Programmable Devices
20678 Discussions
ALT_INBUF_DIFF and Pin Planner
I'm new to the Quatus Env and hitting a snag when implementing the ALT_INBUF_DIFF.
Top-level I have a LVDS sync_pulse_p and a sync_pulse_n going to the ALT_INBUF_DIFF primitive.
sync_buffer : alt_inbuf_diff
generic map
io_standard => "lvds",
enable_bus_hold => "off",
weak_pull_up_resistor => "off"
port map
i => sync_pulse_p,
ibar => sync_pulse_n,
o => sync_pulse
My issues is associated with the Pin Planner. When I set the sync_pulse_p to LVDS in the I/O Standard, it creates a sync_pulse_p(n) signal. If I remove the sync_pulse_n and add sync_pulse_p(n) to the top-level vhdl, I get an error during complilation. What am I missing?
why use the ALT_INBUF_DIFF at all? just port sync_pulse to the top level and give it an LVDS I/O Standard in Pin Planner or Assignment Editor
Okay, but could you explain how to implement this?
For example:
top.vhdl will have th signal:
sync_pulse
Pin Planner will have I/O Standard LVDS for the sync_pulse & sync_pulse(n).
What will the final sync_pulse signal be called in the top vhdl file?
sync_pulse??
right, just have sync_pulse ported all the way to the top level. in Pin Planner, once you assign it an LVDS I/O standard, the complimentary (n) pin will be created and automatically assigned to the pair where you assigned the p pin. the rest is done by the tool
Thanks! It worked.
How should I deal with an output? I was thinking about using the ALT_OUTBUF_DIFF.
it should work just the same for outputs
