I am trying to better understand the different methodologies on using Altera FPGAs as a coprocessor in HPC applications.
Believe there there are four known methodologies. Familair with the first three.. 1. Module plugs into processor socket connection-Intel FSB 2. Module plugs into processor socket connection-AMD HyperTransport 3. Module plugged via PCI express interface 4. a. Module plugs into system memory DIMM socket b. Module plugs into a hard drive bay and connects to processor via DIMM socket Trying to get a better feel for Item-4. Wanted to know the pro's and con's of using FPGA on a memory DIMM socket? Does anybody know of any third party companies that use this approach and offer solutions in this space? Thanks!Link Copied
SRC Computers is the company I've heard of for# 4. They were started by Seymour Cray and do a number of different accelerator-type products. Also be sure to investigate the development side, i.e. hardware/software interaction. If you're ready to write HDL, it's usually not a big deal, but a lot of users investigating this area only write C for processors and want to "push a button" to create hardware from their C.
www.srccomp.com- Mark as New
Thank you.
For Solutions like# 1 and# 2 try XtremeData. They have some good engineers and are working on developing a more sophisticated toolchain compared to the RTL route.
http://www.xtremedatainc.com/products.html Brian- Mark as New
Yes, I did look into Xtremedata products for# 1 and# 2. And for# 3 found GiDEL's solutions suitable www.gidel.com. They have have a tool that can map DSP Builder model based designs to Altera FPGA via PCI express interface(Hardware In the Loop Methodology).
BTW: I am interested in seeing data throughput MB/s for two of Xtremedata's products 1. 2S180 FPGA connected via Intel FSB to a Xeon processor(Xtremedata) FSB interface supports 1066MHz and 64 bits. FPGA I/O connected via FSB might have some speed limitations. What I am looking for the real data throughput that was achieved b/w a 2S180 and a Xeon processor(MB/s)? 2. 2S180 FPGA connected via AMD HyperTransport to an Opteron Processor HyperTransport standard supports 3.2GB/sec(1.6 each way). Again the data I am looking for is the actual throughput between a 2S180 and an Opteron processor. Any thoughts on this? Thanks!- Subscribe to RSS Feed
