Server Products
4784 Discussions
S5520H RAID 5 Drive is Bad
JDost
I have an Intel server with a S5520HC server board running in a RAID 5 which consists of three, 1TB Seagate enterprise drives. The server is exactly 3 years old. It is extremely slow. When I check the system logs it shows that I have a bad drive (see below). When I run the RAID web console program it can't discover any hosts so I can't find out which physical drive is bad. How can I determine which physical drive is bad and is there a way to get the RAID web console to discover the server?
Our best recommendation is running the Intel System Information Retrieval Utility (sysinfo) For UEFI and sending the logs to your local support group for further assistance:
https://downloadcenter.intel.com/download/19657/Intel-System-Information-Retrieval-Utility-sysinfo-For-UEFI Download Intel System Information Retrieval Utility (sysinfo) For UEFI
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
JDost
UPDATE: Here is the error message from the system log.
Log Name: System
Source: disk
Date: 10/18/2013 6:12:31 AM
Event ID: 7
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: STEARNSSVR.jfstearns.local
Description:
The device, \Device\Harddisk0\DR0, has a bad block.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event">
7
2
0
0x80000000000000
1605368
System
server.domain..local
030080000100000000000000070004C0000100009C0000C0000000000000000000C076AB5D010000CECC8B0000000000FFFFFFFF010000005800008402020000ED200A124207204000200000410000000060000000000000A032494280FAFFFF0000000000000000600C032280FAFFFF000000000000000060BBD5AE000000002800AED5BB6000001000000000000000700003000000000B00000000000000000000000000000000
jwdost,
There's a couple ways to install RAID Web Console 2. Checkout the http://www.intel.com/support/motherboards/server/sb/CS-022358.htm RAID Software User Guide in Chapter 8 to see if you can find any installation issues.
John
BPres1
Our theory is that the bad block is in the logical drive, not the physical drive. We have done the chkdsk and found no errors. We have seen this same error on a set of mirrors drives using RAID 1. We first replaced drive 0 of the pair, it was rebuilt but the error continued. So we moved the drive taken from drive 0 and installed it as Drive 1. Once it was rebuilt, the error continued.
AP16
Valued Contributor III
Windows writes event about bad block in two cases: in case the verify read returns different from what should be written (applicable only for certain operations) and in case that system cannot complete read at all. You are likely faced with RAID 5 'write hole' trouble, when because of wrong data or parity chunk controller takes a lot of time in hopeless data block reconstruction. The solution is a full backup and full array recreation.
About RAID Web Console: check that its system service is running and allowed in Windows Firewall.
