hi,
I encoutner a blocking issue when enabling wq of DSA in in ubuntu2404 of SRP EE server. could any expert give some help?
thanks a lot!!!
root@npg-l2-1uspree-01:~# accel-config enable-wq dsa0/wq0.0
failed in dsa0/wq0.0
enabled 0 wq(s) out of 1
Error[0x80110000] dsa0/wq0.0: Unknown error
root@npg-l2-1uspree-01:~# dmesg | grep idxd
[ 8.738647] idxd 0000:f6:01.0: Unable to turn on user SVA feature.
[ 8.814550] idxd 0000:f6:01.0: Intel(R) Accelerator Device (v100)
here is the kernel version:
root@npg-l2-1uspree-01:~# cat /proc/version
Linux version 6.8.1-1002-realtime (buildd@lcy02-amd64-007) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #2-Ubuntu SMP PREEMPT_RT Tue May 21 21:13:36 UTC 2024
here is the OS version
root@npg-l2-1uspree-01:~# cat /etc/os-release
PRETTY_NAME="Ubuntu 24.04 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
Other DMA devices
0000:f6:01.0 'Device 0b25' unused=idxd,igb_uio,vfio-pci
Hi Liheng,
Greetings from Intel.
Hope you are doing well.
Could you please let us know the current firmware versions.
So that we can look into it and proceed further accordingly.
Mohammed Ali
Hello Liheng,
Thank you for contacting Intel.
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action we provided.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Ali
Intel Customer Support
Hello lihengzh,
Greetings!
Kindly provide us the below system details so that we can check this further.
1) The motherboard details that you are using ( model name )
2) The processor details
Also you can refer the below guide on troubleshooting this issue :
An issue with using Data Streaming Accelerator. When trying to test Intel® Data Streaming Accelerator executing dsa-perf-micros and the accel-config test, an error output is show:
$ ./scripts/setup_dsa.sh configs/4e1w-d.conf" in dsa-perf-micros gives this error:
disabled dsa0
enabled 1 device(s) out of 1
We need to analyze the information from DSA and Linux commands together and look for inconsistencies or missing elements related to VT-d and PRICtl functionalities.
Kernel Boot Parameters:
Run grep -i vtd /etc/default/grub and grep -i vtx /etc/default/grub
Look for options like intel_vtd.active=off or intel_vtd_cmt_mode=off that might disable VT-d functionalities.
VT-d Status:
Run grep -i vtd /proc/cpuinfo and grep -i vtx /proc/cpuinfo
Look for entries like "VT-d: active" or "VT-d: disabled" to confirm VT-d activation.
Driver Status:
Run dmesg | grep -i prictl or journalctl | grep -i prictl
Look for any error messages or information about PRICtl driver loading or initialization issues. If VT-d is disabled, investigate the cause through BIOS settings or kernel boot parameters.
On the BIOS settings, please make sure the following options are correct:
enabled "Opt-Out Illegal MSI Mitigation", enabled "PRS Capability for PCIe" and disabled "Limit CPU PA to 46 bits".
Please also consult with the system or motherboard documentation for specific BIOS settings related to VT-d and VT-x and make sure no additional config is needed on BIOS level.
On the Intel® Data Streaming Accelerator User Guide Page 15, there is a description about checking the DSA on the OS:
Run lspci -vvv -s 6a:01.0
The output should be like the following:
Capabilities: [220 v1] Address Translation Service (ATS)
ATSCap: Invalidate Queue Depth: 00
ATSCtl: Enable+, Smallest Translation Unit: 00
Run dmesg | grep -i idxd if you see “Unable to turn on SVA feature”, VT-d scalable mode may not be enabled by default, reboot with “intel_iommu=on,sm_on” added to the kernel command line to enable VT-d scalable mode.
Run dmesg | grep idxd
Received: Unable to turn on SVA
Add this grub config command in /etc/default/grub file:
GRUB_CMDLINE_LINUX_DEFAULT="intel_iommu=on,sm_on iommu=on"
Run update-grub
Reboot the system.
