16616 Discussions
reading interger digits independently
I would like to know if its possible to read digits of an integer independent of each other.... for example, say i have an integer with a value "100". is it possible to assign each digit of an integer to say maybe 3 variables.. first one loaded with '1', 2nd & 3rd loaded with '0's? how do i code it if its possible?
i hope im clear
found some info on the net n then wrote a code for converting Binary to BCD :)
The whole point with the type system in VHDL is that things like integer do not have individual bits that you can access. For doing that, use unsigned/signed types instead.
