Hello All,
I cannot install the update for IntelOneAPI.
Please see log files attached.
N
Hi Noemig4,
Thanks for posting your concern on the forum. Kindly let us know the below details. They will allow us to understand the situation better.
- The version of the Windows operating system.
- A screenshot of the error in GUI installer, if available.
- Are you using the customizable (i.e. online) installer or a full (i.e. offline) installer?
- What are the versions of Visual Studio currently installed & recently uninstalled (if any)?
- What are the versions of Intel® product toolkits (i.e. Intel® OneAPI Toolkit) & suites (i.e. Intel® Parallel Studio XE) or their components already installed & recently uninstalled (if any)?
Looking forward to your update. Hope you have a nice day ahead!
Soumya
Thank you for your reply Soumya, please see my answers below:
- The version of the Windows operating system. Windows 10 PRO
- A screenshot of the error in GUI installer, if available. See image attached.
- Are you using the customizable (i.e. online) installer or a full (i.e. offline) installer? Online Installer.
- What are the versions of Visual Studio currently installed & recently uninstalled (if any)? Microsoft Visual Studio 2019 (currently installed from 1 or 2 years ago)
- What are the versions of Intel® product toolkits (i.e. Intel® OneAPI Toolkit) & suites (i.e. Intel® Parallel Studio XE) or their components already installed & recently uninstalled (if any)? I am installing Intel OneAPI Toolkit but I also use Intel Parallel Studio 2017 with MVS 2013.
N
Hi N,
Thanks for the information. However, based on the shared installation logs and information we have some confusion and would require some more details to check further. Please find them below.
- Kindly check the below path and let us know if Intel® oneAPI Base Toolkit version 2022 and Intel® oneAPI HPC Toolkit version 2021.3 & 2022 are currently installed on the system.
- Path: C:\Program Files (x86)\Intel\oneAPI
- We understand that Visual Studio 2017 and 2019 are installed on the system. However, could you please check and confirm if Visual Studio 2022 is installed on the system?
- Copies of the Info (using 'Copy Info') from 'About' of the Help section of Visual Studio ( for all versions that are currently installed).
Soumya
Soumya,
Thank you for your support. Please see below my comments:
- The following image show my oneAPI folder from path: C:\Program Files (x86)\Intel\oneAPI
- We understand that Visual Studio 2017 and 2019 are installed on the system. However, could you please check and confirm if Visual Studio 2022 is installed on the system? Yes, I have the trial version of Visual Studio 2022. I am testing it to see if it will be useful to get the full license. Does Intel OneAPI work better with MVS 2022? Or 2019 should be fine?
- Copies of the Info (using 'Copy Info') from 'About' of the Help section of Visual Studio ( for all versions that are currently installed). Please see info below:
Microsoft Visual Studio Professional 2019
Version 16.11.23
VisualStudio.16.Release/16.11.23+33214.272
Microsoft .NET Framework
Version 4.8.09037
Installed Version: Professional
Visual C++ 2019 00435-20151-15700-AA191
Microsoft Visual C++ 2019
.NET Core Debugging with WSL 1.0
ADL Tools Service Provider 1.0
This package contains services used by Data Lake tools
ASA Service Provider 1.0
ASP.NET and Web Tools 2019 16.11.115.10959
ASP.NET Web Frameworks and Tools 2019 16.11.115.10959
For additional information, visit https://www.asp.net/
Azure App Service Tools v3.0.0 16.11.115.10959
Azure Data Lake Node 1.0
This package contains the Data Lake integration nodes for Server Explorer.
Azure Data Lake Tools for Visual Studio 2.6.1000.0
Microsoft Azure Data Lake Tools for Visual Studio
Azure Functions and Web Jobs Tools 16.11.115.10959
Azure Stream Analytics Tools for Visual Studio 2.6.1000.0
Microsoft Azure Stream Analytics Tools for Visual Studio
C# Tools 3.11.0-4.22108.8+d9bef045c4362fbcab27ef35daec4e95c8ff47e1
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools 1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Cookiecutter 16.11.21196.2
Provides tools for finding, instantiating and customizing templates in cookiecutter format.
Extensibility Message Bus 1.2.6 (master@34d6af2)
Provides common messaging-based MEF services for loosely coupled Visual Studio extension components communication and integration.
Fabric.DiagnosticEvents 1.0
Fabric Diagnostic Events
GitHub.VisualStudio 2.11.106.19330
A Visual Studio Extension that brings the GitHub Flow into Visual Studio.
Intel Libraries for oneAPI Package ID: w_oneAPI_2022.0.0.161
Intel Libraries for oneAPI – toolkit version: 2022.1.0, extension version 22.0.0.16, Package ID: w_oneAPI_2022.0.0.161, Copyright © 2019-2021 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
Intel® Advisor 2022.0 611554
Intel® Advisor 2022.0, (build 611554), Copyright © 2009-2022 Intel Corporation. All rights reserved.
Intel® C++ Compiler Package ID: w_oneAPI_2022.0.0.161
Intel® C++ Compiler – toolkit version: 2022.1.0, extension version 22.0.16, Package ID: w_oneAPI_2022.0.0.161, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® C++ Compiler Classic Package ID: w_oneAPI_2022.0.0.161
Intel® C++ Compiler Classic – toolkit version: 2022.1.0, extension version 19.2.9.16, Package ID: w_oneAPI_2022.0.0.161, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® DPC++ Compatibility Tool Package ID: w_oneAPI_2022.0.0.97
Intel® DPC++ Compatibility Tool – toolkit version: 2022.1.0, extension version 2022.0.0.16, Package ID: w_oneAPI_2022.0.0.97, Copyright © 2019-2021 Intel Corporation. All rights reserved.
Intel® Fortran Compiler Package ID: w_oneAPI_2022.0.0.161
Intel® Fortran Compiler – toolkit version: 2022.1.0, extension version 22.0.0065.16, Package ID: w_oneAPI_2022.0.0.161, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® Inspector 2022.0 605868
Intel® Inspector 2022.0, (build 605868), Copyright © 2009-2022 Intel Corporation. All rights reserved.
Intel® oneAPI DPC++ Compiler Package ID: w_oneAPI_2022.0.0.161
Intel® oneAPI DPC++ Compiler – toolkit version: 2022.1.0, extension version 22.0.0.16, Package ID: w_oneAPI_2022.0.0.161, Copyright © 2019-2021 Intel Corporation. All rights reserved.