If the commands above do not show the issue, please collect OS Logs, output from the commands described on this article so that we can check this further.
Intel data streaming accelerator user guide : https://www.intel.com/content/www/us/en/content-details/759709/intel-data-streaming-accelerator-user-guide.html?DocID=759709
You can also refer to our resource and documentation center to find more information regarding this. Please note that you need an NDA to access the RDC premier account.
RDC link : https://www.intel.com/content/www/us/en/resources-documentation/developer.html#gs.5k1ay6
How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Account:
So we request you to kindly provide the system details requested and also try out the troubleshooting guide shared to see if it resolves the issue.
Sachin KS
Thank you very much for the great help!
I didn’t find more useful info with the following 13 commands, please feel free to let me know if you want to know info or traces.
- lscpu
- modinfo idxd
- modinfo vfio
- modinfo vfio-pci
- cat /proc/cmdline
- grep -i vtd /etc/default/grub
- grep -i vtx /etc/default/grub
- grep -i vtd /proc/cpuinfo
- grep -i vtx /proc/cpuinfo
- dmesg | grep -i prictl
- journalctl | grep -i prictl
- dmesg | grep idxd
- lspci -vvv -s f6:01.0
Here it the detailed info:
root@npg-l2-1uspree-01:~# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 46 bits physical, 57 bits virtual
Byte Order: Little Endian
CPU(s): 64
On-line CPU(s) list: 0-63
Vendor ID: GenuineIntel
BIOS Vendor ID: Intel
Model name: Intel(R) Xeon(R) Gold 6433N
BIOS Model name: Intel(R) Xeon(R) Gold 6433N CPU @ 1.4GHz
BIOS CPU family: 179
CPU family: 6
Model: 143
Thread(s) per core: 2
Core(s) per socket: 32
Socket(s): 1
Stepping: 8
CPU(s) scaling MHz: 69%
CPU max MHz: 3600.0000
CPU min MHz: 800.0000
BogoMIPS: 2800.00
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm
pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid
aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dc
a sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fa
ult epb cat_l3 cat_l2 cdp_l3 cdp_l2 ssbd mba ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad
fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflusho
pt clwb intel_pt avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_tot
al cqm_mbm_local split_lock_detect user_shstk avx_vnni avx512_bf16 wbnoinvd dtherm ida arat pln pts hfi vnmi avx512
vbmi umip pku ospke waitpkg avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg tme avx512_vpopcntdq la57 r
dpid bus_lock_detect cldemote movdiri movdir64b enqcmd fsrm md_clear serialize tsxldtrk pconfig arch_lbr ibt avx512
_fp16 flush_l1d arch_capabilities
Virtualization features:
Virtualization: VT-x
Caches (sum of all):
