cancel
Showing results for
Search instead for
Did you mean:
Does SSD 525/530/730 support Read Verify?
STetu
New Contributor
We are using Read Verify to recover our storage systems when error occurs. We tested this function both on S3700 and 525 by sending Write Uncorrectable EXT command to the devices, S3700 was able to return error correctly as a response to Read Verify command, but 525 did not return error when receiving Read Verify.
We also read the specification of SSD 525, but could not find the description of Read Verify support.
Please advise if SSD 525/530/730 supports Read Verify.
Thanks in advance.
5 REPLIES 5
Jose_H_Intel1
Valued Contributor II
Intel® SSD 525, Intel® SSD 530 and Intel® SSD 730 do not support Read Verify.
I am sorry for any inconvenience this may cause.
