cd /opt/intel/oneapi/mkl/latest/interfaces/fftw3xf
make libintel64
getting following error
make -f makefile lib _IA=intel64
make[1]: Entering directory '/opt/intel/oneapi/mkl/2023.1.0/interfaces/fftw3xf'
mkdir -p ./obj_intel
icc -Wall -Werror -I/opt/intel/oneapi/mkl/2023.1.0/include -I/opt/intel/oneapi/mkl/2023.1.0/include/fftw -c /opt/intel/oneapi/mkl/2023.1.0/interfaces/fftw3xf/wrappers/fftw_alignment_of.c -o obj_intel/fftw_alignment_of.o
icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message.
error: can't open file obj_intel/fftw_alignment_of.o for write
compilation aborted for /opt/intel/oneapi/mkl/2023.1.0/interfaces/fftw3xf/wrappers/fftw_alignment_of.c (code 1)
make[1]: *** [makefile:150: obj_intel/fftw_alignment_of.o] Error 1
make[1]: Leaving directory '/opt/intel/oneapi/mkl/2023.1.0/interfaces/fftw3xf'
make: *** [makefile:89: libintel64] Error 2
Hi Suman, could you please share the below information:
- Full name of the Intel® product you are using
- OS build on which you are installing
- Version of the product
We would like to know.
Suman, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
![](/skins/images/FCBE28625AAD2D8AF3EB3F393BF39703/responsive_peak/images/icon_anonymous_message.png)
