cancel
Showing results for
Search instead for
Did you mean:
Fresh W7 install showing 49gb of used space on a 160gb G2
Esteemed Contributor III
So after completing a fresh install of Windows 7 Ultimate, I checked the used space of my new Intel G2 160gb SSD and was shocked to see 49gb was used up. Nothing else is on the drive aside from a new windows installation and no other drives are attached to my system at this time. This is my second clean install (after doing a secure erase) since I assumed I did something wrong the first time. I made sure everything was in order and I'm still getting a ridiculous amount of space being taken up.
I ran the SSD optimizer and still nothing changed. Is this a common issue? Perhaps Windows is reading the drive incorrectly? Could there be a logical reason for this? It's puzzling...
6 REPLIES 6
Strange. The Windows folder does get larger over time, but with a fresh install it should be around 8GB.
The Windows folder gets larger over time primarily due to the winsxs folder. Currently mine is 6.68GB
Why not use something like FolderSizes to find where the problem is? http://www.foldersizes.com/features/ http://www.foldersizes.com/features/
Do you have quite a bit of system memory by chance? A large page file & large hibernation file?
RGiff
Contributor
Your partitations must be way off.
Ozz was right, it's less do with the ssd, and more to do with my 24gb of system memory.
When I went to check the hidden files and folders and I found these files:
hiberfil.sys - 17.9gbpagefile.sys - 23.9gb
The hiberfil.sys file has to do with hibernation, and I'm not sure why it's so big, but I'm going to get rid of it.
The pagefile.sys handles virtual memory and the size is usually about 1.5 times the size of the installed memory, which would account for the size. I am wondering if I could or should change the size of it.
