OneAPI does not work on windows
Hi Issac, we have sent you a private message. Kindly check your community inbox.
What information do you need and where I can gather the logs?
I tested OneAPI for compiling C++ SYCL on the same system months ago, and right now it doesnt work
Hi Isaac, could you please share the below details with us?
- Version of Microsoft Visual Studio installed along with it's build version.
- Operating System build on which you are installing the product.
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
- Is the installer an online or an offline package?
- Installation Log files.
- The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
To assist you further, we would require these details.
MSVC
VS: 19.9.6 & cl: 19.39.33523
Windows
Edition Windows 11 Pro
Version 23H2
Installed on 4/23/2024
OS build 22631.3527
Experience Windows Feature Experience Pack 1000.22700.1003.0
Only Intel OneAPI base toolkit 2024.1 is installed.
OneAPI online installer
And also I attempted a repair with the installer
Hi Isaac, we have sent you a private message. Kindly check your community inbox.