Intel® oneAPI Menu & Samples 1.1.431
Intel® oneAPI Visual Studio Menu & Samples Extension
Intel® Performance Libraries Package ID: w_comp_lib_2020.4.311
Intel® Performance Libraries – extension version 19.2.9.16, Package ID: w_comp_lib_2020.4.311, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® VTune™ Profiler 2022 1.2.39.9
Intel® VTune™ Profiler 2022, (build 1.2.39.9), Copyright © 2009-2021 Intel Corporation. All rights reserved.
IntelliCode Extension 1.0
IntelliCode Visual Studio Extension Detailed Info
Microsoft Azure HDInsight Azure Node 2.6.1000.0
HDInsight Node under Azure Node
Microsoft Azure Hive Query Language Service 2.6.1000.0
Language service for Hive query
Microsoft Azure Service Fabric Tools for Visual Studio 16.10
Microsoft Azure Stream Analytics Language Service 2.6.1000.0
Language service for Azure Stream Analytics
Microsoft Azure Stream Analytics Node 1.0
Azure Stream Analytics Node under Azure Node
Microsoft Azure Tools for Visual Studio 2.9
Support for Azure Cloud Services projects
Microsoft Continuous Delivery Tools for Visual Studio 0.4
Simplifying the configuration of Azure DevOps pipelines from within the Visual Studio IDE.
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft Library Manager 2.1.126+g11d4cf0d0c.RR
Install client-side libraries easily to any web project
Microsoft MI-Based Debugger 1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards 1.0
Microsoft Visual Studio Tools for Containers 1.2
Develop, run, validate your ASP.NET Core applications in the target environment. F5 your application directly into a container with debugging, or CTRL + F5 to edit & refresh your app without having to rebuild the container.
Microsoft Visual Studio VC Package 1.0
Mono Debugging for Visual Studio 16.10.15 (552afdf)
Support for debugging Mono processes with Visual Studio.
Node.js Tools 1.5.30526.3 Commit Hash:c09c81113bcbc86d57943fcdd67e82434263d61d
Adds support for developing and debugging Node.js apps in Visual Studio
NuGet Package Manager 5.11.2
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension 1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Python 16.11.21196.2
Provides IntelliSense, projects, templates, debugging, interactive windows, and other support for Python developers.
Python - Profiling support 16.11.21196.2
Profiling support for Python projects.
Razor (ASP.NET Core) 16.1.0.2122504+13c05c96ea6bdbe550bd88b0bf6cdddf8cde1725
Provides languages services for ASP.NET Core Razor.
SQL Server Data Tools 16.0.62205.05200
Microsoft SQL Server Data Tools
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
ToolWindowHostedEditor 1.0
Hosting json editor into a tool window
TypeScript Tools 16.0.30526.2002
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 3.11.0-4.22108.8+d9bef045c4362fbcab27ef35daec4e95c8ff47e1
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual F# Tools 16.11.0-beta.21514.6+b6c2c4f53ea3a08fa603ea93d6d2f808a62a21d1
Microsoft Visual F# Tools
Visual Studio Code Debug Adapter Host Package 1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Container Tools Extensions 1.0
View, manage, and diagnose containers within Visual Studio.
Visual Studio Tools for CMake 1.0
Visual Studio Tools for Containers 1.0
Visual Studio Tools for Kubernetes 1.0
VisualStudio.DeviceLog 1.0
Information about my package
VisualStudio.Foo 1.0
VisualStudio.Mac 1.0
Mac Extension for Visual Studio
Xamarin 16.11.000.197 (d16-11@6934992)
Visual Studio extension to enable development for Xamarin.iOS and Xamarin.Android.
Xamarin Designer 16.11.0.47 (remotes/origin/d16-11@e0d612363)
Visual Studio extension to enable Xamarin Designer tools in Visual Studio.
Xamarin Templates 16.10.5 (355b57a)
Templates for building iOS, Android, and Windows apps with Xamarin and Xamarin.Forms.
Xamarin.Android SDK 12.0.0.3 (d16-11/f0e3c2d)
Xamarin.Android Reference Assemblies and MSBuild support.
Mono: c633fe9
Java.Interop: xamarin/java.interop/d16-11@476bb5b
ProGuard: Guardsquare/proguard/v7.0.1@912d149
SQLite: xamarin/sqlite/3.35.4@85460d3
Xamarin.Android Tools: xamarin/xamarin-android-tools/d16-11@87af37b
Xamarin.iOS and Xamarin.Mac SDK 15.2.0.17 (738fde344)
Xamarin.iOS and Xamarin.Mac Reference Assemblies and MSBuild support.
Thank you very much.
N
Hi N,
Thanks for letting us know the details. However, as mentioned in the last response, we would be requiring of the Visual Studio Info for all the Visual Studio version builds installed. Therefore, kindly share the info for VS 2013 and 2022. If possible , kindly share them in separate text files. We would be requiring them to address the concern better.
Coming to your query - 'Does Intel OneAPI work better with MVS 2022? Or 2019 should be fine?'
The compatibility depends on the specific Intel® product and Visual Studio versions. Our engineering team has tested and documented the compatible Visual Studio versions and their build numbers for integration with the Intel® Parallel Studio XE suite & Intel® OneAPI Toolkit versions. Because of that, Intel® recommends users to check and choose from the below link.
Intel® Compilers Compatibility with Microsoft Visual Studio* Link: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
However, since there are multiple versions of the product suite, toolkit and Visual Studio on the system, there are multiple versions that are incompatible with each other. We have recently come across an issue with Visual Studio 2022 due to which even the product being installed once can cause issues (even post-uninstallation) with older incompatible Intel® product versions. We have resolved these issue with our internal team in the later developments of the product toolkit versions. However, the old product are unable to uninstall (part of the update as well) because of the issue.
Due to that, we would require the requested copies of info to understand the current situation and provide a suitable workaround based on it.
Soumya
Hi Soumya,
Please see the information below:
MVS2013
Microsoft Visual Studio Professional 2013
Version 12.0.31101.00 Update 4
Version 4.8.09037
LightSwitch for Visual Studio 2013 06177-179-0034923-02434
Microsoft LightSwitch for Visual Studio 2013
Team Explorer for Visual Studio 2013 06177-179-0034923-02434
Microsoft Team Explorer for Visual Studio 2013
Visual Basic 2013 06177-179-0034923-02434
Microsoft Visual Basic 2013
Visual C# 2013 06177-179-0034923-02434
Microsoft Visual C# 2013
Visual C++ 2013 06177-179-0034923-02434
Microsoft Visual C++ 2013
Visual F# 2013 06177-179-0034923-02434
Microsoft Visual F# 2013
Visual Studio 2013 Code Analysis Spell Checker 06177-179-0034923-02434
Microsoft® Visual Studio® 2013 Code Analysis Spell Checker
Portions of International CorrectSpell™ spelling correction system © 1993 by Lernout & Hauspie Speech Products N.V. All rights reserved.
