Wireless
7499 Discussions
Intel Wifi 6E AX210 is not working on ubuntu 22.04
yasun95
Hi
I'm experiencing issues with the wireless connection on my desktop after installing Ubuntu 22.04.[I have a ROG STRIX Z370-E GAMING WIFI 2(main board), intel Wifi 6E AX210(wireless module).]
Here's the output from my terminal:
1. uname -srm
Linux 6.5.0-27-generic x86_64
2. lspci
00:00.0 Host bridge: Intel Corporation Device a700 (rev 01)
00:01.0 PCI bridge: Intel Corporation Device a70d (rev 01)
00:01.1 PCI bridge: Intel Corporation Device a72d (rev 01)
00:02.0 VGA compatible controller: Intel Corporation Device a780 (rev 04)
00:0a.0 Signal processing controller: Intel Corporation Device a77d (rev 01)
00:0e.0 RAID bus controller: Intel Corporation Device a77f
00:14.0 USB controller: Intel Corporation Device 7a60 (rev 11)
00:14.2 RAM memory: Intel Corporation Device 7a27 (rev 11)
00:15.0 Serial bus controller: Intel Corporation Device 7a4c (rev 11)
00:15.1 Serial bus controller: Intel Corporation Device 7a4d (rev 11)
00:15.2 Serial bus controller: Intel Corporation Device 7a4e (rev 11)
00:16.0 Communication controller: Intel Corporation Device 7a68 (rev 11)
00:17.0 SATA controller: Intel Corporation Device 7a62 (rev 11)
00:1a.0 PCI bridge: Intel Corporation Device 7a48 (rev 11)
00:1b.0 PCI bridge: Intel Corporation Device 7a40 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Device 7a38 (rev 11)
00:1c.3 PCI bridge: Intel Corporation Device 7a3b (rev 11)
00:1d.0 PCI bridge: Intel Corporation Device 7a30 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Device 7a04 (rev 11)
00:1f.3 Audio device: Intel Corporation Device 7a50 (rev 11)
00:1f.4 SMBus: Intel Corporation Device 7a23 (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Device 7a24 (rev 11)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 2684 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 22ba (rev a1)
02:00.0 Non-Volatile memory controller: SK hynix Device 1959
05:00.0 Network controller: Intel Corporation Device 272b (rev 1a)
06:00.0 Ethernet controller: Intel Corporation Device 125c (rev 06)
3. sudo lshw -C network
*-network
description: Ethernet interface
product: Intel Corporation
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:05:00.0
logical name: wlo1
version: 1a
serial: 90:09:df:06:2c:8c
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.5.0-27-generic firmware=83.ec13314b.0 gl-c0-fm-c0-83.uc ip=192.168.0.10 latency=0 link=yes multicast=yes
resources: irq:16 memory:86700000-86703fff
*-network
physical id: 0
bus info: pci@0000:06:00.0
logical name: eno2
version: 06
serial: e8:9c:25:98:16:76
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=igc driverversion=6.5.0-27-generic duplex=full firmware=2017:888d ip=222.110.40.142 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:19 memory:86500000-865fffff memory:86600000-86603fff
4. sudo dmesg | grep iwl
[ 7.236427] iwlwifi 0000:05:00.0: enabling device (0000 -> 0002)
[ 7.240742] iwlwifi 0000:05:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[ 7.240775] iwlwifi 0000:05:00.0: PCI dev 272b/02f4, rev=0x472, rfid=0x112200
[ 7.265944] iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
[ 7.265973] iwlwifi 0000:05:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.125
[ 7.266389] iwlwifi 0000:05:00.0: loaded firmware version 83.ec13314b.0 gl-c0-fm-c0-83.ucode op_mode iwlmvm
[ 7.842628] iwlwifi 0000:05:00.0: Detected Intel(R) TBD Bz device, REV=0x472
[ 7.865388] iwlwifi 0000:05:00.0: WRT: Invalid buffer destination
[ 8.095459] iwlwifi 0000:05:00.0: loaded PNVM version 8443a58d
[ 8.197113] iwlwifi 0000:05:00.0: base HW address: 90:09:df:06:2c:8c
[ 8.286244] iwlwifi 0000:05:00.0 wlo1: renamed from wlan0
[ 8.370336] iwlwifi 0000:05:00.0: WRT: Invalid buffer destination
[ 8.709604] iwlwifi 0000:05:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
sudo dmesg | grep iwlwifi
[ 1066.282735] Invalid rxb from HW 0
[ 1066.282760] WARNING: CPU: 12 PID: 832 at drivers/net/wireless/intel/iwlwifi/pcie/rx.c:1489 iwl_pcie_rx_handle+0x3ce/0x640 [iwlwifi]
[ 1066.282808] Modules linked in: rfcomm ccm snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda intel_rapl_msr snd_hda_ext_core intel_rapl_common snd_soc_acpi_intel_match intel_uncore_frequency snd_soc_acpi intel_uncore_frequency_common soundwire_generic_allocation intel_tcc_cooling soundwire_bus x86_pkg_temp_thermal cmac algif_hash intel_powerclamp snd_soc_core iwlmvm algif_skcipher snd_compress coretemp af_alg snd_hda_codec_hdmi ac97_bus kvm_intel snd_pcm_dmaengine bnep snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi kvm snd_usb_audio snd_hda_codec snd_usbmidi_lib irqbypass snd_hda_core btusb snd_ump crct10dif_pclmul nouveau i915 btrtl snd_hwdep polyval_clmulni btbcm mac80211 snd_seq_midi mxm_wmi polyval_generic btintel snd_seq_midi_event drm_buddy drm_ttm_helper ghash_clmulni_intel btmtk libarc4 sha256_ssse3 snd_rawmidi ttm bluetooth sha1_ssse3 aesni_intel mc snd_seq
[ 1066.282881] drm_display_helper crypto_simd snd_pcm cec snd_seq_device ecdh_generic iwlwifi joydev input_leds binfmt_misc ecc mei_hdcp snd_timer rc_core mei_pxp cryptd cmdlinepart pmt_telemetry rapl nls_iso8859_1 spi_nor snd mei_me drm_kms_helper cfg80211 pmt_class intel_cstate asus_nb_wmi wmi_bmof mtd soundcore mei i2c_algo_bit intel_vsec acpi_pad acpi_tad mac_hid sch_fq_codel msr parport_pc ppdev lp drm parport efi_pstore ip_tables x_tables autofs4 hid_generic usbhid hid mfd_aaeon asus_wmi ledtrig_audio intel_lpss_pci nvme ucsi_acpi i2c_i801 spi_intel_pci sparse_keymap ahci xhci_pci intel_lpss nvme_core typec_ucsi platform_profile video crc32_pclmul igc spi_intel i2c_smbus libahci vmd xhci_pci_renesas idma64 nvme_common typec wmi pinctrl_alderlake
[ 1066.282958] CPU: 12 PID: 832 Comm: irq/189-iwlwifi Tainted: G W 6.5.0-27-generic #28~22.04.1-Ubuntu
[ 1066.282962] Hardware name: ASUS System Product Name/ROG STRIX Z790-E GAMING WIFI II, BIOS 1102 03/15/2024
