Ich habe ein PC bei Mifcom gekauft, der eine Geschwindigkeit von 5300 GHz anzeigt.
Ich möchte ihn aber auf die normale GHz Taktung haben und das sollte 3,40 sein.
Nur weiß ich nicht, wie ich das machen soll.
Mainboard: ASUS TUF B660M-Plus Wi-Fi
CPU: Intel Core 7 13700KF
There is nothing you need to do. The base clock is automatically at 3.4GHz and only boost to levels above this via the Intel Turbo Boost capability of the processor. For more information on the Intel Turbo Boost capability, consult,
What is Intel Turbo Boost Technology and How Does it Work?
My Intel Core Processor Does Not Reach the Maximum Turbo Boost Frequency
Frequently Asked Questions for Intel Turbo Boost Technology
Frequently Asked Questions About Temperature for Intel Processors
If your goal is to disable Intel Turbo Boost, this is normally supported from the motherboard's BIOS Setup utility.
Hope this helps,
Hope this helps,
Vielen Dank für die schnelle Antwort, ich habe den Turbo Boost deaktiviert und habe jetzt die 3,4 GHz.
If your clock speed idles ok and is not stuck at full speed all the time then I would leave it like it is.
Changing the turbo is pretty easy, just follow a guide or look through the motherboard manual you should have got with your PC.
If it is stuck at full speed all the time then we have the same issue.
Does your cpu run at 5.3ghz all the time ?
