" procedure.
Why not just give people direct link to storage server resource, not some fancy generated url / content blocked by thousands of conditions.
I can confirm it works now on my end. Thanks !
