I'm trying to get remote management working on an older SE7520BD2V server board with the Advanced Edition IMM module installed.
The IMM is configured and working properly as I can go to the configured IP in a browser and get the basic management options. I can also retrieve information from this system from a remote system with command-line IPMI tool.
However, I'm unable to connect from Intel Server Manager (ISM) 8.50. I can discover the IMM IP but when I try to connect, it complains with "Invalid IPMI BMC credentials. Please type in the correct user name and password."
I'm wondering if this could be because I'm running from Win7-64?
If not, what else can I try?
I tried to install the newer Multi Server Manager, but that requires IPMI/BMC on the system from which it's run. I only have ASF on this workstation board. Is there another Intel server management package that's newer than MSM?
Brad
Did you try to setup another BMC user, besides the default anonymous user?
