Rapid Storage Technology
Intel® RST, RAID
2063 Discussions
Why do I have 16 icons for RST on my task bar??
CBeat
AlHill
Download, run, and attach (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
n_scott_pearson
The additional icons are typically the result of alerts being displayed. What happens if you reboot. Do the extra icons go away?
CBeat
Yes the icons go away and there are none. Shortly thereafter all16 begin to appear one at a time in sequence. I get no notifications that something is wrong. I can open the application with any one of them and it shows everything functioning normally.
Charlie
CBeat
I just had an idea. I had RST set for a delayed start. That turns out be the issue. When I reset it to start on boot up the issue no longer happens.
Interesting,
Charlie
n_scott_pearson
You can't (or at least shouldn't) delay the start of a service that is providing storage access.