The American Heritage® Dictionary of the English Language, Third Edition Copyright © 1992 Houghton Mifflin Company. Electronic version licensed from Lernout & Hauspie Speech Products N.V. All rights reserved.
Windows Phone SDK 8.0 - ENU 06177-179-0034923-02434
Application Insights Tools for Visual Studio Package 1.0
ASP.NET and Web Tools 12.4.51016.0
Microsoft Web Developer Tools contains the following components:
Support for creating and opening ASP.NET web projects
Browser Link: A communication channel between Visual Studio and browsers
Editor extensions for HTML, CSS, and JavaScript
Page Inspector: Inspection tool for ASP.NET web projects
Scaffolding: A framework for building and running code generators
Server Explorer extensions for Microsoft Azure Websites
Web publishing: Extensions for publishing ASP.NET web projects to hosting providers, on-premises servers, or Microsoft Azure
ASP.NET Web Frameworks and Tools 2012.2 4.1.21001.0
For additional information, visit http://go.microsoft.com/fwlink/?LinkID=309563
ASP.NET Web Frameworks and Tools 2013 5.2.21010.0
For additional information, visit http://www.asp.net/
Common Azure Tools 1.3
Intel® Advisor 2017 Update 3
Intel® Advisor 2017 Update 3, (build 510716), Copyright © 2009-2017 Intel Corporation. All rights reserved.
Intel® Inspector 2017 Update 3
Intel® Inspector 2017 Update 3, (build 510645), Copyright © 2009-2017 Intel Corporation. All rights reserved.
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for C++ Windows* Package ID: w_comp_lib_2017.4.210
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for C++ Windows* Integration for Microsoft* Visual Studio* 2013, Version 17.0.76.12, Copyright © 2002-2017 Intel Corporation. All rights reserved.
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows* Package ID: w_comp_lib_2017.4.210
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2013, Version 17.0.0047.12, Copyright © 2002-2017 Intel Corporation. All rights reserved.
Intel® VTune™ Amplifier XE 2017 Update 3
Intel® VTune™ Amplifier XE 2017 Update 3, (build 510739), Copyright © 2009-2017 Intel Corporation. All rights reserved.
Microsoft Azure Mobile Services Tools 1.3
NuGet Package Manager 2.8.50926.663
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
Office Developer Tools for Visual Studio 2013 ENU 12.0.30626
Microsoft Office Developer Tools for Visual Studio 2013 ENU
PowerShell Tools 1.3
Provides file classification services using PowerShell
PreEmptive Analytics Visualizer 1.2
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
SQL Server Data Tools 12.0.41012.0
Windows Phone 8.1 SDK Integration 1.0
This package integrates the tools for the Windows Phone 8.1 SDK into the menus and controls of Visual Studio.
Workflow Manager Tools 1.0 1.0
This package contains the necessary Visual Studio integration components for Workflow Manager.
MVS 2022
Microsoft Visual Studio Professional 2022
Version 17.4.4
VisualStudio.17.Release/17.4.4+33213.308
Version 4.8.09037
Visual C++ 2022 00476-80000-00000-AA753
Microsoft Visual C++ 2022
ASP.NET and Web Tools 17.4.326.54890
Azure App Service Tools v3.0.0 17.4.326.54890
Azure Data Lake Tools for Visual Studio 2.6.5000.0
Azure Functions and Web Jobs Tools 17.4.326.54890
Azure Stream Analytics Tools for Visual Studio 2.6.5000.0
C# Tools 4.4.0-6.22608.27+af1e46ad38d900023f8b1a2839484e471ece1502
Cookiecutter 17.0.22263.6
Extensibility Message Bus 1.4.1 (main@2ee106a)
Microsoft Azure Hive Query Language Service 2.6.5000.0
Microsoft Azure Stream Analytics Language Service 2.6.5000.0
Mono Debugging for Visual Studio 17.4.19 (8c0a575)
Node.js Tools 1.5.40817.1 Commit Hash:66443775f9f3b1d8f8fee47af5002828b346688d
NuGet Package Manager 6.4.0
Python - Django support 17.0.22263.6
Provides templates and integration for the Django web framework.
Python - Profiling support 17.0.22263.6
Python - VC Project Support 17.0.21344.1
Provides support for launching C++ projects with Python debugging enabled.
Python with Pylance 17.0.22263.6
Razor (ASP.NET Core) 17.0.0.2246202+61cc048d36a3fc9246d2f04625988b19a18ab8f0
SQL Server Data Tools 17.0.62207.28050
TypeScript Tools 17.0.10921.2001
Visual Basic Tools 4.4.0-6.22608.27+af1e46ad38d900023f8b1a2839484e471ece1502
Visual F# Tools 17.4.0-beta.22512.4+525d5109e389341bb90b144c24e2ad1ceec91e7b
Visual Studio IntelliCode 2.2
AI-assisted development for Visual Studio.
VSPackage Extension 1.0
VSPackage Visual Studio Extension Detailed Info
Xamarin 17.4.0.312 (d17-4@be7e8d1)
Xamarin Designer 17.4.0.138 (remotes/origin/d17-4@d36bba3cc9)
Xamarin.Android SDK 13.1.0.1 (d17-4/13ba222)
Mono: a96bde9
Java.Interop: xamarin/java.interop/d17-4@fcc33ce2
SQLite: xamarin/sqlite/3.39.3@23e1ae7
Xamarin.Android Tools: xamarin/xamarin-android-tools/main@0be567a
Noemi
Hi N,
Thank you for sharing the information. Appreciate your patience while we were looking into the concern. Kindly go through the below steps. Please only proceed with the steps when the previous step has been completed.
Note: Make sure that the installation files of the product suite/toolkit and its compatible Visual Studio version are in the same directory while the separate versions are in a separate directory. To rephrase it, the Intel® Parallel Studio XE suite 2017 and Visual Studio 2013 needs to be in a separate directory than the Intel® OneAPI toolkit for the multiple product installation & integration to work smoothly.
- Uninstall Visual Studio 2019 (16.11.23) and 2022 (17.4.4). Kindly visit the below link to find detailed information on removing Visual Studio using InstallCleanup.exe.
- Install Visual Studio 2019 (16.11.21) or 2022 (17.4.2) with the Desktop development with C++ component selected.
- You may refer to the below link for reference.
