Buenas gente...
Las siguientes consultas .....
El procesador Intel® Xeon® Silver 4410Y Processor soporta memorias de 32-GB (1x32GB) Dual Rank x8 DDR5-5600??
Y si hay alguna lista de memorias adecuadas para este procesador ?...
Gracias
The image below is an extract from the Intel specification for this processor
Speeds above 4000 will be dependant on the motherboard, check the board manufacturer's support website for that information. There should also be a QVL list of compatible memory modules from the same source.
Hello Nanofer,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Server Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Hello Nanofer,
Thank you for reaching out to Intel Community Support!
First and foremost, please be informed that we do not have Spanish language support on our community threads, and we will only support you in English.
The Intel® Xeon® Silver 4410Y Processor is part of the 4th Gen Intel® Xeon® Scalable Processors and you can check for it`s memory specifications in the following link: https://www.intel.com/content/www/us/en/products/sku/232376/intel-xeon-silver-4410y-processor-30m-cache-2-00-ghz/specifications.html
According to the provided documents the Supported Memory Configurations are as follows:
- Memory Speed and Configuration:
- The Intel® Xeon® Silver 4410Y Processor supports DDR5 memory up to 4000 MT/s for both 1 DPC (DIMM per Channel) and 2 DPC configurations.
- Quote: "Up to DDR5-4000 MT/s (1DPC) Up to 4400 MT/s (2DPC)"
- Source: 2 Socket Workstation vs 1 Socket Workstation Guide – 4th Gen Xeon® Scalable vs Intel® Xeon® W Processors, Page: 6
- Memory Capacity:
- The processor supports up to 4 TB of DDR5 memory.
- Source: EV-QS Sapphire Rapids Server Products Product Family – Q1VN - Dear Customer Letter (DCL), Page: 2
Based on the provided Intel documentation, the Intel® Xeon® Silver 4410Y Processor does not support DDR5-5600 memory speeds. It supports up to DDR5-4000 MT/s for 1 DPC and 2 DPC configurations. Therefore, the 32-GB (1x32GB) Dual Rank x8 DDR5-5600 memory is not supported by this processor.
We do not have a compatibility list for memory supported but you can reach out to your IT vendor to provide a list of DIMMs that is compatible with the specifications below.
1. Memory: DDR5 Technology Support DDR5 ECC RDIMM :- 3DS DDR5 ECC RDIMM
2. Memory: Speeds2 (Up to) :- 4400, 4800
3. Memory: Number of IMC per socket :- 4
4. Memory: Channels per IMC (Up to) :- 2
5. Memory: Max DIMM per Channel (Up to) :- 2
6. Memory: Max DIMMs per Socket :- 16
7. Memory: Max Logical Ranks / DDR5 Channel :- RDIMM – 4 / 3DS RDIMM - 16
8. Memory: DRAM Density :- 16,24,32 Gb
9. Memory: Max Capacity (x16 256GB 16Gb 3DS DDR5) per Socket :- 4 TB
10. Memory: Max Capacity (x8 256 GB 16 Gb 3DS DDR5) and (x8 512 GB Intel® Optane™ Persistent Memory 300 Series mapped as memory) per Socket :- 6 TB Note: Requires a SKU which supports Intel® Optane™ Persistent Memory 300 Series
We hope our clarification is sufficient, if there any further clarification needed, please do let us know and we will assist you accordingly.
Thank You & Best Regards,
Ragulan_Intel
Hello Nanofer,
Hope this message finds you well.
This is a gentle follow up on this thread, we would appreciate if you can let us know whether the information shared was sufficient. If yes, we would like to obtain your approval to archive this thread.
Ragulan_Intel
Hello Nanofer,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
You may receive an invitation to take a survey in a few days. We value your feedback and look forward to hearing about your support experience.
Ragulan_Intel
