Processors
14643 Discussions
Turbo Boost Not Enabled
In the past, when I run the Turbo Boost Technology Monitor, it works fine. But just recently, performance on games has been extremely slow, so I checked it again. When I opened the monitor, it said "Turn on turbo boost technology, Intel turbo boost has to be enable to run this program".
I looked up multiple forums and etc but I couldn't find a way to enable it. I've also installed HWiNDO and after the test it said Turbo Boost Technology - Supported, Disabled. I'm on a laptop and there's nothing to enable in the BIOS. I've tried overcloaking with MSI Afterburner too, but that didn't work either. How can I re enable turbo boost?
Oh, and I'm plugged in, and power plan is on High Performance.
Adolfo_S_Intel2
I would suggest running the Intel® Processor Identification Utility to determine if the processor is being properly recognized by the system.
You can download the Intel® Processor Identification Utility at:
http://www.intel.com/support/processors/tools/piu/ http://www.intel.com/support/processors/tools/piu/
When running this tool, make sure that it reports the Intel Turbo Boots technology as available.
Also install the latest BIOS version for your laptop system, and check with them if there is an option on their BIOS to enable or disable the Intel Turbo Boots technology.
If the issue continues, let me know the processor model number on your laptop?
Thanks for the reply. I'm not sure which part of the Intel Processor Identification Utility do I look at for the report that says Intel Turbo Boots technology as available or not. My processor is a Intel Core i7-2670QM.
Edit: Under CPU Technologies, I can't find Intel Turbo Boost Technology.
Adolfo_S_Intel2
Please provide me the log file generated by the Intel® Processor Identification Utility to I can check it for you.
You can copy/paste the reports on the forum so I can read it.
Intel(R) Processor Identification Utility
Version: 4.50.20120413
Time Stamp: 2012/08/25 02:12:20
Operating System: 6.1-7601-Service Pack 1
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 4
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
Type: 0
Family: 6
Model: 2A
Stepping: 7
Revision: 1A
Maximum CPUID Level: D
L1 Instruction Cache: 4 x 32 KB
L1 Data Cache: 4 x 32 KB
L2 Cache: 4 x 256 KB
L3 Cache: 6 MB
Packaging: µPGA/BGA
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: Yes
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: Yes
System Graphics: Intel(R) HD Graphics 3000
Expected Processor Frequency: 2.20 GHz
Reported Processor Frequency: 2.20 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
Adolfo_S_Intel2
I double checked, and the Intel® Processor Identification Utility does not report that feature, so in this case since you have a laptop system, you will need to contact the laptop manufacturer to see if they can tell you the reason that the feature is being reported as disabled.
You can guide them to this website to let them know that the processor actually supports the feature:
http://ark.intel.com/products/53469/Intel-Core-i7-2670QM-Processor-(6M-Cache-up-to-3_10-GHz) http://ark.intel.com/products/53469/Intel-Core-i7-2670QM-Processor-(6M-Cache-up-to-3_10-GHz)
As a suggestion try installing the latest BIOS version for your laptop if available, however you will need to contact them in order for them to help you updating the BIOS.