L1d: 1.5 MiB (32 instances)
L1i: 1 MiB (32 instances)
L2: 64 MiB (32 instances)
L3: 60 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-63
Vulnerabilities:
Gather data sampling: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Reg file data sampling: Not affected
Retbleed: Not affected
Spec rstack overflow: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS; IBPB conditional; RSB filling; PBRSB-eIBRS SW sequence; BHI BHI_DIS_S
Srbds: Not affected
Tsx async abort: Not affected
root@npg-l2-1uspree-01:~# modinfo idxd
filename: /lib/modules/6.8.1-1002-realtime/kernel/drivers/dma/idxd/idxd.ko.zst
import_ns: IDXD
author: Intel Corporation
license: GPL v2
version: 1.00
srcversion: 23680C20EC237C4A2D5D095
alias: pci:v00008086d00000CFEsv*sd*bc*sc*i*
alias: pci:v00008086d00000B25sv*sd*bc*sc*i*
depends: idxd_bus
retpoline: Y
intree: Y
vermagic: 6.8.1-1002-realtime SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 0E:B3:06:BA:A8:77:54:C7:BE:FE:3C:2C:A6:8C:47:19:47:29:65:3A
sig_hashalgo: sha512
signature: 97:73:5E:81:DF:45:FE:8E:8C:74:75:9C:7B:A3:A5:6F:77:B9:65:D9:
85:7E:2D:3B:26:B8:44:5B:D6:E9:B6:AC:4C:15:AB:7A:CF:05:7A:69:
B1:20:0E:63:84:12:2D:B5:3B:1E:D4:E5:D4:6A:9A:B6:E0:4E:5B:7E:
AD:15:48:FD:81:31:CE:9A:03:BA:F2:85:0B:E1:D4:FC:D2:47:4C:AC:
E1:0F:EE:4C:48:DC:46:0B:8E:F8:88:7A:6E:C0:BC:51:0F:4B:DE:1A:
90:66:94:94:01:C2:E8:33:60:92:17:EF:E1:6B:9E:58:14:86:78:A4:
44:83:20:0F:79:C2:05:94:F7:F3:FA:5E:A0:12:92:CE:70:65:B1:5A:
B1:26:61:97:11:C1:5A:7D:60:37:02:37:7D:54:EB:DC:F0:1C:12:67:
F0:B9:D0:93:54:A2:78:7D:8E:88:E4:58:96:CF:70:03:C0:72:31:B5:
BA:BC:A7:87:F4:FD:91:36:DE:41:69:78:9C:EF:45:38:E0:68:C7:B4:
86:78:61:2B:F1:A8:5C:4F:F2:0B:97:C0:C1:53:54:61:DA:93:7F:73:
36:EE:BD:91:26:16:C7:FA:69:21:BA:17:11:65:D7:07:64:FC:45:E6:
16:AA:BB:C6:83:EA:78:74:02:7E:A1:7A:9B:04:D8:F0:E3:D2:B8:E9:
27:7F:63:B8:11:30:0B:34:B7:8E:75:35:06:74:3A:25:E7:35:0D:3F:
99:E9:34:9D:51:9F:86:A6:7F:BB:0D:2F:E1:27:EE:B3:88:5C:BD:D9:
7E:79:49:8D:E2:38:75:B4:98:69:C5:20:54:38:EC:D5:21:B4:E8:C7:
99:0D:90:8C:15:A7:05:EA:B5:4D:DD:40:44:83:4A:98:D9:16:1D:F4:
F4:61:A1:E5:27:A8:91:CA:53:D7:D8:D9:AD:89:CB:09:A5:4D:39:71:
FF:F5:99:97:27:10:A6:A1:37:E6:DF:83:7A:9F:E4:B5:01:C9:58:63:
4B:3A:01:4A:2F:3C:43:B2:2E:14:27:32:FF:8D:43:84:8D:72:E9:7B:
1F:FF:43:66:01:A6:8B:40:A8:1E:11:B6:EF:FC:8D:B2:43:48:C5:16:
46:65:7C:05:CE:66:81:48:CC:B5:A1:7C:67:C4:69:62:81:1F:A7:C2:
CB:65:E6:A9:36:F9:60:37:A8:08:F3:AE:B5:63:6F:E1:D9:4F:BF:B3:
77:22:3D:D0:BF:77:99:08:17:22:C5:7C:49:24:ED:AF:30:41:E6:BC:
02:B2:D0:2E:B9:22:7E:4E:8D:70:4B:2F:E8:49:28:93:CB:E0:56:70:
D6:6A:66:C7:C3:69:36:83:5B:80:83:B4
parm: sva:Toggle SVA support on/off (bool)
parm: tc_override:Override traffic class defaults (bool)
root@npg-l2-1uspree-01:~# modinfo vfio
filename: /lib/modules/6.8.1-1002-realtime/kernel/drivers/vfio/vfio.ko.zst