[ 1066.282964] RIP: 0010:iwl_pcie_rx_handle+0x3ce/0x640 [iwlwifi]
[ 1066.283009] Code: eb 8b 43 34 83 43 30 08 83 e8 08 89 43 34 e9 70 fe ff ff 44 89 f0 89 d6 45 89 e6 41 89 c4 48 c7 c7 a8 bb d8 c0 e8 82 f5 5d ea <0f> 0b 4c 89 ff e8 e8 3b ff ff 8b 55 d4 85 d2 0f 95 c0 41 21 c6 e9
[ 1066.283012] RSP: 0018:ffffb95a003bce18 EFLAGS: 00010246
[ 1066.283016] RAX: 0000000000000000 RBX: ffff931acccb0000 RCX: 0000000000000000
[ 1066.283018] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[ 1066.283020] RBP: ffffb95a003bce78 R08: 0000000000000000 R09: 0000000000000000
[ 1066.283022] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000001001
[ 1066.283024] R13: 0000000000000001 R14: 0000000000000000 R15: ffff931ad2810028
[ 1066.283026] FS: 0000000000000000(0000) GS:ffff9339bf300000(0000) knlGS:0000000000000000
[ 1066.283029] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1066.283031] CR2: 000000c0001d3010 CR3: 0000001a1ec3a000 CR4: 0000000000750ee0
[ 1066.283034] PKRU: 55555554
[ 1066.283035] Call Trace:
[ 1066.283037] <IRQ>
[ 1066.283038] ? show_regs+0x6d/0x80
[ 1066.283047] ? __warn+0x89/0x160
[ 1066.283052] ? iwl_pcie_rx_handle+0x3ce/0x640 [iwlwifi]
[ 1066.283096] ? report_bug+0x17e/0x1b0
[ 1066.283103] ? handle_bug+0x46/0x90
[ 1066.283107] ? exc_invalid_op+0x18/0x80
[ 1066.283112] ? asm_exc_invalid_op+0x1b/0x20
[ 1066.283118] ? iwl_pcie_rx_handle+0x3ce/0x640 [iwlwifi]
[ 1066.283160] ? iwl_pcie_rx_handle+0x3ce/0x640 [iwlwifi]
[ 1066.283203] ? enqueue_task+0x53/0x1a0
[ 1066.283209] iwl_pcie_napi_poll_msix+0x32/0x100 [iwlwifi]
[ 1066.283276] __napi_poll+0x30/0x1f0
[ 1066.283282] net_rx_action+0x181/0x2e0
[ 1066.283288] ? __irq_wake_thread+0x42/0x50
[ 1066.283294] __do_softirq+0xd9/0x349
[ 1066.283302] ? __pfx_irq_thread_fn+0x10/0x10
[ 1066.283307] do_softirq.part.0+0x41/0x80
[ 1066.283315] </IRQ>
[ 1066.283316] <TASK>
[ 1066.283318] __local_bh_enable_ip+0x72/0x80
[ 1066.283325] iwl_pcie_irq_rx_msix_handler+0xd7/0x1a0 [iwlwifi]
[ 1066.283373] irq_thread_fn+0x21/0x70
[ 1066.283379] irq_thread+0xf8/0x1c0
[ 1066.283385] ? __pfx_irq_thread_dtor+0x10/0x10
[ 1066.283391] ? __pfx_irq_thread+0x10/0x10
[ 1066.283397] kthread+0xef/0x120
[ 1066.283405] ? __pfx_kthread+0x10/0x10
[ 1066.283411] ret_from_fork+0x44/0x70
[ 1066.283419] ? __pfx_kthread+0x10/0x10
[ 1066.283425] ret_from_fork_asm+0x1b/0x30
[ 1066.283431] </TASK>
[ 1066.283432] ---[ end trace 0000000000000000 ]---
[ 1066.284166] iwlwifi 0000:05:00.0: Microcode SW error detected. Restarting 0x0.
[ 1066.284298] iwlwifi 0000:05:00.0: Start IWL Error Log Dump:
[ 1066.284302] iwlwifi 0000:05:00.0: Transport status: 0x0000004A, valid: 6
[ 1066.284307] iwlwifi 0000:05:00.0: Loaded firmware version: 83.ec13314b.0 gl-c0-fm-c0-83.ucode
[ 1066.284311] iwlwifi 0000:05:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 1066.284315] iwlwifi 0000:05:00.0: 0x000002F0 | trm_hw_status0
[ 1066.284318] iwlwifi 0000:05:00.0: 0x00000000 | trm_hw_status1
[ 1066.284321] iwlwifi 0000:05:00.0: 0x002C280A | branchlink2
[ 1066.284324] iwlwifi 0000:05:00.0: 0x002C1AC6 | interruptlink1
[ 1066.284327] iwlwifi 0000:05:00.0: 0x002C1AC6 | interruptlink2
[ 1066.284329] iwlwifi 0000:05:00.0: 0x00015BF2 | data1
[ 1066.284332] iwlwifi 0000:05:00.0: 0x01000000 | data2
[ 1066.284334] iwlwifi 0000:05:00.0: 0x00000000 | data3
[ 1066.284337] iwlwifi 0000:05:00.0: 0x9D818420 | beacon time
[ 1066.284340] iwlwifi 0000:05:00.0: 0xDFB3ABE8 | tsf low
[ 1066.284342] iwlwifi 0000:05:00.0: 0x00000A9E | tsf hi
[ 1066.284345] iwlwifi 0000:05:00.0: 0x00000000 | time gp1
[ 1066.284348] iwlwifi 0000:05:00.0: 0x1CDD8912 | time gp2
[ 1066.284350] iwlwifi 0000:05:00.0: 0x00000001 | uCode revision type
[ 1066.284353] iwlwifi 0000:05:00.0: 0x00000053 | uCode version major
[ 1066.284355] iwlwifi 0000:05:00.0: 0xEC13314B | uCode version minor
[ 1066.284358] iwlwifi 0000:05:00.0: 0x00000472 | hw version
[ 1066.284360] iwlwifi 0000:05:00.0: 0x18C80002 | board version
[ 1066.284363] iwlwifi 0000:05:00.0: 0x80ECF400 | hcmd
[ 1066.284366] iwlwifi 0000:05:00.0: 0x00020000 | isr0
[ 1066.284368] iwlwifi 0000:05:00.0: 0x08000000 | isr1
[ 1066.284371] iwlwifi 0000:05:00.0: 0x48F04002 | isr2
[ 1066.284373] iwlwifi 0000:05:00.0: 0x04C0000C | isr3
[ 1066.284375] iwlwifi 0000:05:00.0: 0x00000000 | isr4
[ 1066.284378] iwlwifi 0000:05:00.0: 0x0185001C | last cmd Id
[ 1066.284380] iwlwifi 0000:05:00.0: 0x00015BF2 | wait_event
[ 1066.284383] iwlwifi 0000:05:00.0: 0x00000000 | l2p_control
[ 1066.284386] iwlwifi 0000:05:00.0: 0x00000000 | l2p_duration
[ 1066.284388] iwlwifi 0000:05:00.0: 0x003C0000 | l2p_mhvalid
[ 1066.284391] iwlwifi 0000:05:00.0: 0x00000007 | l2p_addr_match
[ 1066.284393] iwlwifi 0000:05:00.0: 0x00000028 | lmpm_pmg_sel
[ 1066.284396] iwlwifi 0000:05:00.0: 0x00000000 | timestamp
[ 1066.284398] iwlwifi 0000:05:00.0: 0x0000F83C | flow_handler
[ 1066.284502] iwlwifi 0000:05:00.0: Start IWL Error Log Dump:
[ 1066.284504] iwlwifi 0000:05:00.0: Transport status: 0x0000004A, valid: 6
[ 1066.284507] iwlwifi 0000:05:00.0: Loaded firmware version: 83.ec13314b.0 gl-c0-fm-c0-83.ucode
[ 1066.284510] iwlwifi 0000:05:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 1066.284513] iwlwifi 0000:05:00.0: 0x000002F0 | trm_hw_status0
[ 1066.284516] iwlwifi 0000:05:00.0: 0x00000000 | trm_hw_status1
[ 1066.284519] iwlwifi 0000:05:00.0: 0x002C280A | branchlink2
[ 1066.284521] iwlwifi 0000:05:00.0: 0x002C1AC2 | interruptlink1
[ 1066.284524] iwlwifi 0000:05:00.0: 0x002C1AC2 | interruptlink2
[ 1066.284526] iwlwifi 0000:05:00.0: 0x002A50FC | data1
[ 1066.284529] iwlwifi 0000:05:00.0: 0x01000000 | data2
[ 1066.284531] iwlwifi 0000:05:00.0: 0x00000000 | data3
[ 1066.284533] iwlwifi 0000:05:00.0: 0x9D818420 | beacon time
[ 1066.284536] iwlwifi 0000:05:00.0: 0xDFB3ABE8 | tsf low
[ 1066.284539] iwlwifi 0000:05:00.0: 0x00000A9E | tsf hi
[ 1066.284541] iwlwifi 0000:05:00.0: 0x00000000 | time gp1
[ 1066.284544] iwlwifi 0000:05:00.0: 0x1CDD8912 | time gp2