- Intel® Compilers Compatibility with Microsoft Visual Studio* Link: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-...
- Try installing Intel® oneAPI Base Toolkit 2023.
However, kindly let us know if the issue persists or if there are any concerns in between the steps.
Hope you have a nice day ahead.
Soumya
Hi N,
Please let us know if the issue persists or if there are any further queries or concerns.
Soumya
Hi N,
We understand that you might be looking into the provided steps. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this thread active.
Soumya
Good Morning Soumya,
I am looking into the provided steps.
Noemi
I got the following error
Log File:
03/08/2023 11:27:02:495 : 5840 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/noemi/AppData/Local/Temp/intel_oneapi_installer/2023.03.08.11.26.06.106 --product-id intel.oneapi.win.basekit.product --product-ver 2023.0.0-25940 --package-path C:\Users\noemi\AppData\Local\Temp\w_BaseKit_p_2023.0.0.25940 (2)_2023-03-08_11-26-05\packages
03/08/2023 11:27:02:496 : 5840 : MESSAGE : Installer is started in GUI mode
03/08/2023 11:27:02:496 : 5840 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.0.251
03/08/2023 11:27:02:496 : 5840 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.0-251
03/08/2023 11:27:02:496 : 5840 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2023.0.0-25940. Mode is set to install.
03/08/2023 11:27:03:264 : 9376 : MESSAGE : PreRequisite for other install successfully checked
03/08/2023 11:27:03:266 : 9376 : MESSAGE : PreRequisite for other Intel install successfully checked
03/08/2023 11:27:03:270 : 9376 : MESSAGE : All checks for preRequisite for supported operation system are passed
03/08/2023 11:27:04:848 : 9376 : MESSAGE : PreRequisite for admin rights successfully checked
03/08/2023 11:27:04:848 : 9376 : MESSAGE : PreRequisite for temporary folder successfully checked
03/08/2023 11:27:04:848 : 9376 : MESSAGE : PreRequisite for host architecture successfully checked
03/08/2023 11:27:05:020 : 5840 : MESSAGE : The following products are installed by the moment:
Id: intel.oneapi.win.basekit.product, name: Intel® oneAPI Base Toolkit, version: 2022, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.hpckit.product, name: Intel® oneAPI HPC Toolkit, version: 2021.3, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.hpckit.product, name: Intel® oneAPI HPC Toolkit, version: 2022, installation directory: C:\Program Files (x86)\Intel\oneAPI
End of installed products list.
03/08/2023 11:27:20:034 : 2872 : MESSAGE : Check for id = [CPP170IDEFound] failed
03/08/2023 11:27:20:034 : 2872 : MESSAGE : Title [Intel® C++ Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 11:27:20:034 : 2872 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel C++ Compiler 17.0 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 17.0 or older Intel C++ Compilers from the Visual Studio IDE.]
03/08/2023 11:27:20:034 : 2872 : MESSAGE : Check for id = [F170IDEFound] failed
03/08/2023 11:27:20:034 : 2872 : MESSAGE : Title [Intel® Visual Fortran Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 11:27:20:034 : 2872 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 17.0 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 17.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE.]
03/08/2023 11:27:20:036 : 2872 : MESSAGE : Check for id = [CPP191IDEFound] failed
03/08/2023 11:27:20:036 : 2872 : MESSAGE : Title [Intel® C++ Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 11:27:20:036 : 2872 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel C++ Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel C++ Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel C++ Compilers.]
03/08/2023 11:27:20:036 : 2872 : MESSAGE : Check for id = [F191IDEFound] failed
03/08/2023 11:27:20:036 : 2872 : MESSAGE : Title [Intel® Visual Fortran Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 11:27:20:036 : 2872 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel Visual Fortran Compilers.]
03/08/2023 11:27:20:883 : 2872 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
03/08/2023 11:27:20:883 : 2872 : MESSAGE : Title [Intel® Graphics Driver for Windows not found.]
03/08/2023 11:27:20:883 : 2872 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/prerequisites/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
03/08/2023 11:27:20:886 : 2872 : MESSAGE : PreRequisite for Instance Msi successfully checked
03/08/2023 11:27:42:174 : 2872 : MESSAGE : PreRequisite for free disk space passed
03/08/2023 11:27:42:175 : 2872 : MESSAGE : PreRequisite for permissions passed
03/08/2023 11:27:42:175 : 2872 : MESSAGE : PreRequisite for other install successfully checked
03/08/2023 11:27:42:175 : 2872 : MESSAGE : PreRequisite for other Intel install successfully checked
03/08/2023 11:27:42:204 : 2872 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2019] passed
03/08/2023 11:27:42:205 : 2872 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
03/08/2023 11:27:42:232 : 2872 : MESSAGE : Check for blocking processes passed
03/08/2023 11:27:42:258 : 2872 : MESSAGE : Check for blocking processes passed
03/08/2023 11:27:42:264 : 2872 : MESSAGE : Check for id = [vtune.prerequisite.custom.gpu] failed
03/08/2023 11:27:42:264 : 2872 : MESSAGE : Title [A reboot will be required to enable certain features]
03/08/2023 11:27:42:264 : 2872 : MESSAGE : Description [Once the installation is complete, please reboot your system to enable extended GPU analysis on Intel® HD Graphics and Intel® Iris® Xe graphics]
03/08/2023 11:27:44:737 : 5840 : MESSAGE : ISIP consent status is 'Yes'
03/08/2023 11:27:44:737 : 5840 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
03/08/2023 11:27:44:737 : 5840 : MESSAGE : Product download size required: 40012980 bytes
03/08/2023 11:27:44:737 : 5840 : MESSAGE : Product installation size required: 18835659205 bytes
03/08/2023 11:27:44:737 : 5840 : MESSAGE : Product will be (un)integrated with the following IDEs:
03/08/2023 11:27:44:737 : 5840 : MESSAGE : Microsoft Visual Studio* 2019
03/08/2023 11:27:44:738 : 5840 : MESSAGE : End of IDE list.
