Wireless
7438 Discussions
Intel drivers post 22.50.1.1 dont work for 6GHz for AX210 Windows 10
N2692
I have upgraded my AX210 drivers to 22.80.1.1 for my Windows 10 platform. The device does not see 6GHz SSIDs anymore. My hardware platform does not support Windows 11, so I would like to understand if there will be a fix for this anytime soon. I would like to use the latest drivers for better performance. I tried to back rev the driver one release after another and the last release that works for 6GHz is 22.50.1.1.
I also made sure that the registry setting Is6GhzBandSupported is set to 1.
I tried with the Netgear RAXE500 as well as the ASUS AXE11000 with their latest firmware versions.
I am using Windows 10 21H1 release 19043.928 - October 10/12
Please let me know if there is a solution.
David_G_Intel
Hello N2692
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Do you experience any Bluetooth issues?
  • Is this a laptop or desktop system?
  • Is this issue happening at home, office environment or both?
  • Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Have you checked if this issue happens on different networks?
  • What steps do you take to reproduce your issue?
  • Have you installed any recent software or hardware in your system?
  • Have you rebooted your access-point, router, modem?
  • Do other devices still see the network?
  • Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
