It seems none of the options for extracting the drivers are valid anymore.
I have downloaded the installer from https://www.intel.com/content/www/us/en/download/19512/intel-rapid-storage-technology-driver-installation-software-with-intel-optane-memory-10th-and-11th-gen-platforms.html and tried the following:
SetupRST.exe -extract <path>
SetupRST.exe -a -p <path>
But neither works. Does anyone know how to do it with the most recent version, or if an F6 floppy archive still exists?
Thanks!
Serag is a lifesaver....I couldn't get to the install/extract option of this file because it wouldn't even let me in because it said unsupported platform....I created an account just to say thank you, I was clueless.
Serag,
I just had to make an account on intel plataform to thank you for the link
I also created an account just to say thanks. Huge help, I have been struggling with this for a while.
how to extract intel or non inet rst to usb
I had the same issue, and ended up going down a rabbit hole with Procmon to find where the exe extracted the files.
I then actually went back and checked the documentation, turns out that the extract function is listed in the README, however it does not show up when you run the /? flag.
Extract driver files from SetupRST.exe: - Open terminal in the directory with SetupRST.exe by right-clicking the directory and selecting "Open in Terminal" or "Open PowerShell here" - Enter the following command: ./SetupRST.exe -extractdrivers SetupRST_extracted
Hopefully this helps someone new visiting the post, no discredit to the person who shared the extracted files previously - I'm always a little cautious downloading drivers for untrusted sources.
Cheers,
Ayden