03/08/2023 11:27:44:751 : 2872 : MESSAGE : Graph State Dump.
intel.oneapi.win.basekit.product,v=2023.0.0-25940, Enabled, Selected, Not Installed
intel.oneapi.win.basekit.getting_started,v=2023.0.0-25940, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2023.0.0-25468, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2023.0.0-25468, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.common,v=2023.0.0-25547, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2019,v=2023.0.0-25547, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2022,v=2023.0.0-25547, Disabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities,v=2021.8.0-25540, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2019,v=2021.8.0-25540, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.common,v=2021.8.0-25540, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2022,v=2021.8.0-25540, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger,v=2023.0.0-25548, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2023.0.0-25548, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2023.0.0-25548, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.0.0-25548, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.0.0-25548, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpl,v=2022.0.0-25550, Enabled, Selected, Not Installed
intel.oneapi.win.condaindex,v=2023.0.0-25469, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.devel,v=2021.8.0-25874, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.runtime,v=2021.8.0-25874, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler,v=2023.0.0-25922, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-dpcpp-common,v=2023.0.0-25922, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common,v=2023.0.0-25922, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2023.0.0-25922, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2023.0.0-25922, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.0.0-25922, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2021_VS160.vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS160.vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS160.vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS170.vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS170.vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique192_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique193_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique2023_vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique2023_vsix_llvm_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2023.0.0-25839, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_193_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2019,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2022,v=2023.0.0-25839, Disabled, Not Selected, Not Installed
intel.oneapi.win.dal.devel,v=2023.0.0-25934, Enabled, Selected, Not Installed
intel.oneapi.win.dal.runtime,v=2023.0.0-25934, Enabled, Selected, Not Installed
intel.oneapi.win.vpl,v=2023.0.0-25551, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.devel,v=2021.7.0-25929, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.runtime,v=2021.7.0-25929, Enabled, Selected, Not Installed
intel.oneapi.win.ippcp,v=2021.6.3-25544, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2023.0.0-25930, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2023.0.0-25930, Enabled, Selected, Not Installed
intel.oneapi.win.advisor,v=2023.0.0-25538, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vsix,v=2023.0.0-25538, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vs2019,v=2023.0.0-25538, Enabled, Selected, Not Installed
intel.oneapi.win.vtune,v=2023.0.0-25541, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vsix,v=2023.0.0-25541, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vs2019,v=2023.0.0-25541, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vs2022,v=2023.0.0-25541, Disabled, Not Selected, Not Installed
intel.oneapi.win.dnnl,v=2023.0.0-25927, Enabled, Selected, Not Installed
03/08/2023 11:27:46:846 : 2872 : MESSAGE : Operations dump.
Updating package state...
Preparing removal...
Remove intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97
Remove intel.oneapi.win.vtune,v=2022.0.0-88
Remove intel.oneapi.win.vtune.vs2019,v=2022.0.0-88
Remove intel.oneapi.win.vtune.vsix,v=2022.0.0-88
Remove intel.oneapi.win.advisor,v=2022.0.0-78
Remove intel.oneapi.win.advisor.vs2019,v=2022.0.0-78
Remove intel.oneapi.win.advisor.vsix,v=2022.0.0-78
Remove intel.oneapi.win.oneapi-common.vars,v=2022.0.0-67
Remove intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2022.0.0-161
Remove intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS160.vs2019,v=2022.0.0-161
Remove intel.oneapi.win.dpcpp-compiler.ide_shared.vs2019,v=2022.0.0-161
Remove intel.oneapi.win.dev-utilities.vs2019,v=2021.5.0-922
Remove intel.oneapi.win.basekit.getting_started,v=2022.1.0-116
Finalizing removal. It may take up to 5 minutes...
Remove intel.oneapi.win.condaindex,v=2022.0.0-61
Remove intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2022.0.0-161
Remove intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2021.5.0-115
Remove intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2021.5.0-115
Preparing installation...
Protecting installation location...
Install intel.oneapi.win.basekit.getting_started,v=2023.0.0-25940
Install intel.oneapi.win.oneapi-common.vars,v=2023.0.0-25468
Install intel.oneapi.win.oneapi-common.licensing,v=2023.0.0-25468
Install intel.oneapi.win.dpcpp_ct.vs2019,v=2023.0.0-25547
Install intel.oneapi.win.dpcpp_ct.common,v=2023.0.0-25547
Install intel.oneapi.win.dev-utilities.common,v=2021.8.0-25540
Install intel.oneapi.win.dev-utilities.vs2019,v=2021.8.0-25540
Install intel.oneapi.win.dev-utilities,v=2021.8.0-25540
Install intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2023.0.0-25548
Install intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2023.0.0-25548
Install intel.oneapi.win.dpcpp_debugger,v=2023.0.0-25548
Install intel.oneapi.win.condaindex,v=2023.0.0-25469
Install intel.oneapi.win.dpl,v=2022.0.0-25550
Install intel.oneapi.win.tbb.runtime,v=2021.8.0-25874
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2023.0.0-25839
Install intel.oneapi.win.tbb.devel,v=2021.8.0-25874
Install intel.oneapi.win.openmp,v=2023.0.0-25922
Install intel.oneapi.win.compilers-common-runtime,v=2023.0.0-25922
Install intel.oneapi.win.compilers-common,v=2023.0.0-25922
Install intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.0.0-25922
Install intel.oneapi.win.cpp-dpcpp-common,v=2023.0.0-25922
Install intel.oneapi.win.dpcpp-compiler.ide.vs2019,v=2023.0.0-25839
Install intel.oneapi.win.dpcpp-compiler.ide_shared.vs2019,v=2023.0.0-25839
Install intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS160.vs2019,v=2023.0.0-25839
Install intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS160.vs2019,v=2023.0.0-25839
Install intel.oneapi.win.compilers-common.ide.common,v=2023.0.0-25839
Install intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2019,v=2023.0.0-25839
Install intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique2023_vs2019,v=2023.0.0-25839
Install intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2023.0.0-25839
Install intel.oneapi.win.dpcpp-compiler,v=2023.0.0-25922
Install intel.oneapi.win.dal.runtime,v=2023.0.0-25934
Install intel.oneapi.win.dal.devel,v=2023.0.0-25934
Install intel.oneapi.win.vpl,v=2023.0.0-25551
Install intel.oneapi.win.ipp.runtime,v=2021.7.0-25929
Install intel.oneapi.win.ipp.devel,v=2021.7.0-25929
Install intel.oneapi.win.ippcp,v=2021.6.3-25544
Install intel.oneapi.win.mkl.runtime,v=2023.0.0-25930
Install intel.oneapi.win.mkl.devel,v=2023.0.0-25930
Install intel.oneapi.win.advisor.vsix,v=2023.0.0-25538
Install intel.oneapi.win.advisor.vs2019,v=2023.0.0-25538
Install intel.oneapi.win.advisor,v=2023.0.0-25538
Install intel.oneapi.win.vtune.vsix,v=2023.0.0-25541
Install intel.oneapi.win.vtune.vs2019,v=2023.0.0-25541
Install intel.oneapi.win.vtune,v=2023.0.0-25541
Install intel.oneapi.win.dnnl,v=2023.0.0-25927
Install intel.oneapi.win.basekit.product,v=2023.0.0-25940
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
03/08/2023 11:27:46:891 : 2872 : MESSAGE : Start install/modify sequence execution.