[ 1066.284546] iwlwifi 0000:05:00.0: 0x00000001 | uCode revision type
[ 1066.284549] iwlwifi 0000:05:00.0: 0x00000053 | uCode version major
[ 1066.284551] iwlwifi 0000:05:00.0: 0xEC13314B | uCode version minor
[ 1066.284554] iwlwifi 0000:05:00.0: 0x00000472 | hw version
[ 1066.284556] iwlwifi 0000:05:00.0: 0x18C80002 | board version
[ 1066.284559] iwlwifi 0000:05:00.0: 0x80E9FC10 | hcmd
[ 1066.284561] iwlwifi 0000:05:00.0: 0x00020000 | isr0
[ 1066.284564] iwlwifi 0000:05:00.0: 0x08000000 | isr1
[ 1066.284566] iwlwifi 0000:05:00.0: 0x48F04002 | isr2
[ 1066.284569] iwlwifi 0000:05:00.0: 0x04C0000C | isr3
[ 1066.284571] iwlwifi 0000:05:00.0: 0x00000000 | isr4
[ 1066.284573] iwlwifi 0000:05:00.0: 0x00000000 | last cmd Id
[ 1066.284576] iwlwifi 0000:05:00.0: 0x002A50FC | wait_event
[ 1066.284579] iwlwifi 0000:05:00.0: 0x00000000 | l2p_control
[ 1066.284581] iwlwifi 0000:05:00.0: 0x00000000 | l2p_duration
[ 1066.284583] iwlwifi 0000:05:00.0: 0x003C0000 | l2p_mhvalid
[ 1066.284586] iwlwifi 0000:05:00.0: 0x00000007 | l2p_addr_match
[ 1066.284589] iwlwifi 0000:05:00.0: 0x00000028 | lmpm_pmg_sel
[ 1066.284591] iwlwifi 0000:05:00.0: 0x00000000 | timestamp
[ 1066.284594] iwlwifi 0000:05:00.0: 0x0000F83C | flow_handler
[ 1066.284647] iwlwifi 0000:05:00.0: Start IWL Error Log Dump:
[ 1066.284650] iwlwifi 0000:05:00.0: Transport status: 0x0000004A, valid: 7
[ 1066.284652] iwlwifi 0000:05:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 1066.284655] iwlwifi 0000:05:00.0: 0x00000000 | umac branchlink1
[ 1066.284658] iwlwifi 0000:05:00.0: 0xC00809B0 | umac branchlink2
[ 1066.284661] iwlwifi 0000:05:00.0: 0x8026DAA8 | umac interruptlink1
[ 1066.284663] iwlwifi 0000:05:00.0: 0x00000000 | umac interruptlink2
[ 1066.284666] iwlwifi 0000:05:00.0: 0x01000000 | umac data1
[ 1066.284668] iwlwifi 0000:05:00.0: 0x00000000 | umac data2
[ 1066.284671] iwlwifi 0000:05:00.0: 0x00000000 | umac data3
[ 1066.284673] iwlwifi 0000:05:00.0: 0x00000053 | umac major
[ 1066.284676] iwlwifi 0000:05:00.0: 0xEC13314B | umac minor
[ 1066.284678] iwlwifi 0000:05:00.0: 0x1CDD8906 | frame pointer
[ 1066.284681] iwlwifi 0000:05:00.0: 0xD00D6198 | stack pointer
[ 1066.284683] iwlwifi 0000:05:00.0: 0x00FD019C | last host cmd
[ 1066.284686] iwlwifi 0000:05:00.0: 0x00000400 | isr status reg
[ 1066.284751] iwlwifi 0000:05:00.0: TCM1 status:
[ 1066.284754] iwlwifi 0000:05:00.0: 0x00000070 | error ID
[ 1066.284757] iwlwifi 0000:05:00.0: 0x0000184E | tcm branchlink2
[ 1066.284759] iwlwifi 0000:05:00.0: 0x00001C44 | tcm interruptlink1
[ 1066.284762] iwlwifi 0000:05:00.0: 0x00001C44 | tcm interruptlink2
[ 1066.284765] iwlwifi 0000:05:00.0: 0x40000000 | tcm data1
[ 1066.284767] iwlwifi 0000:05:00.0: 0xDEADBEEF | tcm data2
[ 1066.284769] iwlwifi 0000:05:00.0: 0xDEADBEEF | tcm data3
[ 1066.284772] iwlwifi 0000:05:00.0: 0x000018AC | tcm log PC
[ 1066.284774] iwlwifi 0000:05:00.0: 0x00803FF0 | tcm frame pointer
[ 1066.284777] iwlwifi 0000:05:00.0: 0x00803F4C | tcm stack pointer
[ 1066.284780] iwlwifi 0000:05:00.0: 0x00000000 | tcm msg ID
[ 1066.284782] iwlwifi 0000:05:00.0: 0x40000000 | tcm ISR status
[ 1066.284785] iwlwifi 0000:05:00.0: 0x000002F0 | tcm HW status[0]
[ 1066.284788] iwlwifi 0000:05:00.0: 0x00000000 | tcm HW status[1]
[ 1066.284790] iwlwifi 0000:05:00.0: 0x00000000 | tcm HW status[2]
[ 1066.284793] iwlwifi 0000:05:00.0: 0x00008100 | tcm HW status[3]
[ 1066.284796] iwlwifi 0000:05:00.0: 0x00000000 | tcm HW status[4]
[ 1066.284798] iwlwifi 0000:05:00.0: 0x00000000 | tcm SW status[0]
[ 1066.284864] iwlwifi 0000:05:00.0: RCM1 status:
[ 1066.284867] iwlwifi 0000:05:00.0: 0x00000070 | error ID
[ 1066.284870] iwlwifi 0000:05:00.0: 0x00001B9E | rcm branchlink2
[ 1066.284872] iwlwifi 0000:05:00.0: 0x00002178 | rcm interruptlink1
[ 1066.284875] iwlwifi 0000:05:00.0: 0x00002178 | rcm interruptlink2
[ 1066.284877] iwlwifi 0000:05:00.0: 0x20000000 | rcm data1
[ 1066.284880] iwlwifi 0000:05:00.0: 0xDEADBEEF | rcm data2
[ 1066.284882] iwlwifi 0000:05:00.0: 0xDEADBEEF | rcm data3
[ 1066.284885] iwlwifi 0000:05:00.0: 0x00001C00 | rcm log PC
[ 1066.284887] iwlwifi 0000:05:00.0: 0x00803FF0 | rcm frame pointer
[ 1066.284890] iwlwifi 0000:05:00.0: 0x00803F4C | rcm stack pointer
[ 1066.284893] iwlwifi 0000:05:00.0: 0x00000000 | rcm msg ID
[ 1066.284895] iwlwifi 0000:05:00.0: 0x20000000 | rcm ISR status
[ 1066.284898] iwlwifi 0000:05:00.0: 0x00020400 | frame HW status
[ 1066.284900] iwlwifi 0000:05:00.0: 0x00000000 | LMAC-to-RCM request mbox
[ 1066.284903] iwlwifi 0000:05:00.0: 0x00000000 | RCM-to-LMAC request mbox
[ 1066.284906] iwlwifi 0000:05:00.0: 0x00000000 | MAC header control
[ 1066.284909] iwlwifi 0000:05:00.0: 0x00000000 | MAC header addr1 low
[ 1066.284911] iwlwifi 0000:05:00.0: 0x003C0000 | MAC header info
[ 1066.284914] iwlwifi 0000:05:00.0: 0x00000000 | MAC header error
[ 1066.284980] iwlwifi 0000:05:00.0: TCM2 status:
[ 1066.284982] iwlwifi 0000:05:00.0: 0x00000070 | error ID
[ 1066.284985] iwlwifi 0000:05:00.0: 0x0000184E | tcm branchlink2
[ 1066.284987] iwlwifi 0000:05:00.0: 0x00001C44 | tcm interruptlink1
[ 1066.284990] iwlwifi 0000:05:00.0: 0x00001C44 | tcm interruptlink2
[ 1066.284992] iwlwifi 0000:05:00.0: 0x40000000 | tcm data1
[ 1066.284995] iwlwifi 0000:05:00.0: 0xDEADBEEF | tcm data2
[ 1066.284997] iwlwifi 0000:05:00.0: 0xDEADBEEF | tcm data3
[ 1066.285000] iwlwifi 0000:05:00.0: 0x000018AC | tcm log PC
[ 1066.285002] iwlwifi 0000:05:00.0: 0x00803FF0 | tcm frame pointer
[ 1066.285005] iwlwifi 0000:05:00.0: 0x00803F4C | tcm stack pointer
[ 1066.285007] iwlwifi 0000:05:00.0: 0x00000000 | tcm msg ID
[ 1066.285010] iwlwifi 0000:05:00.0: 0x40000000 | tcm ISR status
[ 1066.285012] iwlwifi 0000:05:00.0: 0x000002F0 | tcm HW status[0]
[ 1066.285015] iwlwifi 0000:05:00.0: 0x00000000 | tcm HW status[1]
[ 1066.285018] iwlwifi 0000:05:00.0: 0x00000000 | tcm HW status[2]
[ 1066.285020] iwlwifi 0000:05:00.0: 0x00008000 | tcm HW status[3]
[ 1066.285023] iwlwifi 0000:05:00.0: 0x00000000 | tcm HW status[4]
