Hi everyone.
I have 2 question about NIOS II file read/write, and download to pc. 1. I found below writing from altera forum to use fopen & fclose function. associated system library -> system library properties -> software component -> add this software component check but, Nios II BSP properties doesn't have "software component" option, so I didn't find "add this software component" check box. Where can I find that? 2. I want to get some data from FPGA Kit to my pc, "txt" file type. I saw that the best easy way is to use JTAG Uart. but, I have never used Jtag Uart.. Where can I find JTAG Uart instruction about NIOS II? Thanks in advance.Link Copied
Hi Teddy,
a good start could be the Embedded Peripherals IP User Guide Chapter 5: http://www.altera.com/literature/ug/ug_embedded_ip.pdf From here you can get to several informations about sopc, software and handling of the JTAG uart core.