03/08/2023 11:27:46:931 : 2872 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1678292866841822'.
03/08/2023 11:27:46:931 : 2872 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1678292866841822' execution is finished with status Success.
03/08/2023 11:27:46:931 : 2872 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1678292866841822'.
03/08/2023 11:27:46:932 : 2872 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1678292866841822' execution is finished with status Success.
03/08/2023 11:27:46:932 : 2872 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97'.
03/08/2023 11:27:48:502 : 2872 : ERROR : Removal of component has failed.
Component id: intel.oneapi.win.dpcpp_ct.vs2019, name: Intel® DPC++ Compatibility Tool, version: 2022.0.0-97.
Error: Sequence execution failed.
03/08/2023 11:27:48:502 : 2872 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97' execution is finished with status Fail.
03/08/2023 11:27:48:502 : 2872 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1678292866841822'.
03/08/2023 11:27:48:502 : 2872 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1678292866841822' rollback is finished with status Success.
03/08/2023 11:27:48:502 : 2872 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1678292866841822'.
03/08/2023 11:27:48:523 : 2872 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1678292866841822' rollback is finished with status Success.
03/08/2023 11:27:48:523 : 2872 : ERROR : Install sequence execution status: Rollback
03/08/2023 11:27:48:542 : 5840 : MESSAGE : ----------------------------------------------------------------------------------------------------
03/08/2023 11:27:48:542 : 5840 : MESSAGE : Anonymous statistics fields:
03/08/2023 11:27:48:542 : 5840 : MESSAGE : EventId = 'install-min'
03/08/2023 11:27:48:542 : 5840 : MESSAGE : EventTime = ''
03/08/2023 11:27:48:542 : 5840 : MESSAGE : Id = 'intel.oneapi.win.basekit.product,v=2023.0.0-25940'
03/08/2023 11:27:48:542 : 5840 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Base Toolkit 2023\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4611\", \"product_tag\":\"\" }'
03/08/2023 11:27:48:542 : 5840 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Base Toolkit 2023'
03/08/2023 11:27:48:694 : 8060 : ERROR : Integrity check failed.
Checksum of file C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.dpcpp_debugger,v=2023.0.0-25548\data1.cab is not correct.
I tried one more time and got the following error:
03/08/2023 12:00:01:151 : 6692 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/noemi/AppData/Local/Temp/intel_oneapi_installer/2023.03.08.11.59.55.298 --product-id intel.oneapi.win.basekit.product --product-ver 2023.0.0-25940 --package-path C:\Users\noemi\AppData\Local\Temp\w_BaseKit_p_2023.0.0.25940 (2)_2023-03-08_11-59-54\packages
03/08/2023 12:00:01:151 : 6692 : MESSAGE : Installer is started in GUI mode
03/08/2023 12:00:01:151 : 6692 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.0.251
03/08/2023 12:00:01:151 : 6692 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.0-251
03/08/2023 12:00:01:151 : 6692 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2023.0.0-25940. Mode is set to install.
03/08/2023 12:00:01:835 : 21768 : MESSAGE : PreRequisite for other install successfully checked
03/08/2023 12:00:01:839 : 21768 : MESSAGE : PreRequisite for other Intel install successfully checked
03/08/2023 12:00:01:843 : 21768 : MESSAGE : All checks for preRequisite for supported operation system are passed
03/08/2023 12:00:02:597 : 21768 : MESSAGE : PreRequisite for admin rights successfully checked
03/08/2023 12:00:02:597 : 21768 : MESSAGE : PreRequisite for temporary folder successfully checked
03/08/2023 12:00:02:597 : 21768 : MESSAGE : PreRequisite for host architecture successfully checked
03/08/2023 12:00:02:764 : 6692 : MESSAGE : The following products are installed by the moment:
03/08/2023 12:00:06:996 : 11816 : MESSAGE : Check for id = [CPP170IDEFound] failed
03/08/2023 12:00:06:996 : 11816 : MESSAGE : Title [Intel® C++ Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 12:00:06:996 : 11816 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel C++ Compiler 17.0 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 17.0 or older Intel C++ Compilers from the Visual Studio IDE.]
03/08/2023 12:00:06:996 : 11816 : MESSAGE : Check for id = [F170IDEFound] failed
03/08/2023 12:00:06:996 : 11816 : MESSAGE : Title [Intel® Visual Fortran Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 12:00:06:997 : 11816 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 17.0 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 17.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE.]
03/08/2023 12:00:06:998 : 11816 : MESSAGE : Check for id = [CPP191IDEFound] failed
03/08/2023 12:00:06:998 : 11816 : MESSAGE : Title [Intel® C++ Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 12:00:06:998 : 11816 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel C++ Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel C++ Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel C++ Compilers.]
03/08/2023 12:00:06:999 : 11816 : MESSAGE : Check for id = [F191IDEFound] failed
03/08/2023 12:00:06:999 : 11816 : MESSAGE : Title [Intel® Visual Fortran Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
03/08/2023 12:00:06:999 : 11816 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel Visual Fortran Compilers.]
03/08/2023 12:00:07:716 : 11816 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
03/08/2023 12:00:07:716 : 11816 : MESSAGE : Title [Intel® Graphics Driver for Windows not found.]
03/08/2023 12:00:07:716 : 11816 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/prerequisites/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
03/08/2023 12:00:07:718 : 11816 : MESSAGE : PreRequisite for Instance Msi successfully checked
03/08/2023 12:00:14:363 : 11816 : MESSAGE : PreRequisite for free disk space passed
03/08/2023 12:00:14:364 : 11816 : MESSAGE : PreRequisite for permissions passed
03/08/2023 12:00:14:364 : 11816 : MESSAGE : PreRequisite for other install successfully checked
03/08/2023 12:00:14:364 : 11816 : MESSAGE : PreRequisite for other Intel install successfully checked
03/08/2023 12:00:14:393 : 11816 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2019] passed
03/08/2023 12:00:14:393 : 11816 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
03/08/2023 12:00:14:421 : 11816 : MESSAGE : Check for blocking processes passed
03/08/2023 12:00:14:447 : 11816 : MESSAGE : Check for blocking processes passed
03/08/2023 12:00:14:453 : 11816 : MESSAGE : Check for id = [vtune.prerequisite.custom.gpu] failed
03/08/2023 12:00:14:453 : 11816 : MESSAGE : Title [A reboot will be required to enable certain features]
03/08/2023 12:00:14:453 : 11816 : MESSAGE : Description [Once the installation is complete, please reboot your system to enable extended GPU analysis on Intel® HD Graphics and Intel® Iris® Xe graphics]
03/08/2023 12:00:16:469 : 6692 : MESSAGE : ISIP consent status is 'Yes'
03/08/2023 12:00:16:469 : 6692 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
03/08/2023 12:00:16:469 : 6692 : MESSAGE : Product download size required: 40012980 bytes
03/08/2023 12:00:16:469 : 6692 : MESSAGE : Product installation size required: 18835659205 bytes
03/08/2023 12:00:16:469 : 6692 : MESSAGE : Product will be (un)integrated with the following IDEs:
03/08/2023 12:00:16:469 : 6692 : MESSAGE : Microsoft Visual Studio* 2019
03/08/2023 12:00:16:470 : 6692 : MESSAGE : End of IDE list.
