TENGO UNA PC CORE 2 QUAD Q6600 CON MAINBOARD DG33FB,
EL PROBLEMA ES QUE CUANDO LE COLOCO 4 GB DE RAM SE PONE
MAS LENTA QUE CUANDO TENIA 2 GB DE RAM.
QUIERO SABER SI ES PROBLEMA DE MAINBOARD, PROCESADOR O MEMORIA?
Hello;
What I recommned you is to make sure that the memory that you are using is fully compatible with your processor, you can check the list of support memory for your processor here:
http://www.intel.com/support/motherboards/desktop/dg33fb/sb/CS-026593.htm http://www.intel.com/support/motherboards/desktop/dg33fb/sb/CS-026593.htm
