Hello, Im trying to resolve some errors inside device manager. Im showing an error under storage controllers labeled as "Intel RST VMD Controller A77F" and under the properties is says:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Windows cannot verify the digital signature for this file. The signing certificate for this file has been revoked.
also
Showing an Error Under Human Interface Devices Labeled as "Intel(R) Quick SPI Host Controller- 7A50" and under the properties of that :
This device cannot start. (Code 10)
STATUS_DEVICE_POWER_FAILURE
Hi Just4555,
Thank you for posting in our Intel communities.
Apologies for the delay on my response. Please share more details about the issue:
I would like to know if you're using RAID configuration on your PC.
Was this working before or a newly integrated system?
Did you do recent changes with the system?
Have you performed other troubleshooting steps?
Did you remove or modify any drivers on your system?
Dean R.
Hi Just4555,
Dean R.