softdep: post: vfio_iommu_type1 vfio_iommu_spapr_tce
description: VFIO - User Level meta-driver
author: Alex Williamson alex.williamson@redhat.com
license: GPL v2
version: 0.3
import_ns: IOMMUFD
alias: devname:vfio/vfio
alias: char-major-10-196
import_ns: IOMMUFD_VFIO
import_ns: IOMMUFD
srcversion: 71E8940B20D02E0F6F5D499
depends: iommufd
retpoline: Y
intree: Y
sig_id: PKCS#7
signature: 2C:99:F2:F9:4D:20:4E:F4:0D:74:1C:B2:A1:CD:34:DF:3E:0A:83:39:
0F:B5:53:DC:0E:84:50:9A:37:D6:32:7F:13:83:3A:CB:7D:08:8F:86:
D3:B1:16:73:43:61:BF:B7:47:1E:8C:58:B4:22:48:56:57:3C:E7:81:
F0:C4:CF:6C:9F:CF:06:2E:C2:60:86:96:2F:E4:3F:55:FF:81:DD:6E:
16:C9:8C:BA:CE:8E:46:9C:75:F6:81:3D:17:F2:C1:64:53:06:5E:3D:
B4:1C:51:71:C5:DB:83:D7:8D:FD:6C:02:94:92:8C:84:44:53:15:2A:
F0:A2:48:9B:96:B3:6B:55:5C:0D:95:1A:32:36:2F:74:3A:0E:03:A9:
4D:29:CD:EA:F0:B6:3D:D6:8C:B3:6F:14:40:4B:A0:A6:4D:B8:F5:38:
9B:DA:15:8C:E5:55:21:24:93:11:59:21:6A:A5:7D:61:23:8D:F8:CF:
F2:D1:C8:3A:D1:C6:75:7F:36:34:ED:1B:B8:E6:C4:4F:1A:B1:0E:35:
29:F7:39:E2:97:45:50:D4:3C:3F:63:56:03:7A:01:53:5C:D8:53:CF:
D8:DC:3C:CF:5C:A9:83:C1:95:60:86:7D:BA:41:27:11:E0:BA:9A:08:
42:E0:03:EC:44:63:5D:EB:D4:E6:84:4C:10:59:0A:E9:9B:AB:3C:4A:
30:06:24:02:1B:3B:3A:C2:8D:66:85:F8:1A:F4:05:E0:AF:A3:51:CF:
A3:ED:73:41:3E:28:F2:2F:DA:4A:91:4A:68:90:58:E7:D9:21:D7:AF:
C5:5A:8A:A1:79:E4:79:A9:1C:A5:43:85:DA:33:2F:C5:5E:02:3A:AC:
09:04:FA:E1:5A:C2:3D:C6:C9:83:05:D8:F1:44:4D:5D:06:CD:AA:F3:
3A:B9:79:F7:BA:71:5C:EE:7C:25:4D:C1:F2:55:CA:24:B8:36:E2:FE:
48:E3:29:35:45:0C:4B:D0:98:3C:45:2E:20:6F:41:0E:06:08:02:08:
01:97:DF:DF:AF:2B:C1:42:02:76:EB:B4:A0:6F:EB:1A:B4:FF:8B:52:
36:D2:04:F8:EB:72:48:A6:D6:B4:19:50:99:16:4A:36:95:C6:4E:1C:
00:3A:16:52:09:49:FF:35:C1:E7:CA:E1:8D:84:FE:24:E5:D8:B4:7D:
38:F7:07:83:85:FF:B9:29:4F:45:7C:56:C0:22:99:3C:B2:59:49:7A:
85:66:75:0C:C1:69:02:2B:85:01:58:12:E7:D0:10:E2:8B:7E:0A:1C:
6E:9B:4A:AD:7F:32:B6:1F:C8:5C:3E:A2:B7:E6:FA:A6:D1:65:A4:DA:
C6:91:73:70:A8:CD:2D:B9:53:C9:D6:49
parm: enable_unsafe_noiommu_mode:Enable UNSAFE, no-IOMMU mode. This mode provides no device isolation, no DMA translation, no host kernel protection, cannot be used for device assignment to virtual machines, requires RAWIO permissions, and will taint the kernel. If you do not know what this is for, step away. (default: false) (bool)
root@npg-l2-1uspree-01:~# modinfo vfio-pci
filename: /lib/modules/6.8.1-1002-realtime/kernel/drivers/vfio/pci/vfio-pci.ko.zst
description: VFIO PCI - User Level meta-driver
license: GPL v2
srcversion: 2961A59104CE4DB12621164
alias: vfio_pci:v*d*sv*sd*bc*sc*i*
depends: vfio-pci-core,vfio
retpoline: Y
intree: Y
sig_id: PKCS#7
signature: 63:15:9B:7D:A0:D1:49:1A:46:CF:47:BB:66:73:AB:62:09:74:06:BC:
03:96:F5:90:C7:B2:04:AB:75:4A:16:A6:98:DB:52:D0:5C:CF:A7:02:
