16642 Discussions
13 bit counter in VHDL not working :(
Hi..
I have made simple 13 bit counter code.But its not working.I could not able to find any solution.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
architecture behav of FA_calc is
signal counter : std_logic_vector(12 downto 0) := "0000000000000";
signal clkenable : std_logic;
begin
clkdiv : process(clk)
begin
if clk = '1' and clk'event and clkenable = '1' then
counter <= counter + 1;
end if;
end process;
trans : process(counter)
begin
clkenable <= '1';
if counter = "1101001000000" then
end case;
counter <= "0000000000000";
clkenable <= '0';
end if;
end process trans;
Warning :- There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).
Whats should i do for that ??Error is because of unsign number i defined "use IEEE.std_logic_unsigned.all but still warning :(
begin
end if;
end process;
THe above if statement is not formed correctly.
remove the and clkenable = '1' from the initial if statemetn and place it inside the (clk and clkevent) section.
THe altera tool have a language help section forthese type expressions.
