Programmable Devices
20713 Discussions
Arria JESD spanning 2 Transceiver Banks
David32
I must connect a number of quad ADC devices with either 2, 3, or 4 JESD to the FPGA.
The number of lanes in the interface will affect the effective bits in the conversion (either 8 or 9) and of course the lane bit rate.
Since a bank in the FPGA consists of 6 transceiver channels, I would like to know what limitations exist such as:
1. Using 3 2-lane JESD interfaces in a single bank, is it possible?
2. Using JESD 4-lane interfaces, however, this would sometimes mean using 2 channels from one bank and 2 channels from the other (is it possible)?
skbeh
Hi David
Please see the inline reply below:
>> Both cases mentioned above are possible.
The link below has a JESD204B example design for Arria 10 with two x8 Lanes JESD204B (Duplex) IP Cores that could be useful for your reference.
https://www.intel.com/content/www/us/en/design-example/715135/arria-10-two-x8-lanes-jesd204b-duplex-ip-cores-multi-device-synchronization-reference-design-using-nios-ii-processor.html
Soon
skbeh
Hi David
Soon
David32
Thanks for your reply