03/08/2023 12:00:16:483 : 11816 : MESSAGE : Graph State Dump.
03/08/2023 12:00:18:397 : 11816 : MESSAGE : Operations dump.
03/08/2023 12:00:18:445 : 11816 : MESSAGE : Start install/modify sequence execution.
03/08/2023 12:00:18:495 : 11816 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1678294818392383'.
03/08/2023 12:00:18:495 : 11816 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1678294818392383' execution is finished with status Success.
03/08/2023 12:00:18:495 : 11816 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1678294818392383'.
03/08/2023 12:00:18:495 : 11816 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1678294818392383' execution is finished with status Success.
03/08/2023 12:00:18:495 : 11816 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97'.
03/08/2023 12:00:20:168 : 11816 : ERROR : Removal of component has failed.
03/08/2023 12:00:20:168 : 11816 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97' execution is finished with status Fail.
03/08/2023 12:00:20:168 : 11816 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1678294818392383'.
03/08/2023 12:00:20:168 : 11816 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1678294818392383' rollback is finished with status Success.
03/08/2023 12:00:20:168 : 11816 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1678294818392383'.
03/08/2023 12:00:20:189 : 11816 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1678294818392383' rollback is finished with status Success.
03/08/2023 12:00:20:189 : 11816 : ERROR : Install sequence execution status: Rollback
03/08/2023 12:00:20:209 : 6692 : MESSAGE : ----------------------------------------------------------------------------------------------------
03/08/2023 12:00:20:209 : 6692 : MESSAGE : Anonymous statistics fields:
03/08/2023 12:00:20:209 : 6692 : MESSAGE : EventId = 'install-min'
03/08/2023 12:00:20:209 : 6692 : MESSAGE : EventTime = ''
03/08/2023 12:00:20:209 : 6692 : MESSAGE : Id = 'intel.oneapi.win.basekit.product,v=2023.0.0-25940'
03/08/2023 12:00:20:209 : 6692 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Base Toolkit 2023\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4611\", \"product_tag\":\"\" }'
03/08/2023 12:00:20:209 : 6692 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Base Toolkit 2023'
03/08/2023 12:00:20:448 : 1596 : ERROR : Integrity check failed.
There is an existing issue with Visual Studio and oneAPI installation if you have older versions of oneAPI in your system, did you try using this workaround? https://www.intel.com/content/www/us/en/developer/articles/technical/vs2022-and-oneapi-install-issue.html
I tried and I got the following error:
I may need to do a clean reinstall of Windows and reinstall all intel tools because nothing seems to be working.
N
Hi N,
Thanks for the logs. We are currently checking them with our resources. Please wait for 2-3 business days. We will get back to you as soon as possible.
Soumya
Hi N,
We appreciate your patience while we were checking on the logs. Based on them, we would need to confirm the following details to check further.
- Were Visual Studio 2019 and 2022 uninstalled as mentioned in the earlier steps? Please make sure & confirm of it using InstallCleanup.exe through the information provided in the below link.
- If you had referred to the below link then please let us know.
- Link: https://www.intel.com/content/www/us/en/developer/articles/technical/vs2022-and-oneapi-install-issue.html
- Did you try Option 2?
- Before you had received the screenshot error, did you go through all the steps mentioned in the workaround in the given order?
- If any step was skipped, please let us know the concern you had in implementing it.
Soumya
Hello Soumya,
I uninstalled MVS 2019 and 2022. I successfully used InstallCleanup.exe following the steps provided.
Then I reinstalled MVS 2019 (16.11.21) with the Desktop development with C++ component selected.
I tried installing Intel® oneAPI Base Toolkit 2023but the problem persisted, see error image and log file below:
LOG FILE:
03/13/2023 23:11:48:256 : 13644 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/noemi/AppData/Local/Temp/intel_oneapi_installer/2023.03.13.23.11.42.294 --product-id intel.oneapi.win.basekit.product --product-ver 2023.0.0-25940 --package-path C:\Users\noemi\AppData\Local\Temp\w_BaseKit_p_2023.0.0.25940 (3)_2023-03-13_23-11-41\packages
03/13/2023 23:11:48:256 : 13644 : MESSAGE : Installer is started in GUI mode
03/13/2023 23:11:48:257 : 13644 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.0.251
03/13/2023 23:11:48:257 : 13644 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.0-251
03/13/2023 23:11:48:257 : 13644 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2023.0.0-25940. Mode is set to install.
03/13/2023 23:11:48:923 : 24244 : MESSAGE : PreRequisite for other install successfully checked
03/13/2023 23:11:48:931 : 24244 : MESSAGE : PreRequisite for other Intel install successfully checked
03/13/2023 23:11:48:942 : 24244 : MESSAGE : All checks for preRequisite for supported operation system are passed
03/13/2023 23:11:49:689 : 24244 : MESSAGE : PreRequisite for admin rights successfully checked
03/13/2023 23:11:49:690 : 24244 : MESSAGE : PreRequisite for temporary folder successfully checked
03/13/2023 23:11:49:690 : 24244 : MESSAGE : PreRequisite for host architecture successfully checked
03/13/2023 23:11:49:844 : 13644 : MESSAGE : The following products are installed by the moment:
03/13/2023 23:12:10:961 : 7956 : MESSAGE : Check for id = [CPP170IDEFound] failed
03/13/2023 23:12:10:961 : 7956 : MESSAGE : Title [Intel® C++ Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.]
03/13/2023 23:12:10:961 : 7956 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel C++ Compiler 17.0 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 17.0 or older Intel C++ Compilers from the Visual Studio IDE.]
