16612 Discussions
Alternative to weak pull-up for I/O during configuration?
I've got the following problem:
I use a Cyclone II FPGA in a complex design. Some User I/Os are connected to npn transistors. The problem is, that during configuration thru an epcs4 device the outputs are weak pull-up. This means, that the npn transistors connected to these outputs are conductive during configuration (circa 260ms). The Design works properly on a ready developed PCB, but the Quality Management in my Company does not allow these transistors to be conductive during power-up. It is also not possible to add some pull-down resistors, because the PCB design should not be changed.
Is there any possibility to pull-down the USER I/O Pins during configuration?
Maybe a little tick in Quartus settings?
I hope somenone knows what I mean and has a solution!
Thanks in advance
Stefan
PS: Sorry for my bad english!
In unconfigured state, the device didn't yet receive any configuration data. How should Quartus be able to change the device behaviour then? the weak pull-up mechanism is hardwired in fpga silicon only.
An external pull-down resistor is a simple and reliable method to achieve the required behaviour. The weak pull-up resistor range is given in device manual (10 k minimum for most devices), it's easy to calculate a suitable pull-down resistor dimensioning.
Hi FvM,
Thanks for your reply!
I've expected that there´s no way to change the USER I/O behaviour during configuration! I think I have to make a redesign of the PCB to achieve the behaviour I need. Unfortunately it´s not possible to solder some additional pull-down resistors on the PCB, because the transistors are in a SOT 363 Package. Maybe it´s possible to add some external inverters on the pcb and change the vhdl file to change the behaviour.
You can use dual transistors with integrated resistors or solder 0201 chips to the SOT363 pins.
Is there any reason why newer devices don't use Bus-Hold during config, instead of weak pull-up?
Bus-hold hasn't a defined initial level, it would be unacceptable for many applications.
--- Quote Start ---
--- Quote End ---
I am talking at POR & config time, before user mode. Why you would care at all about a defined level before user mode?
I seriously care about it, cause I have hardware connected to some I/O pins that may be instantly damaged when receiving illegal signal patterns.
--- Quote Start ---
--- Quote End ---
I see. You are using the weak pull-ups, not for the purpose of avoiding floating inputs on the FPGA, but also for providing a defined power-up output level.
I assumed that in those applications where the power-up level is critical, an external pull-up or pull-down would be used, but I guess I was wrong.
Today I talked to an FAE from my distributor and he told me that possibly in Cyclone IV devices it might be possible to choose between weak pull-up and weak pull-down I/Os during configuration. A special PIN has to be hard-wired for selection, but these are plans for the future. I think I'll leave my design unchanged because it works well. In a re-design of the PCB I use some unused inverters to meet my requirements.
Thanks for your suggestions!
Stefan
