hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1568 Discussions
Could not install Intel Fortran 2025 with VS2019, the log file is included.
DK57
01/20/2025 15:57:38:004 : 6632 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir F:/TEMP/intel_oneapi_installer/2025.01.20.15.57.28.994 --product-id intel.oneapi.lin.fortran-compiler.product --product-ver 2025.0.4+10 --package-path F:\temp\intel-fortran-compiler-2025.0.4.19_offline\packages
01/20/2025 15:57:38:004 : 6632 : MESSAGE : Installer is started in GUI mode
01/20/2025 15:57:38:004 : 6632 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.4.0.1657
01/20/2025 15:57:38:004 : 6632 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.4.0-1657
01/20/2025 15:57:38:004 : 6632 : MESSAGE : Product is set to intel.oneapi.lin.fortran-compiler.product,v=2025.0.4+10. Mode is set to install.
01/20/2025 15:57:38:280 : 17536 : MESSAGE : PreRequisite for other install successfully checked
01/20/2025 15:57:38:288 : 17536 : MESSAGE : PreRequisite for other Intel install successfully checked
01/20/2025 15:57:38:290 : 17536 : MESSAGE : All checks for preRequisite for supported operation system are passed
01/20/2025 15:57:39:019 : 17536 : MESSAGE : PreRequisite for admin rights successfully checked
01/20/2025 15:57:39:019 : 17536 : MESSAGE : PreRequisite for temporary folder successfully checked
01/20/2025 15:57:39:019 : 17536 : MESSAGE : PreRequisite for host architecture successfully checked
01/20/2025 15:58:08:105 : 18128 : MESSAGE : Changed installation directory from 'C:\Program Files (x86)\Intel\oneAPI' to 'C:\Intel\oneAPI'.
01/20/2025 15:58:13:449 : 18128 : MESSAGE : Check for id = [F191IDEFound] failed
01/20/2025 15:58:13:449 : 18128 : MESSAGE : Title [Intel® Visual Fortran Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
01/20/2025 15:58:13:449 : 18128 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel Visual Fortran Compilers.]
01/20/2025 15:58:13:453 : 18128 : MESSAGE : PreRequisite for Instance Msi successfully checked
01/20/2025 15:58:42:789 : 18128 : MESSAGE : PreRequisite for free disk space passed
01/20/2025 15:58:42:794 : 18128 : MESSAGE : PreRequisite for permissions passed
01/20/2025 15:58:42:794 : 18128 : MESSAGE : PreRequisite for empty dir is passed
01/20/2025 15:58:42:794 : 18128 : MESSAGE : PreRequisite for other install successfully checked
01/20/2025 15:58:42:794 : 18128 : MESSAGE : PreRequisite for other Intel install successfully checked
01/20/2025 15:58:42:827 : 18128 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2019] passed
01/20/2025 15:58:42:827 : 18128 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
01/20/2025 15:58:42:866 : 6632 : MESSAGE : ISIP consent status is 'No'
01/20/2025 15:58:42:866 : 6632 : MESSAGE : Product installation directory is C:\Intel\oneAPI
01/20/2025 15:58:42:866 : 6632 : MESSAGE : Product installation size required: 1490497612 bytes
01/20/2025 15:58:42:866 : 6632 : MESSAGE : Product will be (un)integrated with the following IDEs:
01/20/2025 15:58:42:866 : 6632 : MESSAGE : Microsoft Visual Studio* 2019.
01/20/2025 15:58:42:866 : 6632 : MESSAGE : End of IDE list.
01/20/2025 15:58:42:877 : 18128 : MESSAGE : Graph State Dump.
