Since doing a fresh install of WIndows 10 Anniversary update, I can't connect to corporate WLAN which uses Cisco PEAP as it's network authentication method. After installing the latest Proset and drivers for WIndows 10 64bit, this is no longer an option like it used to be on the first version of Windows 10.
Any ideas, why this isn't installing the Cisco PEAP driver extension?
WIfi card : Dual band wireless AC-7260
Driver Version : 18.33.3.2
Attachment shows that Cisco PEAP isn't an option.
- Tags:
- Cisco
iBROX,
The Intel Dual Band Wireless-AC 7260 complies with the latest security standards currently available on the market. The way security protocols are handled will depend on the OS when using Intel® PROset/Wireless Software. However, Cisco* PEAP was jointly developed by Cisco* Systems, Microsoft* and RSA* Security.
If this situation occurred after Windows®10 Anniversary Update, we recommend also to engage Microsoft* and/or Cisco* for additional support. Please check the links below:
Cisco - http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1200-series/prod_qas0900aecd801764fa.html Protected EAP (PEAP) Application Note
Cisco - http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1200-series/prod_qas0900aecd801764fa.html Cisco Protected Extensible Authentication Protocol
Microsoft - https://technet.microsoft.com/en-us/itpro/surface/enable-peap-eap-fast-and-cisco-leap-on-surface-devices Enable PEAP, EAP-FAST, and Cisco LEAP on Surface devices
In order to help with this, you are welcome to try a custom installation. This link provides the step-by-step for this time installation:http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005564.html Updated Installation Process for Intel® PROSet/Wireless Software
If you are an IT administrator, this link: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000017246.html IT Administrator Links for Intel® PROSet/Wireless Software may contain information that might help you as well.
Let us know if this helped you.
Aleki
iBROX,
Aleki
Thank you Aleki, the following link has fixed my problem :
I installed the CiscoEapPeap_all_components package and now the PEAP option appears in the wifi settings and I can connect to my enterprise/corporate wifi now . Anniversary edition perhaps breaks this by the looks of it, but i'm happy now
Thanks for your help.