[ 1066.285025] iwlwifi 0000:05:00.0: 0x00000000 | tcm SW status[0]
[ 1066.285092] iwlwifi 0000:05:00.0: RCM2 status:
[ 1066.285094] iwlwifi 0000:05:00.0: 0x00000070 | error ID
[ 1066.285097] iwlwifi 0000:05:00.0: 0x00001B9E | rcm branchlink2
[ 1066.285099] iwlwifi 0000:05:00.0: 0x00002178 | rcm interruptlink1
[ 1066.285102] iwlwifi 0000:05:00.0: 0x00002178 | rcm interruptlink2
[ 1066.285104] iwlwifi 0000:05:00.0: 0x20000000 | rcm data1
[ 1066.285107] iwlwifi 0000:05:00.0: 0xDEADBEEF | rcm data2
[ 1066.285109] iwlwifi 0000:05:00.0: 0xDEADBEEF | rcm data3
[ 1066.285112] iwlwifi 0000:05:00.0: 0x00001C00 | rcm log PC
[ 1066.285114] iwlwifi 0000:05:00.0: 0x00803FF0 | rcm frame pointer
[ 1066.285117] iwlwifi 0000:05:00.0: 0x00803F4C | rcm stack pointer
[ 1066.285119] iwlwifi 0000:05:00.0: 0x00000000 | rcm msg ID
[ 1066.285122] iwlwifi 0000:05:00.0: 0x20000000 | rcm ISR status
[ 1066.285124] iwlwifi 0000:05:00.0: 0x00020400 | frame HW status
[ 1066.285127] iwlwifi 0000:05:00.0: 0x00000000 | LMAC-to-RCM request mbox
[ 1066.285129] iwlwifi 0000:05:00.0: 0x00000000 | RCM-to-LMAC request mbox
[ 1066.285132] iwlwifi 0000:05:00.0: 0x00000000 | MAC header control
[ 1066.285134] iwlwifi 0000:05:00.0: 0x00000000 | MAC header addr1 low
[ 1066.285137] iwlwifi 0000:05:00.0: 0x003C0000 | MAC header info
[ 1066.285139] iwlwifi 0000:05:00.0: 0x00000000 | MAC header error
[ 1066.285165] iwlwifi 0000:05:00.0: IML/ROM dump:
[ 1066.285167] iwlwifi 0000:05:00.0: 0x00000B03 | IML/ROM error/state
[ 1066.285184] iwlwifi 0000:05:00.0: 0x0000DF63 | IML/ROM data1
[ 1066.285201] iwlwifi 0000:05:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 1066.285213] iwlwifi 0000:05:00.0: Fseq Registers:
[ 1066.285227] iwlwifi 0000:05:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 1066.285234] iwlwifi 0000:05:00.0: 0x80B00004 | FSEQ_TOP_INIT_VERSION
[ 1066.285241] iwlwifi 0000:05:00.0: 0x00550000 | FSEQ_CNVIO_INIT_VERSION
[ 1066.285255] iwlwifi 0000:05:00.0: 0x0000AA14 | FSEQ_OTP_VERSION
[ 1066.285268] iwlwifi 0000:05:00.0: 0x0000000F | FSEQ_TOP_CONTENT_VERSION
[ 1066.285276] iwlwifi 0000:05:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 1066.285283] iwlwifi 0000:05:00.0: 0x02001910 | FSEQ_CNVI_ID
[ 1066.285290] iwlwifi 0000:05:00.0: 0x02001910 | FSEQ_CNVR_ID
[ 1066.285298] iwlwifi 0000:05:00.0: 0x02001910 | CNVI_AUX_MISC_CHIP
[ 1066.285313] iwlwifi 0000:05:00.0: 0x02001910 | CNVR_AUX_MISC_CHIP
[ 1066.285330] iwlwifi 0000:05:00.0: 0x00001041 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 1066.285347] iwlwifi 0000:05:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 1066.285361] iwlwifi 0000:05:00.0: 0x00550000 | FSEQ_PREV_CNVIO_INIT_VERSION
[ 1066.285368] iwlwifi 0000:05:00.0: 0x00B00004 | FSEQ_WIFI_FSEQ_VERSION
[ 1066.285375] iwlwifi 0000:05:00.0: 0x00B00004 | FSEQ_BT_FSEQ_VERSION
[ 1066.285389] iwlwifi 0000:05:00.0: 0x0000005F | FSEQ_CLASS_TP_VERSION
[ 1066.285404] iwlwifi 0000:05:00.0: UMAC CURRENT PC: 0x8026935a
[ 1066.285417] iwlwifi 0000:05:00.0: LMAC1 CURRENT PC: 0xd0
[ 1066.285430] iwlwifi 0000:05:00.0: LMAC2 CURRENT PC: 0xd0
[ 1066.285444] iwlwifi 0000:05:00.0: UMAC CURRENT PC 1: 0x80269358
[ 1066.285457] iwlwifi 0000:05:00.0: TCM1 CURRENT PC: 0xd0
[ 1066.285470] iwlwifi 0000:05:00.0: RCM1 CURRENT PC: 0xd0
[ 1066.285484] iwlwifi 0000:05:00.0: RCM2 CURRENT PC: 0xd0
[ 1066.285492] iwlwifi 0000:05:00.0: Function Scratch status:
[ 1066.285495] iwlwifi 0000:05:00.0: 0x01010100 | Func Scratch
[ 1066.426039] iwlwifi 0000:05:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 1066.426043] ieee80211 phy0: Hardware restart was requested
[ 1149.253191] iwlwifi 0000:05:00.0: WRT: Invalid buffer destination
[ 1149.596380] iwlwifi 0000:05:00.0: Failed to send recovery cmd blob was invalid 1
5. ls -l | grep .ucode (/lib/firmware)
drwxr-xr-x 2 root root 4096 2월 21 04:23 amd-ucode
drwxr-xr-x 2 root root 4096 2월 21 04:23 intel-ucode
-rw-r--r-- 1 root root 337572 2월 21 18:32 iwlwifi-100-5.ucode
-rw-r--r-- 1 root root 337520 2월 21 18:32 iwlwifi-1000-5.ucode
-rw-r--r-- 1 root root 689680 2월 21 18:32 iwlwifi-105-6.ucode
-rw-r--r-- 1 root root 701228 2월 21 18:32 iwlwifi-135-6.ucode
-rw-r--r-- 1 root root 695876 2월 21 18:32 iwlwifi-2000-6.ucode
-rw-r--r-- 1 root root 707392 2월 21 18:32 iwlwifi-2030-6.ucode
-rw-r--r-- 1 root root 609892 2월 21 18:32 iwlwifi-3160-10.ucode
-rw-r--r-- 1 root root 683996 2월 21 18:32 iwlwifi-3160-12.ucode
-rw-r--r-- 1 root root 688616 2월 21 18:32 iwlwifi-3160-13.ucode
-rw-r--r-- 1 root root 918212 2월 21 18:32 iwlwifi-3160-16.ucode
-rw-r--r-- 1 root root 918268 2월 21 18:32 iwlwifi-3160-17.ucode
-rw-r--r-- 1 root root 670484 2월 21 18:32 iwlwifi-3160-7.ucode
-rw-r--r-- 1 root root 667284 2월 21 18:32 iwlwifi-3160-8.ucode
-rw-r--r-- 1 root root 669872 2월 21 18:32 iwlwifi-3160-9.ucode
-rw-r--r-- 1 root root 1384856 2월 21 18:32 iwlwifi-3168-21.ucode
-rw-r--r-- 1 root root 1028092 2월 21 18:32 iwlwifi-3168-22.ucode
-rw-r--r-- 1 root root 1032436 2월 21 18:32 iwlwifi-3168-27.ucode
-rw-r--r-- 1 root root 1036288 2월 21 18:32 iwlwifi-3168-29.ucode
-rw-r--r-- 1 root root 150100 2월 21 18:32 iwlwifi-3945-2.ucode
-rw-r--r-- 1 root root 187972 2월 21 18:32 iwlwifi-4965-2.ucode
-rw-r--r-- 1 root root 340696 2월 21 18:32 iwlwifi-5000-5.ucode
-rw-r--r-- 1 root root 337400 2월 21 18:32 iwlwifi-5150-2.ucode
-rw-r--r-- 1 root root 454608 2월 21 18:32 iwlwifi-6000-4.ucode
-rw-r--r-- 1 root root 444128 2월 21 18:32 iwlwifi-6000g2a-5.ucode
-rw-r--r-- 1 root root 677296 2월 21 18:32 iwlwifi-6000g2a-6.ucode
-rw-r--r-- 1 root root 679436 2월 21 18:32 iwlwifi-6000g2b-6.ucode
-rw-r--r-- 1 root root 469780 2월 21 18:32 iwlwifi-6050-5.ucode
-rw-r--r-- 1 root root 672352 2월 21 18:32 iwlwifi-7260-10.ucode
-rw-r--r-- 1 root root 782300 2월 21 18:32 iwlwifi-7260-12.ucode
-rw-r--r-- 1 root root 786920 2월 21 18:32 iwlwifi-7260-13.ucode
-rw-r--r-- 1 root root 1049284 2월 21 18:32 iwlwifi-7260-16.ucode
-rw-r--r-- 1 root root 1049340 2월 21 18:32 iwlwifi-7260-17.ucode