intel.oneapi.lin.fortran-compiler.product,v=2025.0.4+10, Enabled, Selected, Not Installed
intel.oneapi.win.ifort-compiler,v=2025.0.4+1521, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common,v=2025.0.4+1521, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2025.0.4+1521, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2025.0.4+1521, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2025.0.1+16, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vs2019_links,v=2025.0.1+16, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vs2022_links,v=2025.0.1+16, Disabled, Not Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2025.0.1+16, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.oneapi-vars,v=2025.0.1+16, Enabled, Selected, Not Installed
intel.oneapi.win.umf,v=0.9.1+5, Enabled, Selected, Not Installed
intel.oneapi.win.tcm,v=1.2.0+583, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger,v=2025.0.0+656, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2025.0.0+656, Enabled, Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-fee-vs2019,v=2025.0.0+656, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2025.0.0+656, Enabled, Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-vsmi-vs2019,v=2025.0.0+656, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2025.0.0+656, Disabled, Not Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-fee-vs2022,v=2025.0.0+656, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2025.0.0+656, Disabled, Not Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-vsmi-vs2022,v=2025.0.0+656, Enabled, Not Selected, Not Installed
intel.oneapi.win.mpi.runtime,v=2021.14.1+6, Enabled, Selected, Not Installed
intel.oneapi.win.ifort-compiler-ide-reg,v=2025.0.4+1521, Enabled, Selected, Not Installed
intel.oneapi.win.ifort-compiler.ide.vs2019,v=2025.0.1+10, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common_vs_2019,v=2025.0.1+10, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.utils_vs_2019,v=2025.0.1+10, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common,v=2025.0.1+10, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.regupdater_nl,v=2025.0.1+10, Enabled, Selected, Not Installed
intel.oneapi.win.ifort-compiler.ide.vs2022,v=2025.0.1+10, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common_vs_2022,v=2025.0.1+10, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.utils_vs_2022,v=2025.0.1+10, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.docs,v=2025.0.1+10, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.docs-fort,v=2025.0.1+10, Enabled, Selected, Not Installed
01/20/2025 15:58:42:880 : 18128 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Protecting installation location...
Finalizing removal. It may take up to 5 minutes...
Install intel.oneapi.win.oneapi-common.vs2019_links,v=2025.0.1+16
Install intel.oneapi.win.oneapi-common.vars,v=2025.0.1+16
Install intel.oneapi.win.oneapi-common.licensing,v=2025.0.1+16
Install intel.oneapi.win.oneapi-common.oneapi-vars,v=2025.0.1+16
Install intel.oneapi.win.tcm,v=1.2.0+583
Install intel.oneapi.win.umf,v=0.9.1+5
Install intel.oneapi.win.openmp,v=2025.0.4+1521
Install intel.oneapi.win.compilers-common-runtime,v=2025.0.4+1521
Install intel-oneapi-win-dpcpp_debugger-vsix-fee-vs2019,v=2025.0.0+656
Install intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2025.0.0+656
Install intel-oneapi-win-dpcpp_debugger-vsix-vsmi-vs2019,v=2025.0.0+656
Install intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2025.0.0+656
Install intel.oneapi.win.dpcpp_debugger,v=2025.0.0+656
Install intel.oneapi.win.compilers-common,v=2025.0.4+1521
Install intel.oneapi.win.mpi.runtime,v=2021.14.1+6
Install intel.oneapi.win.ifort-compiler-ide-reg,v=2025.0.4+1521
Install intel.oneapi.win.compilers-common.ide.utils_vs_2019,v=2025.0.1+10
Install intel.oneapi.win.compilers-common.ide.common_vs_2019,v=2025.0.1+10
Install intel.oneapi.win.compilers-common.ide.regupdater_nl,v=2025.0.1+10
Install intel.oneapi.win.compilers-common.ide.common,v=2025.0.1+10
Install intel.oneapi.win.ifort-compiler.ide.vs2019,v=2025.0.1+10
Install intel.oneapi.win.compilers-common.ide.docs,v=2025.0.1+10
Install intel.oneapi.win.compilers-common.ide.docs-fort,v=2025.0.1+10
Install intel.oneapi.win.ifort-compiler,v=2025.0.4+1521
Install intel.oneapi.lin.fortran-compiler.product,v=2025.0.4+10
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
01/20/2025 15:58:43:368 : 18128 : MESSAGE : Start install/modify sequence execution.
01/20/2025 15:58:43:515 : 18128 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1737385122877398'.
01/20/2025 15:58:43:515 : 18128 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1737385122877398' execution is finished with status Success.
01/20/2025 15:58:43:515 : 18128 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1737385122877398'.
01/20/2025 15:58:43:515 : 18128 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1737385122877398' execution is finished with status Success.
01/20/2025 15:58:43:515 : 18128 : MESSAGE : Starting execution of operation 'protect.operation.intel.sessionmanifest.1737385122877398'.
