I work for a university and we have to deploy to a gang of share computers Cyclone V. I have no knowledge of this Prime software, what it does, and how it does it. But, because I know PowerShell I have been tasked to find a way to deploy these devices remotely.
As I've found thus far, the device installer looks to only come in a GUI form. If anyone knows a CLI method, I would be grateful.
Thanks in advance
check quartus_sh -qinstall feature.
Thanks for the information. It lead me into a good direction. I was able to discover the dev_install.exe has somewhat of a command line option that can me viewed with the --help option.
However, it does not appear to have the option to select and install the .qdz files.
My goal is to add Cyclone V to the device family unattended on many of out lab workstations.
This does not work.
dev_install.exe --unattendedmodeui none --mode unattended --downloaddir c:\intelFPGA_lite\23.1std\quartus\common\devinfo\dev_install --accept_eula 1
Usually when using the GUI, if the .qdz file is in the same location as the installer, the default is that it will install that device. Are you saying you have the .qdz file available in that location and it's not getting installed?
May I know if the issue has been resolved and if you still need help with this case?
Richard Tan
Do you need any further assistance from my side?
Richard Tan
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you for reaching out to us!
Richard Tan
