Processors
14646 Discussions
Upgrade CPU T5470
MPtraxx
I have an old laptop i just renovating this laptop as my backup laptop. So i want upgrade HDD will be replaced with SSD (added 2 GB RAM - total 4 GB) and also i just thinking about CPU upgrade.
What do you think? I have T5470 (PPGA478 socket) i wanted replace this for best cpu in this case (product family or whatever simply much better than i have). I look for QX9300 which is also core 2 family but quad also PGA478 and not PPGA478). So i read something that it will fit into socket but it wont work hmm. Can you confirm that?
If QX9300 wont work then i should take X7900 (2 cores) or T9900 (2 cores with 3 GHz). Or which cpu is best in this case?
So i looking for maybe high end CPU for my laptop.
Primary i have desktop with i7 8700K this notebook is as backup or weekly use.
AlHill
For an upgrade processor, the motherboard/system bios must support it.  Check with the motherboard/system manufacturer for which processors their bios supports.
Socket compatibility is NOT enough.
[If you find any Intel driver you might need, download and save it now.]
MPtraxx
I dont know all what i know is that i have acer colombia BIOS (Phoenix Technologies LTD v. 1.35) in system info.
AlHill
Who made the laptop?  That is who you check with.
MPtraxx
Acer Extensa 5620 model. But on acer webpage i tried here download drivers or manuals and when i fill SNID or Serial page giving me error (could not find). So serial does not exists now. But i am sure in past worked SNID.
AlHill
Listen closely:  ASK ACER what processors are SUPPORTED BY THEIR BIOS.
MPtraxx
Listen you also acer dont recognize my notebook via my Serial number or manufactured number... I doubt that acer will know which CPUs are compatible with my board. But okay i thought that it depends on socket as always... I read on net some people upgraded their T5470 to T8300 or T9300 but HP brand of notebook for example...
I will ask acer „experts”
AlHill
There is no way anyone here can tell you what the  acer bios supports.
If you want to play with "renovating" such old devices, you need to experience the pain of doing so yourself.
AlHill
This link tells you nothing.
You need to get information on what processors are supported by the acer bios.
MPtraxx
Hmm acer have same bios or not? I mean phoenix technologies bios. And also i have in user guide listed these CPU so i think it should be works but i dont have list of supported CPU from acer they dont know. I asked it.
AlHill
It is an acer bios.
If you use a processor that is not supported by the bios, it may work, it may not work, or it may work with errors.
And, you also need to consider that the laptop was not necessarily designed to support higher wattage processors.
MPtraxx
Yeah i understand... I hope that every acer extensa 5620 use same BIOS...