8E:29:5E:5B:E5:47:C5:67:05:92:62:C0:79:88:03:A6:0A:58:10:29:
09:7C:6F:44:4C:30:29:97:E7:0A:AB:35:17:BE:4D:32:47:AF:47:61:
E5:AE:42:18:BC:E4:C2:FD:7B:C5:6C:1D:D7:0B:A0:A1:21:C5:91:99:
2E:B9:E7:08:0C:27:0A:87:19:BC:D2:93:0C:2F:34:A2:EB:E7:3D:FE:
03:4E:FB:EC:9A:C0:51:22:AD:41:48:72:BD:0D:27:63:9D:A6:7A:EC:
D2:1B:64:69:1E:C7:6E:38:54:17:34:16:72:2D:E4:1C:6C:39:B7:E9:
10:78:97:A8:19:A6:FE:E4:47:D4:A4:96:CA:62:40:01:59:EE:AD:82:
60:AB:2F:13:E0:97:37:E7:C4:21:77:73:B0:6C:8B:B1:47:F0:23:75:
79:C1:AA:6A:FA:58:4D:28:9E:FE:08:74:48:7C:69:1D:5C:D3:5D:B8:
53:2B:0D:B3:F6:5C:26:FE:50:7A:5C:69:D8:15:E0:ED:E3:B2:B0:25:
3C:E1:27:62:6C:F1:71:06:F1:82:62:F7:72:CC:1E:FC:B6:C1:56:E6:
F6:F6:F3:D7:2A:9C:3A:F2:99:17:FF:C0:3C:27:40:B7:58:15:34:B3:
02:D6:A0:7A:4B:5F:71:3C:BF:22:62:BD:3F:66:C0:55:79:E7:56:50:
EB:AC:64:2C:71:70:88:BA:5C:97:32:15:CD:30:F2:53:13:A3:AF:5B:
FB:0C:B8:30:B0:13:2F:EB:74:67:8C:71:43:23:C3:91:51:46:FE:92:
EE:3A:F4:6F:87:DB:67:1E:D4:F8:F3:51:2D:25:95:3E:8F:19:0C:12:
6E:6F:18:F2:C0:25:2B:7A:A8:E4:37:DB:C6:39:9F:D6:9C:C8:B4:AC:
38:B6:50:A8:33:30:34:BF:A1:39:8E:89:E2:C2:92:4B:50:F3:3F:D3:
96:86:E5:73:61:BB:B7:96:CF:2E:34:73:88:7B:81:F3:F0:C7:FF:EA:
0B:8B:15:F4:F2:48:E6:7A:02:E3:A1:A6:AD:97:91:2C:C1:92:39:27:
81:A0:9C:0E:05:B7:51:38:54:D0:15:34:2E:28:E1:CB:7E:4E:82:FB:
F1:FD:6A:87:0D:7C:0E:00:DF:BF:E7:1C:B9:6C:47:9F:FF:D0:CB:E7:
60:37:D7:B0:69:6F:05:7A:83:66:7D:9D:95:A2:26:D3:5F:6F:63:58:
54:97:DB:DE:69:3E:6B:34:D9:24:52:06
parm: ids:Initial PCI IDs to add to the vfio driver, format is "vendor:device[:subvendor[:subdevice[:class[:class_mask]]]]" and multiple comma separated entries can be specified (string)
parm: nointxmask:Disable support for PCI 2.3 style INTx masking. If this resolves problems for specific devices, report lspci -vvvxxx to linux-pci@vger.kernel.org so the device can be fixed automatically via the broken_intx_masking flag. (bool)
parm: disable_vga:Disable VGA resource access through vfio-pci (bool)
parm: disable_idle_d3:Disable using the PCI D3 low power state for idle, unused devices (bool)
parm: enable_sriov:Enable support for SR-IOV configuration. Enabling SR-IOV on a PF typically requires support of the userspace PF driver, enabling VFs without such support may result in non-functional VFs or PF. (bool)
parm: disable_denylist:Disable use of device denylist. Disabling the denylist allows binding to devices with known errata that may lead to exploitable stability or security issues when accessed by untrusted users. (bool)
