I'm wondering if this is an issue with the Intel XTU application or indicative of a problem with the cpu or motherboard.
I've been trying to chase down intermittent drops in frame rate, like the system hangs momentarily, while playing FFXIV. It may be while using other applications, but I can notice it with that as there is typically constant movement on the screen most of the time.
Any ideas?
These are examples of what I've seen:
Having the exact same issue right now after just purchasing my i9 14900k. Newest motherboard update including the intel patch and I'm getting the same voltage spikes where it goes to over 1000000000 watts for a brief second. Did you find a fix or whether this is just a XTU bug and not a real issue?