01/20/2025 15:58:43:692 : 18128 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1737385122877398' execution is finished with status Success.
01/20/2025 15:58:43:692 : 18128 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1737385122877399'.
01/20/2025 15:58:43:692 : 18128 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1737385122877399' execution is finished with status Success.
01/20/2025 15:58:43:693 : 18128 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.vs2019_links,v=2025.0.1+16'.
01/20/2025 15:58:43:827 : 18128 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vs2019_links,v=2025.0.1+16' execution is finished with status Success.
01/20/2025 15:58:43:827 : 18128 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.vars,v=2025.0.1+16'.
01/20/2025 15:58:43:929 : 18128 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.oneapi-common.vars, name: oneAPI Common, version: 2025.0.1+16.
Error: Sequence execution failed.
01/20/2025 15:58:43:929 : 18128 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2025.0.1+16' execution is finished with status Fail.
01/20/2025 15:58:43:930 : 18128 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.vs2019_links,v=2025.0.1+16'.
01/20/2025 15:58:44:070 : 18128 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vs2019_links,v=2025.0.1+16' rollback is finished with status Success.
01/20/2025 15:58:44:070 : 18128 : MESSAGE : Starting rollback of operation 'complete.operation.intel.sessionmanifest.1737385122877399'.
01/20/2025 15:58:44:153 : 18128 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1737385122877399' rollback is finished with status Success.
01/20/2025 15:58:44:153 : 18128 : MESSAGE : Starting rollback of operation 'protect.operation.intel.sessionmanifest.1737385122877398'.
01/20/2025 15:58:44:153 : 18128 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1737385122877398' rollback is finished with status Success.
01/20/2025 15:58:44:153 : 18128 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1737385122877398'.
01/20/2025 15:58:44:153 : 18128 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1737385122877398' rollback is finished with status Success.
01/20/2025 15:58:44:153 : 18128 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1737385122877398'.
01/20/2025 15:58:44:154 : 18128 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1737385122877398' rollback is finished with status Success.
01/20/2025 15:58:44:154 : 18128 : ERROR : Install sequence execution status: Rollback
01/20/2025 15:58:44:188 : 6632 : MESSAGE : ----------------------------------------------------------------------------------------------------
01/20/2025 15:58:44:188 : 6632 : MESSAGE : Anonymous statistics fields:
01/20/2025 15:58:44:188 : 6632 : MESSAGE : EventId = 'install-min'
01/20/2025 15:58:44:188 : 6632 : MESSAGE : EventKey = 'S3UqiDQDs0egwqo7y1z17w=='
01/20/2025 15:58:44:189 : 6632 : MESSAGE : EventTime = ''
01/20/2025 15:58:44:189 : 6632 : MESSAGE : Id = 'intel.oneapi.lin.fortran-compiler.product,v=2025.0.4+10'
01/20/2025 15:58:44:189 : 6632 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® Fortran Compiler 2025.0.4\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4611\", \"product_tag\":\"\" }'
01/20/2025 15:58:44:189 : 6632 : MESSAGE : ProductId = '[Windows] Intel® Fortran Compiler 2025.0.4'
01/20/2025 15:58:44:189 : 6632 : MESSAGE : ----------------------------------------------------------------------------------------------------
RahulC_Intel
Hi Dimitar, could you please share the below details with us so that we will assist you in a better way.
  • Operating system and its build version on which you are installing the product.
  • Are you using online or offline installer?
  • Did you select Desktop Development with C++ while installing Visual Studio?
  • Exact version of Visual Studio with build version?
  • Screenshot of an error code.
DK57
1. I was the latest Fortran 2025 offline installer. Next week I will have access to the computer in question and will give you the required information. Thank you.
2. On other hand, I was able to install the same on the another computer and started to test the same compiler.
F.Y.I., I'm developing DLLs for a complex application, which works greatly compiled with the old IFORT from 2011. I would like to test the same with the latest Fortran compiler 2025.
Compiled for debug with /Od the application starts and works. However compiled for release with any of /O0 ..... /O3, the DLLs are built, but the application will not run. It exits with no message. Could you please help on this. Thank you.
RahulC_Intel
Hi Dimitar, we have sent you a private message. Kindly check your inbox.
RahulC_Intel
Hi Dimitar, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
