problem with niosII
when i try to run my program as NiosII instruction set simulator this warning appear,i dont understand how to solve it:
**** build of configuration debug for project farha ****
make -s all includes
compiling hello_world.c...
linking farha.elf...
info: (farha.elf) 39 kbytes program size (code + initialized data).
info: 2009 kbytes free for stack + heap.
post-processing to create ext_flash.flash
hardware simulation is not enabled for the target sopc builder system. skipping creation of hardware simulation model contents and simulation symbol files. (note: this does not affect the instruction set simulator.)
post-processing to create onchip_ram.hex
build completed in 12.781 seconds
what shall i do to have a result.
i'm working with niosII ide(v9),quartus(v9),cycloneII
:confused::confused::confused:
Did u configure your sopc system pins?
Not yet,how to do it?
Follow this tutorial.;)
Maybe you need asure the .sof is right!
