oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1285 Discussions
Fail to install oneAPI 2021 on Windows Server 2022
Zaikun
I tried installing oneAPI 2021 Fortran compilers on Windows Server 2022 using the following batch script.
:: URL for the offline installer of Intel OneAPI Fortran compiler. See
set URL=https://registrationcenter-download.intel.com/akdlm/irc_nas/18247/w_HPCKit_p_2021.4.0.3340_offline.exe
:: Component to install.
set COMPONENTS=intel.oneapi.win.ifort-compiler
:: Download the installer. curl is included by default in Windows since Windows 10, version 1803.
::cd %Temp%  :: CD does not work if %Temp% is on a different drive.
curl.exe --output webimage.exe --url %URL% --retry 5 --retry-delay 5
start /b /wait webimage.exe -s -x -f webimage_extracted --log extract.log
:: Install the compiler.
webimage_extracted\bootstrapper.exe -s --action install --components=%COMPONENTS% --eula=accept -p=NEED_VS2017_INTEGRATION=0 -p=NEED_VS2019_INTEGRATION=0 -p=NEED_VS2022_INTEGRATION=0 --log-dir=.
set installer_exit_code=%ERRORLEVEL%
:: Run the script that sets the environment variables.
call "C:\Program Files (x86)\Intel\oneAPI\setvars.bat"
:: Show the result of the installation.
echo The path to ifort is:
where ifort.exe
echo The path to ifx is:
where ifx.exe
:: Remove the installer.
del webimage.exe
rd /s/q "webimage_extracted"
:: Exit with the installer exit code.
exit /b %installer_exit_code%
It fails with the following message.
Checking system requirements...
Done.
Wait while the installer is preparing...
Done.
Launching the installer...
Process crashed
D:\a\setup_mex\setup_mex>set installer_exit_code=-1073741819
Here is a screenshot.
In contrast, the same installation works well on Windows Server 2019.
Is this a known issue, or did I overlook something?
Thank you very much.
Barbara_P_Intel
Moving this over to the Installation Forum. They are better equipped to help.
