20777 Discussions
Flash Memory VHDL. Write Duration. JEDEC.
I am using a flash memory amd29lv320d. It is CFI compliant. I designed a code for write, read and erase the flash in VHDL.
For read and erase I have what I expected (talking in terms of duration), but when I need to write it takes too long time.
For write 320000 bytes it takes more than 4 hours, but the datasheet says that the "Chip program time" is maximum 72 sec.
The reason is that the signal flash ready takes a long time to be asserted.
Does anybody have had some trouble similar?
Thank you.
I decided to attach some image of the signals that I am generating from VHDL, maybe someone has already designed a driver for a Flash and can see something strange.
It is a standard FLASH, CFI jedec.
You can see the signal I_busy is the flag RY/BY that comes from the flash but takes too long time to be asserted.
Any sugerence will be apreciated.
Thank you.:cool:
Just if somebody has the same trouble in the future.
I found the trouble. I had forgoten the pull up resistor in the RY/BY pin.
I used the pin assignment tool for add a weak pull up resistor .
Bye.
