12606 Discussions
Cyclone IV : boot nios from epcs
Dear all,
I'm trying to run the nios directly from the flash (epcs16) on startup, but even if I apply step by step instructions on different files given by Altera, I never succeeded (the fpga works).
- Generic Nios II Booting Methods User Guide
- Enabling Nios® II Boot from Quad Serial Configuration(EPCQ) and Serial Configuration (EPCS) devices inQuartus® II 13.0
- Nios II Processor Booting From Altera Serial Flash (AN736)
Could you help me please?
Here is what I do
hardware configuration: https://alteraforum.com/forum/attachment.php?attachmentid=13898&stc=1
A: Nios II (e) and Reset vector on epcq_controller memory
B: on chip ram
C: active serial flash controller (epcs 16) https://alteraforum.com/forum/attachment.php?attachmentid=13899&stc=1
(there are different flash controller: legacy...)
D: Clock bridge to get a 25MHz because of epcs clock constraint
https://alteraforum.com/forum/attachment.php?attachmentid=13900&stc=1
software configuration:
1. Build Project
2. Open Nios II command shell:
sof2flash --input=hw.sof --output=hw.flash –epcs –verbose
elf2flash --input=sw.elf --output=sw.flash --epcs --after=hw.flash –verbose
nios2-elf-objcopy --input-target srec --output-target ihex sw.flash sw.hex
output generation:
https://alteraforum.com/forum/attachment.php?attachmentid=13901&stc=1
SOF file with SOF Data (no compression)
And Hex data
  • Big endian
  • Relative address
Thank you,
Guillaume
I tried again but it doesn't work.
Any idea?
Thank you!
For the software configuration, can you try the mem_init_generate tool instead of sof2flash or elf2flash tool?
Any more description when you say it never works?
If you programmed a JIC file containing only SOF, does the FPGA configuration works?
Thanks for you answer.
When I programmed the FPGA with a .pof or .jic file containing only the SOF, the FPGA configuration worked. Then, I added the nios code to the POF and the FPGA also worked.
I'm going to try with the mem_ini_generate, and I'll set the generated hex file to the absolute address + 1 after the FPGA bitstream.
Thank you
Take note on the reset vector offset as well, make sure it does not overlap the configuration bitstream.
