Server Products
4800 Discussions
ɴᴅᴀ Request for accessing advandced cooling configuration on Intel Wolf Pass
Koray
1 of my client requested me to reconfigure his R208WFTZSR so it can work above 22℃ (room temperature without cooling in terms of energy consumption) which is above the maximal 15℃ temperature specified by the manual. This requires more performant cooling and thus requires reconfiguring the system. I created Ticket ID №05701131 and support told me the document containing the details requires Intel Premier Access and signing an NDA and that I should post the request here.
Hope to get an answer before the ticket is closed…
Labels (3)
Allan_A_Intel
Hello, Koray,
Thank you for reaching Intel Communities. However, these forums are not the place to ask for access to confidential documentation. In the link they provided you will need to request for access and to apply for a Corporate Non-Disclosure Agreement (CNDA).
If possible, please double check in the case that you mentioned so the Intel agent verify properly the steps you need to follow to be granted with the access you need.
Allan
Koray
But I received this from Customer support :
Then what did they meaned ?
