Programmable Devices
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
20581 Discussions
E-Tile Hard IP for Ethernet pin placement
yairs
Hi.
I am trying to build a 100GE Interface for a stratix10 tx device(1st280ey2f55i2lg). I have compiled successfully the example design, but I do not know how to change the location of the e-tile in order to match it to my board. The example design uses :
set_location_assignment PIN_REFCLK_GXER9C_CH1P -to i_clk_ref
set_location_assignment PIN_GXER9C_TX_CH0P -to o_tx_serial[0]
set_location_assignment PIN_GXER9C_TX_CH1P -to o_tx_serial[1]
set_location_assignment PIN_GXER9C_TX_CH2P -to o_tx_serial[2]
set_location_assignment PIN_GXER9C_TX_CH3P -to o_tx_serial[3]
set_location_assignment PIN_GXER9C_RX_CH0P -to i_rx_serial[0]
set_location_assignment PIN_GXER9C_RX_CH1P -to i_rx_serial[1]
set_location_assignment PIN_GXER9C_RX_CH2P -to i_rx_serial[2]
set_location_assignment PIN_GXER9C_RX_CH3P -to i_rx_serial[3]
and when I try to change it to any other tile, I am getting a fitter error. I couldn't find what are the restrictions for the e-tile selection. Please help.
yair shapira
ZiYing_Intel
Hi yair,
It was the wrong pin assignment issue. You put 2 different signal in the same pin because you already
set_location_assignment PIN_REFCLK_GXER9C_CH1P -to i_clk_ref. For further information about E-tile hard IP, you may refer to link below https://www.intel.com/content/www/us/en/docs/programmable/683468/21-1/introduction.html
Since your issue has been resolved, I am now close the case. If you happen another issue after the case closed, please do feel free to submit another issue. There will have people reach out to you.
zying
ZiYing_Intel
Hi yair shapira,
May I know that you try change to which tile?
zying
yairs
Sure. Thanks for your help.
I tried (among other options that I do not remember ..) To move to tile 8B channels 0 - 3.
Yair,
ZiYing_Intel
Hi yairs,
Can you share the .qar file? So that I can try debug the issue from my side.
zying
yairs
Hi.
Here it is.
Yair
ZiYing_Intel
Hi Yairs,
Can you try achieve the project again? because the file that you share to me corrupted and don't have the .qsf and .qpf file inside it.
zying
yairs
Hi.
I Archived again.
I am attaching the qsf and qpf also separately , just in case...
yair shapira
ZiYing_Intel
Hi yairs,
I have a look and tried your .qar file from my side. It was the pin assignment issue. I made some changes on the pin assignment and it was compiled successfully from my side.
yairs
Thanks a lot , Now it compiles.
I saw that you made a change in one of the TBI Clocks placement. Could you please elaborate (or refer me to some document) , what is the usage of the TBI Clocks and what are their pin placement rules.
I am going to try to add at least one more 100GE ETILE IP, and probably some 10GE Interfaces in the future.
Thanks for all your help
yair
ZiYing_Intel
Hi yair,
zying
