Hi all,
I access to epcs controller as mtd under Linux/uClinux. To update program file, i use .rbf but i need to do a byte-reverse before writing it to the EPCS16 someone has a program to do it? ThanksLink Copied
great
I will try it right now :) thank you very much- Mark as New
what version of python you use?
ActiveState Active Python 2.4
it works thank you :)
