20736 Discussions
How to get rid of warnings?
Hi everybody,
Is there any site or document which deals with warnings messages and how to get rid of them?
I got such types of warnings
*Info: Pin "y[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
and
* Info: Pin ssd_7[0] has VCC driving its datain port
and
*The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
and
* Pin "ssd_7[0]" stuck at VCC
With regards
You can solve these problems by following the recommendations - so e.g. specify and output capacity
Or, you can setup error suppression in the Synthesis Tab, but providing the code of the error to suppress. Also you can right click on an error to set it to "off".
Thank you fpgaengineerfrankfurt (http://alteraforum.org/forum/member.php?u=1331) for your answer,
What I need actually is to resolve the source of the warning and not to ignore it.
for example how colud I specify an o/p load capacitance?
--- Quote Start ---
--- Quote End ---
Goto Assignments > Device > Device and Pin Options > Capacitive Loading and fill out the table accordingly.
--- Quote Start ---
--- Quote End ---
This is in the same Device and Pin Options but under Unused Pins and Reserve all unused pins.
ssd_7[0] must have some logic that sticks it high, is this desired behavior?
I really appreciate your cooperation.
Your answers were very helpful to me.