-rw-r--r-- 1 root root 683236 2월 21 18:32 iwlwifi-7260-7.ucode
-rw-r--r-- 1 root root 679780 2월 21 18:32 iwlwifi-7260-8.ucode
-rw-r--r-- 1 root root 680508 2월 21 18:32 iwlwifi-7260-9.ucode
-rw-r--r-- 1 root root 736844 2월 21 18:32 iwlwifi-7265-10.ucode
-rw-r--r-- 1 root root 880604 2월 21 18:32 iwlwifi-7265-12.ucode
-rw-r--r-- 1 root root 885224 2월 21 18:32 iwlwifi-7265-13.ucode
-rw-r--r-- 1 root root 1180356 2월 21 18:32 iwlwifi-7265-16.ucode
-rw-r--r-- 1 root root 1180412 2월 21 18:32 iwlwifi-7265-17.ucode
-rw-r--r-- 1 root root 690452 2월 21 18:32 iwlwifi-7265-8.ucode
-rw-r--r-- 1 root root 697828 2월 21 18:32 iwlwifi-7265-9.ucode
lrwxrwxrwx 1 root root 21 2월 21 18:32 iwlwifi-7265D-10.ucode -> iwlwifi-7265-10.ucode
-rw-r--r-- 1 root root 1002800 2월 21 18:32 iwlwifi-7265D-12.ucode
-rw-r--r-- 1 root root 1008692 2월 21 18:32 iwlwifi-7265D-13.ucode
-rw-r--r-- 1 root root 1384500 2월 21 18:32 iwlwifi-7265D-16.ucode
-rw-r--r-- 1 root root 1383604 2월 21 18:32 iwlwifi-7265D-17.ucode
-rw-r--r-- 1 root root 1385368 2월 21 18:32 iwlwifi-7265D-21.ucode
-rw-r--r-- 1 root root 1028376 2월 21 18:32 iwlwifi-7265D-22.ucode
-rw-r--r-- 1 root root 1032740 2월 21 18:32 iwlwifi-7265D-27.ucode
-rw-r--r-- 1 root root 1036772 2월 21 18:32 iwlwifi-7265D-29.ucode
-rw-r--r-- 1 root root 1745176 2월 21 18:32 iwlwifi-8000C-13.ucode
-rw-r--r-- 1 root root 2351636 2월 21 18:32 iwlwifi-8000C-16.ucode
-rw-r--r-- 1 root root 2394060 2월 21 18:32 iwlwifi-8000C-21.ucode
-rw-r--r-- 1 root root 2120860 2월 21 18:32 iwlwifi-8000C-22.ucode
-rw-r--r-- 1 root root 2227284 2월 21 18:32 iwlwifi-8000C-27.ucode
-rw-r--r-- 1 root root 2310116 2월 21 18:32 iwlwifi-8000C-31.ucode
-rw-r--r-- 1 root root 2448976 2월 21 18:32 iwlwifi-8000C-34.ucode
-rw-r--r-- 1 root root 2428004 2월 21 18:32 iwlwifi-8000C-36.ucode
-rw-r--r-- 1 root root 2389968 2월 21 18:32 iwlwifi-8265-21.ucode
-rw-r--r-- 1 root root 1811984 2월 21 18:32 iwlwifi-8265-22.ucode
-rw-r--r-- 1 root root 2234528 2월 21 18:32 iwlwifi-8265-27.ucode
-rw-r--r-- 1 root root 2307104 2월 21 18:32 iwlwifi-8265-31.ucode
-rw-r--r-- 1 root root 2440780 2월 21 18:32 iwlwifi-8265-34.ucode
-rw-r--r-- 1 root root 2436632 2월 21 18:32 iwlwifi-8265-36.ucode
-rw-r--r-- 1 root root 2632620 2월 21 18:32 iwlwifi-9000-pu-b0-jf-b0-33.ucode
-rw-r--r-- 1 root root 2678284 2월 21 18:32 iwlwifi-9000-pu-b0-jf-b0-34.ucode
-rw-r--r-- 1 root root 2520568 2월 21 18:32 iwlwifi-9000-pu-b0-jf-b0-38.ucode
-rw-r--r-- 1 root root 2620464 2월 21 18:32 iwlwifi-9000-pu-b0-jf-b0-41.ucode
-rw-r--r-- 1 root root 2543536 2월 21 18:32 iwlwifi-9000-pu-b0-jf-b0-43.ucode
-rw-r--r-- 1 root root 1520208 2월 21 18:32 iwlwifi-9000-pu-b0-jf-b0-46.ucode
-rw-r--r-- 1 root root 2637216 2월 21 18:32 iwlwifi-9260-th-b0-jf-b0-33.ucode
-rw-r--r-- 1 root root 2678092 2월 21 18:32 iwlwifi-9260-th-b0-jf-b0-34.ucode
-rw-r--r-- 1 root root 2521412 2월 21 18:32 iwlwifi-9260-th-b0-jf-b0-38.ucode
-rw-r--r-- 1 root root 2620656 2월 21 18:32 iwlwifi-9260-th-b0-jf-b0-41.ucode
-rw-r--r-- 1 root root 2558176 2월 21 18:32 iwlwifi-9260-th-b0-jf-b0-43.ucode
-rw-r--r-- 1 root root 1491056 2월 21 18:32 iwlwifi-9260-th-b0-jf-b0-46.ucode
-rw-r--r-- 1 root root 1106228 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-48.ucode
-rw-r--r-- 1 root root 1103952 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-50.ucode
-rw-r--r-- 1 root root 1209628 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-53.ucode
-rw-r--r-- 1 root root 1223144 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-55.ucode
-rw-r--r-- 1 root root 1300764 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-59.ucode
-rw-r--r-- 1 root root 1329296 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-62.ucode
-rw-r--r-- 1 root root 1334856 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-63.ucode
-rw-r--r-- 1 root root 1344220 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-66.ucode
-rw-r--r-- 1 root root 1355836 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-68.ucode
-rw-r--r-- 1 root root 1364312 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-71.ucode
-rw-r--r-- 1 root root 1370236 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-72.ucode
-rw-r--r-- 1 root root 1369840 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-73.ucode
-rw-r--r-- 1 root root 1371532 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-74.ucode
-rw-r--r-- 1 root root 1404704 2월 21 18:32 iwlwifi-Qu-b0-hr-b0-77.ucode
-rw-r--r-- 1 root root 1052796 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-48.ucode
-rw-r--r-- 1 root root 1053004 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-50.ucode
-rw-r--r-- 1 root root 1147104 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-53.ucode
-rw-r--r-- 1 root root 1163672 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-55.ucode
-rw-r--r-- 1 root root 1226208 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-59.ucode
-rw-r--r-- 1 root root 1248672 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-62.ucode
-rw-r--r-- 1 root root 1252748 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-63.ucode
-rw-r--r-- 1 root root 1262312 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-66.ucode
-rw-r--r-- 1 root root 1275268 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-68.ucode
-rw-r--r-- 1 root root 1285192 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-71.ucode
-rw-r--r-- 1 root root 1285968 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-72.ucode
-rw-r--r-- 1 root root 1290084 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-73.ucode
-rw-r--r-- 1 root root 1290892 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-74.ucode
-rw-r--r-- 1 root root 1322436 2월 21 18:32 iwlwifi-Qu-b0-jf-b0-77.ucode
-rw-r--r-- 1 root root 1106248 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-48.ucode
-rw-r--r-- 1 root root 1103968 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-50.ucode
-rw-r--r-- 1 root root 1209644 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-53.ucode
