Hi everyone,
I have 2 Always blocks, but one of them does not run. Can you help me make it run?
always
begin
// Code runs
end
always
begin
// Code does not run
end
Maybe defining sensitivity list may help you out:
always@(*)- Mark as New
Which block I defined sensitivity list, it does not run. :confused:
you are using the "always" block in a wrong way.
Always blocks will be evaluated by Modelsim according to Verilog rules. Because you didn't post any actual code, we could only guess about the specific problem. But this isn't a riddle forum.
For the time being, I want to suggest the classical Cummings paper that addresses many problems around always blocks. http://csg.csail.mit.edu/6.375/6_375_2007_www/papers/cummings-nonblocking-snug99.pdf