root@npg-l2-1uspree-01:~# cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-6.8.1-1002-realtime root=/dev/mapper/ubuntu--vg--00-ubuntu--lv ro intel_iommu=on,sm_on iommu=on vfio_pci.enable_sriov=1 vfio_pci.disable_idle_d3=1 usbcore.autosuspend=-1 selinux=0 enforcing=0 nmi_watchdog=0 crashkernel=auto softlockup_panic=0 audit=0 mce=off hugepagesz=1G hugepages=50 hugepagesz=2M hugepages=0 default_hugepagesz=1G kthread_cpus=0 irqaffinity=0,31,32,63 rcu_nocb_poll nohz=on skew_tick=1 skew_tick=1 tsc=reliable rcupdate.rcu_normal_after_boot=1 isolcpus=managed_irq,domain,1-30,33-62 nohz_full=1-30,33-62 rcu_nocbs=1-30,33-62 nosoftlockup tsc=nowatchdog
root@npg-l2-1uspree-01:~# grep -i vtd /etc/default/grub
root@npg-l2-1uspree-01:~# grep -i vtx /etc/default/grub
root@npg-l2-1uspree-01:~# grep -i vtd /proc/cpuinfo
root@npg-l2-1uspree-01:~# grep -i vtx /proc/cpuinfo
root@npg-l2-1uspree-01:~# dmesg | grep -i prictl
root@npg-l2-1uspree-01:~# journalctl | grep -i prictl
[ 7.356870] idxd 0000:f6:01.0: Unable to turn on user SVA feature.
[ 7.522017] idxd 0000:f6:01.0: Intel(R) Accelerator Device (v100)
root@npg-l2-1uspree-01:~# lspci -vvv -s f6:01.0
f6:01.0 System peripheral: Intel Corporation Device 0b25
Subsystem: Intel Corporation Device 0000
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
IOMMU group: 1
Region 0: Memory at 26fffff20000 (64-bit, prefetchable) [size=64K]
Region 2: Memory at 26fffff00000 (64-bit, prefetchable) [size=128K]
Capabilities: [40] Express (v2) Root Complex Integrated Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0
ExtTag+ RBE+ FLReset+
DevCtl: CorrErr- NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 512 bytes, MaxReadReq 4096 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp+ 10BitTagReq+ OBFF Not Supported, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+ LTR- 10BitTagReq+ OBFF Disabled,
AtomicOpsCtl: ReqEn-
Capabilities: [80] MSI-X: Enable+ Count=9 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [90] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP- SDES- TLP+ FCP- CmpltTO+ CmpltAbrt+ UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [150 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [160 v1] Transaction Processing Hints
Device specific mode supported
Steering table in TPH capability structure
Capabilities: [170 v1] Virtual Channel
Caps: LPEVC=1 RefClk=100ns PATEntryBits=1
Arb: Fixed+ WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=fd
Status: NegoPending- InProgress-
VC1: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Ctrl: Enable+ ID=1 ArbSelect=Fixed TC/VC=02
Capabilities: [200 v1] Designated Vendor-Specific: Vendor=8086 ID=0005 Rev=0 Len=24 <?>
Capabilities: [230 v1] Process Address Space ID (PASID)
PASIDCap: Exec- Priv+, Max PASID Width: 14
PASIDCtl: Enable+ Exec- Priv+
Capabilities: [240 v1] Page Request Interface (PRI)
PRICtl: Enable- Reset-
PRISta: RF- UPRGI- Stopped+
Page Request Capacity: 00000200, Page Request Allocation: 00000200
Kernel driver in use: idxd
Kernel modules: idxd
Hi MACM,
Greetings!