-rw-r--r-- 1 root root 1223160 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-55.ucode
-rw-r--r-- 1 root root 1300780 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-59.ucode
-rw-r--r-- 1 root root 1329312 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-62.ucode
-rw-r--r-- 1 root root 1334872 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-63.ucode
-rw-r--r-- 1 root root 1344236 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-66.ucode
-rw-r--r-- 1 root root 1355852 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-68.ucode
-rw-r--r-- 1 root root 1364328 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-71.ucode
-rw-r--r-- 1 root root 1370252 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-72.ucode
-rw-r--r-- 1 root root 1369856 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-73.ucode
-rw-r--r-- 1 root root 1371548 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-74.ucode
-rw-r--r-- 1 root root 1404720 2월 21 18:32 iwlwifi-Qu-c0-hr-b0-77.ucode
-rw-r--r-- 1 root root 1052816 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-48.ucode
-rw-r--r-- 1 root root 1053020 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-50.ucode
-rw-r--r-- 1 root root 1147120 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-53.ucode
-rw-r--r-- 1 root root 1163688 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-55.ucode
-rw-r--r-- 1 root root 1226224 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-59.ucode
-rw-r--r-- 1 root root 1248688 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-62.ucode
-rw-r--r-- 1 root root 1252764 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-63.ucode
-rw-r--r-- 1 root root 1262328 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-66.ucode
-rw-r--r-- 1 root root 1275284 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-68.ucode
-rw-r--r-- 1 root root 1285208 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-71.ucode
-rw-r--r-- 1 root root 1285984 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-72.ucode
-rw-r--r-- 1 root root 1290100 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-73.ucode
-rw-r--r-- 1 root root 1290908 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-74.ucode
-rw-r--r-- 1 root root 1322452 2월 21 18:32 iwlwifi-Qu-c0-jf-b0-77.ucode
-rw-r--r-- 1 root root 1105668 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-48.ucode
-rw-r--r-- 1 root root 1103952 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-50.ucode
-rw-r--r-- 1 root root 1209628 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-53.ucode
-rw-r--r-- 1 root root 1223140 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-55.ucode
-rw-r--r-- 1 root root 1299660 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-59.ucode
-rw-r--r-- 1 root root 1328924 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-62.ucode
-rw-r--r-- 1 root root 1334804 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-63.ucode
-rw-r--r-- 1 root root 1344216 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-66.ucode
-rw-r--r-- 1 root root 1347524 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-67.ucode
-rw-r--r-- 1 root root 1355800 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-68.ucode
-rw-r--r-- 1 root root 1364308 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-71.ucode
-rw-r--r-- 1 root root 1370356 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-72.ucode
-rw-r--r-- 1 root root 1369976 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-73.ucode
-rw-r--r-- 1 root root 1371668 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-74.ucode
-rw-r--r-- 1 root root 1404840 2월 21 18:32 iwlwifi-QuZ-a0-hr-b0-77.ucode
-rw-r--r-- 1 root root 1052608 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-48.ucode
-rw-r--r-- 1 root root 1053004 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-50.ucode
-rw-r--r-- 1 root root 1147104 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-53.ucode
-rw-r--r-- 1 root root 1163668 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-55.ucode
-rw-r--r-- 1 root root 1226064 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-59.ucode
-rw-r--r-- 1 root root 1248672 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-62.ucode
-rw-r--r-- 1 root root 1252744 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-63.ucode
-rw-r--r-- 1 root root 1262244 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-66.ucode
-rw-r--r-- 1 root root 1275264 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-68.ucode
-rw-r--r-- 1 root root 1285188 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-71.ucode
-rw-r--r-- 1 root root 1286088 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-72.ucode
-rw-r--r-- 1 root root 1290220 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-73.ucode
-rw-r--r-- 1 root root 1290972 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-74.ucode
-rw-r--r-- 1 root root 1321956 2월 21 18:32 iwlwifi-QuZ-a0-jf-b0-77.ucode
-rw-r--r-- 1 root root 1044452 2월 21 18:32 iwlwifi-cc-a0-46.ucode
-rw-r--r-- 1 root root 1096704 2월 21 18:32 iwlwifi-cc-a0-48.ucode
-rw-r--r-- 1 root root 1101228 2월 21 18:32 iwlwifi-cc-a0-50.ucode
-rw-r--r-- 1 root root 1205332 2월 21 18:32 iwlwifi-cc-a0-53.ucode
-rw-r--r-- 1 root root 1219356 2월 21 18:32 iwlwifi-cc-a0-55.ucode
-rw-r--r-- 1 root root 1261280 2월 21 18:32 iwlwifi-cc-a0-59.ucode
-rw-r--r-- 1 root root 1292672 2월 21 18:32 iwlwifi-cc-a0-62.ucode
-rw-r--r-- 1 root root 1298688 2월 21 18:32 iwlwifi-cc-a0-63.ucode
-rw-r--r-- 1 root root 1307180 2월 21 18:32 iwlwifi-cc-a0-66.ucode
-rw-r--r-- 1 root root 1310488 2월 21 18:32 iwlwifi-cc-a0-67.ucode
-rw-r--r-- 1 root root 1314392 2월 21 18:32 iwlwifi-cc-a0-68.ucode
-rw-r--r-- 1 root root 1322288 2월 21 18:32 iwlwifi-cc-a0-71.ucode
-rw-r--r-- 1 root root 1329780 2월 21 18:32 iwlwifi-cc-a0-72.ucode
-rw-r--r-- 1 root root 1333296 2월 21 18:32 iwlwifi-cc-a0-73.ucode
