Processors
14589 Discussions
Processor cpu lag?
I wonder if it's becouse my Processor is just bad or I might need some driver of likely. Dxdiag says following: Intel(R) Core(TM) 2 Duo CPU E4500 @ 2.20Ghz (2CPUs), ~2.2GHz - NVIDIA GeForce 8800 GT The windows 7 PC test or whatever you can call it says this
http://img207.imageshack.us/img207/1330/94385291.jpg http://img207.imageshack.us/img207/1330/94385291.jpg Any tips will be appreciated, thank you in advance
(I was having the exact same lags in Windows xp home edition)
I'm having low fps around 10-40 in World of Warcraft with the lowest possible graphic.
Try running this free program. It will stress test your system. It usually finds any problems within the first 10 minutes, it's really good.
http://www.pcworld.com/downloads/file/fid,7146-order,1-page,1-c,alldownloads/description.html http://www.pcworld.com/downloads/file/fid,7146-order,1-page,1-c,alldownloads/description.html
I would not ue vista for benchmarking or rating, get vantage or 3dmark06. If your system is stable then is fine since your clocks are low try overclocking a bit. For stabilty use prime95
