cancel
Showing results for
Search instead for
Did you mean:
p3600 on ASUS P9D WS Motherboard.
CBrac2
New Contributor
Hi, I'm trying to install p3600 on ASUS P9D WS Motherboard. The device fits into a PCIe slot just fine and during motherboard startup, I can see the LED's on the SSD flash yellow (for activity) and then green for health. However, shortly thereafter the motherboard basically resets. Without the P3600 inserted, the computer starts up just fine. Any ideas? Do I need an updated bios on the motherboard? Thanks!
15 REPLIES 15
CBrac2
New Contributor
Well done, ClementChong!
I applied your suggested technique, the computer booted, and with Linux kernel 3.13.0, the device was found and am currently "dd"'ing the drive. I used a two dollar roll of electrical tape found at Home Depot.
Have you found any performance impact with this configuration?
PS. For those trivia-minded reading along, this is the first, and perhaps only time, I have used the swiss army knife tweezer or toothpick, and remarkably, at the same time! So, they are useful apparently.