-rw-r--r-- 1 root root 1334780 2월 21 18:32 iwlwifi-cc-a0-74.ucode
-rw-r--r-- 1 root root 1366144 2월 21 18:32 iwlwifi-cc-a0-77.ucode
-rw-r--r-- 1 root root 1797996 2월 21 18:32 iwlwifi-gl-c0-fm-c0-83.ucode
-rw-r--r-- 1 root root 1840116 2월 21 18:32 iwlwifi-gl-c0-fm-c0-86.ucode
-rw-r--r-- 1 root root 1753308 2월 21 18:32 iwlwifi-ma-b0-gf-a0-83.ucode
-rw-r--r-- 1 root root 1695788 2월 21 18:32 iwlwifi-ma-b0-gf-a0-86.ucode
-rw-r--r-- 1 root root 1721448 2월 21 18:32 iwlwifi-ma-b0-gf4-a0-83.ucode
-rw-r--r-- 1 root root 1670940 2월 21 18:32 iwlwifi-ma-b0-gf4-a0-86.ucode
-rw-r--r-- 1 root root 1572104 2월 21 18:32 iwlwifi-ma-b0-hr-b0-83.ucode
-rw-r--r-- 1 root root 1520636 2월 21 18:32 iwlwifi-ma-b0-hr-b0-86.ucode
-rw-r--r-- 1 root root 1515812 2월 21 18:32 iwlwifi-so-a0-gf-a0-64.ucode
-rw-r--r-- 1 root root 1524432 2월 21 18:32 iwlwifi-so-a0-gf-a0-67.ucode
-rw-r--r-- 1 root root 1533812 2월 21 18:32 iwlwifi-so-a0-gf-a0-68.ucode
-rw-r--r-- 1 root root 1550124 2월 21 18:32 iwlwifi-so-a0-gf-a0-71.ucode
-rw-r--r-- 1 root root 1560532 2월 21 18:32 iwlwifi-so-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1563692 2월 21 18:32 iwlwifi-so-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1577460 2월 21 18:32 iwlwifi-so-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1641260 2월 21 18:32 iwlwifi-so-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1667236 2월 21 18:32 iwlwifi-so-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1672988 2월 21 18:32 iwlwifi-so-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1682852 2월 21 18:32 iwlwifi-so-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1739988 2월 21 18:32 iwlwifi-so-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 1737644 2월 21 18:32 iwlwifi-so-a0-gf-a0-84.ucode
-rw-r--r-- 1 root root 1679788 2월 21 18:32 iwlwifi-so-a0-gf-a0-86.ucode
-rw-r--r-- 1 root root 1541932 2월 21 18:32 iwlwifi-so-a0-gf4-a0-67.ucode
-rw-r--r-- 1 root root 1552216 2월 21 18:32 iwlwifi-so-a0-gf4-a0-68.ucode
-rw-r--r-- 1 root root 1566352 2월 21 18:32 iwlwifi-so-a0-gf4-a0-71.ucode
-rw-r--r-- 1 root root 1580900 2월 21 18:32 iwlwifi-so-a0-gf4-a0-72.ucode
-rw-r--r-- 1 root root 1587800 2월 21 18:32 iwlwifi-so-a0-gf4-a0-73.ucode
-rw-r--r-- 1 root root 1602068 2월 21 18:32 iwlwifi-so-a0-gf4-a0-74.ucode
-rw-r--r-- 1 root root 1669164 2월 21 18:32 iwlwifi-so-a0-gf4-a0-77.ucode
-rw-r--r-- 1 root root 1711100 2월 21 18:32 iwlwifi-so-a0-gf4-a0-78.ucode
-rw-r--r-- 1 root root 1712776 2월 21 18:32 iwlwifi-so-a0-gf4-a0-79.ucode
-rw-r--r-- 1 root root 1691804 2월 21 18:32 iwlwifi-so-a0-gf4-a0-81.ucode
-rw-r--r-- 1 root root 1703968 2월 21 18:32 iwlwifi-so-a0-gf4-a0-83.ucode
-rw-r--r-- 1 root root 1709900 2월 21 18:32 iwlwifi-so-a0-gf4-a0-84.ucode
-rw-r--r-- 1 root root 1653836 2월 21 18:32 iwlwifi-so-a0-gf4-a0-86.ucode
-rw-r--r-- 1 root root 1427384 2월 21 18:32 iwlwifi-so-a0-hr-b0-64.ucode
-rw-r--r-- 1 root root 1429192 2월 21 18:32 iwlwifi-so-a0-hr-b0-68.ucode
-rw-r--r-- 1 root root 1456960 2월 21 18:32 iwlwifi-so-a0-hr-b0-71.ucode
-rw-r--r-- 1 root root 1470384 2월 21 18:32 iwlwifi-so-a0-hr-b0-72.ucode
-rw-r--r-- 1 root root 1465208 2월 21 18:32 iwlwifi-so-a0-hr-b0-73.ucode
-rw-r--r-- 1 root root 1475876 2월 21 18:32 iwlwifi-so-a0-hr-b0-74.ucode
-rw-r--r-- 1 root root 1500532 2월 21 18:32 iwlwifi-so-a0-hr-b0-77.ucode
-rw-r--r-- 1 root root 1517148 2월 21 18:32 iwlwifi-so-a0-hr-b0-79.ucode
-rw-r--r-- 1 root root 1539288 2월 21 18:32 iwlwifi-so-a0-hr-b0-81.ucode
-rw-r--r-- 1 root root 1552480 2월 21 18:32 iwlwifi-so-a0-hr-b0-83.ucode
-rw-r--r-- 1 root root 1549088 2월 21 18:32 iwlwifi-so-a0-hr-b0-84.ucode
-rw-r--r-- 1 root root 1507388 2월 21 18:32 iwlwifi-so-a0-hr-b0-86.ucode
-rw-r--r-- 1 root root 1365628 2월 21 18:32 iwlwifi-so-a0-jf-b0-64.ucode
-rw-r--r-- 1 root root 1378284 2월 21 18:32 iwlwifi-so-a0-jf-b0-68.ucode
-rw-r--r-- 1 root root 1400056 2월 21 18:32 iwlwifi-so-a0-jf-b0-71.ucode
-rw-r--r-- 1 root root 1406312 2월 21 18:32 iwlwifi-so-a0-jf-b0-72.ucode
-rw-r--r-- 1 root root 1409336 2월 21 18:32 iwlwifi-so-a0-jf-b0-73.ucode
-rw-r--r-- 1 root root 1417940 2월 21 18:32 iwlwifi-so-a0-jf-b0-74.ucode
-rw-r--r-- 1 root root 1446036 2월 21 18:32 iwlwifi-so-a0-jf-b0-77.ucode
-rw-r--r-- 1 root root 1413868 2월 21 18:32 iwlwifi-ty-a0-gf-a0-59.ucode
-rw-r--r-- 1 root root 1455104 2월 21 18:32 iwlwifi-ty-a0-gf-a0-62.ucode
-rw-r--r-- 1 root root 1460012 2월 21 18:32 iwlwifi-ty-a0-gf-a0-63.ucode
-rw-r--r-- 1 root root 1481960 2월 21 18:32 iwlwifi-ty-a0-gf-a0-66.ucode
-rw-r--r-- 1 root root 1482872 2월 21 18:32 iwlwifi-ty-a0-gf-a0-67.ucode
-rw-r--r-- 1 root root 1494304 2월 21 18:32 iwlwifi-ty-a0-gf-a0-68.ucode
-rw-r--r-- 1 root root 1494024 2월 21 18:32 iwlwifi-ty-a0-gf-a0-71.ucode
-rw-r--r-- 1 root root 1499284 2월 21 18:32 iwlwifi-ty-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1502900 2월 21 18:32 iwlwifi-ty-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1533444 2월 21 18:32 iwlwifi-ty-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1594276 2월 21 18:32 iwlwifi-ty-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1620004 2월 21 18:32 iwlwifi-ty-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1620704 2월 21 18:32 iwlwifi-ty-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1628828 2월 21 18:32 iwlwifi-ty-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1683076 2월 21 18:32 iwlwifi-ty-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 1676912 2월 21 18:32 iwlwifi-ty-a0-gf-a0-84.ucode
-rw-r--r-- 1 root root 1632464 2월 21 18:32 iwlwifi-ty-a0-gf-a0-86.ucode
5. modinfo iwlwifi
filename: /lib/modules/6.5.0-27-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-cc-a0-77.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-77.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-77.ucode
firmware: iwlwifi-Qu-b0-jf-b0-77.ucode
firmware: iwlwifi-Qu-c0-hr-b0-77.ucode
firmware: iwlwifi-Qu-b0-hr-b0-77.ucode
firmware: iwlwifi-ma-b0-mr-a0-83.ucode
firmware: iwlwifi-ma-b0-gf4-a0-83.ucode
firmware: iwlwifi-ma-b0-gf-a0-83.ucode
firmware: iwlwifi-ma-b0-hr-b0-83.ucode