Thanks for the update. Kindly allow us some time to check on this and we will keep you posted once there is an update.
Ragulan_Intel
Hi lihengzh
Please find the information below.
1 – Could you please test using the Ubuntu 22.10 version? I have reached out to the BU and the expert oriented to first test using distribution 22.10
2 – Can you go over the commands?
Double-check: BIOS:- EDKII -> Socket Configuration -> IIO Configuration -> Intel VT for Directed I/O (VT-d)
Option: No -> Yes
Install ubuntu 21.10
vi /etc/default/grub
GRUB_CMDLINE_LINUX="iommu=pt intel_iommu=on,sm_on idxd.dyndbg idxd.legacy_cdev_load=1 modprobe.blacklist=idxd_uacce"
Check and verify driver loaded
lsmod | grep dxd
idxd 98304 0
idxd_bus 20480 1 idxd
Dmesg | grep dxd
Verify idxd driver loaded properly
download
https://github.com/intel/idxd-config/archive/refs/tags/accel-config-v3.4.4.zip
apt-get update
apt install build-essential
apt install autoconf automake autotools-dev libtool pkgconf asciidoc xmlto
apt install automake
apt install autotools-dev
apt install libtools
apt install libtool
apt install pkgconf
apt install uuid-dev libjson-c-dev libkeyutils-dev
cd idxd-config-accel-config-v3.4.4
./configure CFLAGS='-g -O2' --prefix=/usr --sysconfdir=/etc --libdir=/usr/lib64 --disable-docs --enable-test=yes
make
make check
make install
cd idxd-config-accel-config-v3.4.4/test/configs
cp 2g2q_user_1.conf dedicated_2g2q_user_1.conf
sed -i.bak 's/"mode":"shared"/"mode":"dedicated"/g' dedicated_2g2q_user_1.conf
sed -i.bak 's/"threshold":15/"threshold":0/g' dedicated_2g2q_user_1.conf
reboot
# accel-config load-config -c configs/dedicated_2g2q_user_1.conf
# accel-config enable-device dsa0
enabled 1 wq(s) out of 1
# accel-config enable-wq dsa0/wq0.1
./dsa_test -w 0 -f 0x0 -v
./dsa_test -w 0 -l 4096 -o 0x3 -f 0x0 t200 -v
./dsa_test -w 0 -l 2097152 -o 0x3 -f 0x0 t200 -v
./dsa_test -w 0 -l 1073741824 -o 0x3 -f 0x0 t200 -v
Passed if no error reported
Ali
Hi lihengzh
Hope you are doing great.
After some research and testing, based on other cases that are showing the same behavior:
1 - The hardware CPU ( Intel(R) Xeon(R) Gold 6433N) is showing the DSA device present on the system per message: (“idxd 0000:f6:01.0: Intel(R) Accelerator Device (v100)”. There are no issues with the hardware.
2 - Need to go over the Kernel and drivers for DSA to make sure all is installed correctly on the OS, following Intel® Data Streaming Accelerator User Guide. Make sure to be using the supported OS described in the Guide: SUSE Linux Enterprise Server SLES 15 SP4 / Redhat Enterprise Linux RHEL 8.7 & 9.1 / Ubuntu Ubuntu 22.10 (page 15). We do not provide OS support, please contact the OS vendor.
3 - We suggest the Kernel to be used should be higher than 6.6 as contains all drivers needed.
4 - We suggest the following troubleshooting:
a – Could you please test using the Ubuntu 22.10 version? I have reached out to the BU and the expert oriented to first test using distribution 22.10
b – Can you go over the commands?
Option: No -> Yes
lsmod | grep dxd
idxd 98304 0
Dmesg | grep dxd
download
apt-get update
apt install libtool
apt install pkgconf
make
make check
make install
reboot
For more details about OS driver enablement, please check with the OS vendor.
Best Regard,
Ali
Hello lihengzh
Ali
Hello lihengzh,
This is the second follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Please feel free to respond to this email at your earliest convenience.
Ali
Hello lihengzh,
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Mohammed Ali CM