03/13/2023 23:12:10:962 : 7956 : MESSAGE : Check for id = [F170IDEFound] failed
03/13/2023 23:12:10:962 : 7956 : MESSAGE : Title [Intel® Visual Fortran Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.]
03/13/2023 23:12:10:962 : 7956 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 17.0 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 17.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE.]
03/13/2023 23:12:10:963 : 7956 : MESSAGE : Check for id = [CPP191IDEFound] failed
03/13/2023 23:12:10:963 : 7956 : MESSAGE : Title [Intel® C++ Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
03/13/2023 23:12:10:963 : 7956 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel C++ Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel C++ Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel C++ Compilers.]
03/13/2023 23:12:10:964 : 7956 : MESSAGE : Check for id = [F191IDEFound] failed
03/13/2023 23:12:10:964 : 7956 : MESSAGE : Title [Intel® Visual Fortran Compiler 19.1 Integration(s) in Microsoft Visual Studio* is already installed.]
03/13/2023 23:12:10:964 : 7956 : MESSAGE : Description [Next step you will be given an option to integrate with Microsoft Visual Studio. Please read the following warning before proceeding. If you choose to install, the Intel Visual Fortran Compiler 19.1 IDE integration(s) will be uninstalled and the oneAPI Compiler 2021 Product IDE integration will be installed. You will no longer be able to select 18.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE. You will still be able to select 19.0 or newer Intel Visual Fortran Compilers.]
03/13/2023 23:12:11:679 : 7956 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
03/13/2023 23:12:11:679 : 7956 : MESSAGE : Title [Intel® Graphics Driver for Windows not found.]
03/13/2023 23:12:11:679 : 7956 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/prerequisites/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
03/13/2023 23:12:11:681 : 7956 : MESSAGE : PreRequisite for Instance Msi successfully checked
03/13/2023 23:12:19:356 : 7956 : MESSAGE : PreRequisite for free disk space passed
03/13/2023 23:12:19:357 : 7956 : MESSAGE : PreRequisite for permissions passed
03/13/2023 23:12:19:357 : 7956 : MESSAGE : PreRequisite for other install successfully checked
03/13/2023 23:12:19:357 : 7956 : MESSAGE : PreRequisite for other Intel install successfully checked
03/13/2023 23:12:19:392 : 7956 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2019] passed
03/13/2023 23:12:19:393 : 7956 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
03/13/2023 23:12:19:421 : 7956 : MESSAGE : Check for blocking processes passed
03/13/2023 23:12:19:448 : 7956 : MESSAGE : Check for blocking processes passed
03/13/2023 23:12:19:454 : 7956 : MESSAGE : Check for id = [vtune.prerequisite.custom.gpu] failed
03/13/2023 23:12:19:454 : 7956 : MESSAGE : Title [A reboot will be required to enable certain features]
03/13/2023 23:12:19:454 : 7956 : MESSAGE : Description [Once the installation is complete, please reboot your system to enable extended GPU analysis on Intel® HD Graphics and Intel® Iris® Xe graphics]
03/13/2023 23:12:21:569 : 13644 : MESSAGE : ISIP consent status is 'Yes'
03/13/2023 23:12:21:569 : 13644 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
03/13/2023 23:12:21:569 : 13644 : MESSAGE : Product download size required: 40012980 bytes
03/13/2023 23:12:21:569 : 13644 : MESSAGE : Product installation size required: 18835659205 bytes
03/13/2023 23:12:21:569 : 13644 : MESSAGE : Product will be (un)integrated with the following IDEs:
03/13/2023 23:12:21:570 : 13644 : MESSAGE : Microsoft Visual Studio* 2019
03/13/2023 23:12:21:570 : 13644 : MESSAGE : End of IDE list.
03/13/2023 23:12:21:585 : 7956 : MESSAGE : Graph State Dump.
03/13/2023 23:12:23:427 : 7956 : MESSAGE : Operations dump.
03/13/2023 23:12:23:473 : 7956 : MESSAGE : Start install/modify sequence execution.
03/13/2023 23:12:23:514 : 7956 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1678763543423166'.
03/13/2023 23:12:23:514 : 7956 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1678763543423166' execution is finished with status Success.
03/13/2023 23:12:23:514 : 7956 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1678763543423166'.
03/13/2023 23:12:23:514 : 7956 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1678763543423166' execution is finished with status Success.
03/13/2023 23:12:23:515 : 7956 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97'.
03/13/2023 23:12:25:153 : 7956 : ERROR : Removal of component has failed.
03/13/2023 23:12:25:153 : 7956 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.vs2019,v=2022.0.0-97' execution is finished with status Fail.
03/13/2023 23:12:25:153 : 7956 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1678763543423166'.
03/13/2023 23:12:25:153 : 7956 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1678763543423166' rollback is finished with status Success.
03/13/2023 23:12:25:153 : 7956 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1678763543423166'.
03/13/2023 23:12:25:173 : 7956 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1678763543423166' rollback is finished with status Success.
03/13/2023 23:12:25:173 : 7956 : ERROR : Install sequence execution status: Rollback
03/13/2023 23:12:25:210 : 13644 : MESSAGE : ----------------------------------------------------------------------------------------------------
03/13/2023 23:12:25:210 : 13644 : MESSAGE : Anonymous statistics fields:
03/13/2023 23:12:25:210 : 13644 : MESSAGE : EventId = 'install-min'
03/13/2023 23:12:25:210 : 13644 : MESSAGE : EventTime = ''
03/13/2023 23:12:25:210 : 13644 : MESSAGE : Id = 'intel.oneapi.win.basekit.product,v=2023.0.0-25940'
03/13/2023 23:12:25:210 : 13644 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Base Toolkit 2023\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4611\", \"product_tag\":\"\" }'
03/13/2023 23:12:25:210 : 13644 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Base Toolkit 2023'
03/13/2023 23:12:25:262 : 5004 : ERROR : Integrity check failed.
Hi N,
Thanks for the update. Kindly try the Option 1 (all the steps in the given order) from the below link. On the Step 4, please uninstall the Intel® oneAPI Base Toolkit 2022.1 (as per the log it is currently installed on the system). After Step 6, try installing the Intel® oneAPI Base Toolkit 2023.
Please let us know if the issue persists. Looking forward to your update on the matter.
Hope you have a nice day ahead!
Soumya
Hi N,
Please let us know if the issue persists even after trying out the steps.
Soumya
Hi N,
We understand that you might be looking into the issue. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this thread active.
Soumya
![](/skins/images/E2C6D832B61BAAAA0B8D2A8E57BC7B01/responsive_peak/images/icon_anonymous_message.png)
