Processors
15930 Discussions
XTUOCDriverService causes delays and lags with windows11
vcheruk3
Lately I have been noticing signifcant performance concerns with minimum usage of PC resources.
CPU/Memory/GPU and disk utilization are at the very minimal usage, however I have been experencing significant delays while using windows11 with activites like browsing, screen refresh, install and unistall programs. With the XTUOCDriverService disabled in the system configuration, everything seems to be working normally.
Attached is the SSU scan report with the above service disabled. Can you please advise?
Earl_Intel
Hi vcheruk3,
For us to better understand your concern, can you provide the following details listed below:
  • May I know if the system is working fine before?
  • What are the changes on the system before you encounter the issue?
  • Besides disabling XTUOCDriverService, what other troubleshooting steps you have performed?
Earl E.
Earl_Intel
Hi vcheruk3,
Earl E.
Earl_Intel
Hi vcheruk3,
Earl E.