firmware: iwlwifi-ma-a0-mr-a0-83.ucode
firmware: iwlwifi-ma-a0-gf4-a0-83.ucode
firmware: iwlwifi-ma-a0-gf-a0-83.ucode
firmware: iwlwifi-ma-a0-hr-b0-83.ucode
firmware: iwlwifi-ty-a0-gf-a0-83.ucode
firmware: iwlwifi-so-a0-gf-a0-83.ucode
firmware: iwlwifi-so-a0-hr-b0-83.ucode
firmware: iwlwifi-so-a0-jf-b0-83.ucode
firmware: iwlwifi-gl-c0-fm-c0-83.ucode
firmware: iwlwifi-gl-b0-fm-b0-83.ucode
firmware: iwlwifi-bz-a0-fm4-b0-83.ucode
firmware: iwlwifi-bz-a0-fm-c0-83.ucode
firmware: iwlwifi-bz-a0-fm-b0-83.ucode
firmware: iwlwifi-bz-a0-gf4-a0-83.ucode
firmware: iwlwifi-bz-a0-gf-a0-83.ucode
firmware: iwlwifi-bz-a0-hr-b0-83.ucode
firmware: iwlwifi-sc-a0-wh-a0-83.ucode
firmware: iwlwifi-sc-a0-gf4-a0-83.ucode
firmware: iwlwifi-sc-a0-gf-a0-83.ucode
firmware: iwlwifi-sc-a0-hr-b0-83.ucode
firmware: iwlwifi-sc-a0-fm-c0-83.ucode
firmware: iwlwifi-sc-a0-fm-b0-83.ucode
srcversion: 0440E23B2A94F0E8C9AC972
alias: pci:v00008086d0000E440sv*sd*bc*sc*i*
alias: pci:v00008086d00007740sv*sd*bc*sc*i*
alias: pci:v00008086d0000A840sv*sd*bc*sc*i*
alias: pci:v00008086d0000272Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002727sv*sd*bc*sc*i*
alias: pci:v00008086d00007E40sv*sd*bc*sc*i*
alias: pci:v00008086d00002729sv*sd*bc*sc*i*
alias: pci:v00008086d00007F70sv*sd*bc*sc*i*
alias: pci:v00008086d000054F0sv*sd*bc*sc*i*
alias: pci:v00008086d000051F1sv*sd*bc*sc*i*
alias: pci:v00008086d000051F0sv*sd*bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias: pci:v00008086d00007A70sv*sd*bc*sc*i*
alias: pci:v00008086d00002725sv*sd*bc*sc*i*
alias: pci:v00008086d00002723sv*sd*bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias: pci:v00008086d000043F0sv*sd*bc*sc*i*
alias: pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000034F0sv*sd*bc*sc*i*
alias: pci:v00008086d000006F0sv*sd*bc*sc*i*
alias: pci:v00008086d000002F0sv*sd*bc*sc*i*
alias: pci:v00008086d0000A370sv*sd*bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000031DCsv*sd*bc*sc*i*
alias: pci:v00008086d000030DCsv*sd*bc*sc*i*
alias: pci:v00008086d0000271Csv*sd*bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002526sv*sd*bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias: pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias: pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias: pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000526Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias: pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias: pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias: pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias: pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias: pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 6.5.0-27-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 7C:40:0F:70:93:A8:28:01:C4:70:76:FE:57:06:CE:57:A9:09:64:E3
sig_hashalgo: sha512
signature: 72:22:70:AA:42:38:99:33:7B:43:7A:05:92:46:E5:A9:DC:B4:FE:C4:
2D:C9:50:71:B7:3C:AE:C3:55:CE:F5:BE:93:F3:60:C1:DF:D6:49:43:
5F:52:71:56:5E:47:19:93:DC:11:EA:87:59:78:D8:48:4C:E2:40:82:
E6:4E:51:EB:43:2D:A6:0D:DE:AD:36:FF:AD:BB:B5:C2:2B:33:33:96:
AA:58:6A:62:5E:2C:D7:25:2E:42:D1:CF:42:82:E3:C7:F1:C9:88:89:
CF:3F:45:93:27:5F:BD:5B:BC:9B:4F:6D:C8:FE:A9:71:EB:00:40:95:
1B:6E:6F:41:70:D9:17:35:46:63:2C:64:8C:E9:7B:68:69:F4:E3:7C:
06:04:EF:4B:E7:B2:1F:08:4C:87:6C:91:61:15:E4:25:2F:11:68:39:
4D:8A:6E:C3:F4:98:2E:A7:82:DA:1D:F1:8D:DC:A4:3B:48:67:9D:49:
F1:5A:64:DE:33:BD:7A:36:77:AD:E6:F3:0A:EE:4E:BC:30:C0:9C:AE:
DE:94:72:DB:0D:10:30:49:E9:68:B3:91:99:02:A5:5A:69:58:62:52:
06:8F:12:A6:1A:E8:C3:65:EF:BC:65:02:76:01:B4:E4:61:8A:83:5D:
B3:26:1D:B4:59:9B:70:05:04:1E:2E:25:AA:FF:30:6A:7C:44:C0:79:
83:72:4C:43:1D:87:7B:67:F4:AB:46:56:DC:09:D4:D9:CB:EE:19:17:
DC:C2:6B:96:AE:A6:4D:6C:EC:63:BE:47:CD:87:BA:0D:6D:6B:3B:C8:
9B:90:BE:F2:B6:23:16:03:A2:B3:94:E3:E9:0B:7D:82:2D:2A:02:EE:
88:95:DE:E0:50:AD:6B:4A:47:11:A4:9E:57:07:E2:8D:C8:53:F5:23:
66:D2:F6:31:94:6C:C5:24:9C:B4:D5:E0:AE:90:6A:6E:79:AA:99:5F:
D9:9E:AF:43:B4:DD:8E:35:C5:EF:1D:87:3B:63:39:B2:2D:DF:49:0B:
E2:BC:82:C5:A9:A0:BD:64:3D:1F:D2:7A:CF:3C:7E:C7:32:60:5A:41:
67:54:C2:31:8B:40:FB:D7:05:03:53:C2:8F:F1:08:71:5F:8D:08:91:
B4:FA:8B:3F:0B:C8:28:A5:DE:8A:05:A3:D3:BA:BE:DA:7B:75:99:D1:
34:72:19:47:22:E7:CC:1B:A5:CB:2D:E3:20:29:39:99:D9:31:89:04:
DB:06:D7:07:31:0B:B6:6D:C1:BE:2D:F7:8E:D2:58:EC:9B:C9:DA:E0:
CD:D0:AE:66:5B:F8:5F:5B:6D:49:89:39:7F:D7:1F:D7:92:90:D0:4E:
EE:FD:1C:A5:9E:04:B1:9C:C2:45:60:55
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16) (uint)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_11be:Disable EHT capabilities (default: false) (bool)
When I was installing the operating system on my desktop, I downloaded it through wireless wifi instead of LAN, and it worked fine during installation. However, after removing the installation USB and rebooting to start using Ubuntu, suddenly none of the wireless communication was working.
Wireless communication still isn't functioning. How can I resolve this?
yasun95
I had previously inquired about the wireless communication not functioning on my desktop in the Ubuntu 22.04 LTS environment.
I hypothesized that my desktop's components might be too new for Ubuntu 22.04 LTS. In addition to wireless communication, there were also issues with the display on Ubuntu 22.04.
This led me to believe that there might be compatibility issues between the OS (especially an older LTS version) and the hardware components.
Without hesitation, I installed and tested the Ubuntu 24.04-beta version, which resulted in both the display and wireless communication functioning properly.
Here are the specifications of my desktop:
  • Motherboard: ROG STRIX Z790-E GAMING WIFI 2
  • CPU: Intel i9-14900K
  • Graphics: Nvidia Geforce RTX 4090
  • Wireless: Wifi 6E AX210
uname -srm -> Linux 6.8.0-22-generic x86_64
Good luck to everyone.
yasun95
"I made a mistake!
The motherboard I used is not the ROG STRIX Z370-E GAMING WIFI 2, but the ROG STRIX Z790-E GAMING WIFI 2!"
yasun95
