Processors
16002 Discussions
I dont find PCI\VEN_8086&DEV_8C96 Intel(R9) Series Chipset Family PCI Express Root Port 4 - 8c96
Manuel28
Hi
I didn't find driver update intel's website for PCI\VEN_8086&DEV_8C96 " Intel(R9) Series Chipset Family PCI Express Root Port 4 - 8c96".
Why ?
Thanks for answers.
n_scott_pearson
Normally, you get the Chipset Device Software (a.k.a. INF Update) package from your motherboard (or system) vendor. They have the version of the package that is specific to your chipset.
Hope this helps,
P.S. Once you have the package, I suggest that you install it using the following process:
  1. If you haven't already, download the Chipset Device Software package, in ZIP file form, to your system.
  2. Extract the contents of this package to a temporary folder.
  3. Open a Command or PowerShell Window and make this temporary folder the current folder.
  4. Run command ".\SetupChipset.exe -overall".
  5. Reboot.
  6. Delete temporary folder.
Manuel28
Thank you for your answer
I try this solution
VARADHARAJAN
Valued Contributor I
@Manuel28
I found the driver, use the device manager to install  inf file
Driver.zip  contains one particular driver
Chipset_10.1.1.42_old.zip contains all the drivers
Varadharajan K
